Cutting coil springs? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2012, 02:15 PM   #1 (permalink)
Member # 81189
I need to lower my rig about 3" in the rear. Instead of buying different coils...
Can I trim the coil, then using a torch... heat up the trimmed end, just 3" or so... In order to bend the trimmed end up a bit so it'll sit flat on my coil mount? Or will the heat ruin the spring steel?
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 02:23 PM   #2 (permalink)
Member # 81189
Nevermind. I found a How To link:
http://speeddirect.com/index.aspx?nodeID=173
Old 04-24-2012, 02:31 PM   #3 (permalink)
Banned
Member # 158768
i disagree with that link. between friends fucking up their car's ride quality in h/s and this video i'm going with torches being a bad idea. just use a cutoff wheel like he says and cut in quarter turns of the circle.
Quick Tip - Cutting Springs - YouTube
fatdan460 is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 02:34 PM   #4 (permalink)
Pook's Avatar
Member # 3370
I used a chop saw all the time cutting springs back in my lowrider days.
:grinpimp:
Pook is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 02:35 PM   #5 (permalink)
Member # 43587
Send a message via AIM to TBItoy
I plasma cut mine.
Quick and easy.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 02:37 PM   #6 (permalink)
Member # 187570
Ya the torch is a bad idea softens the spring to much. Just use a cut off wheel and cut to whatever length you want
toyota85 is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 06:29 PM   #7 (permalink)
Member # 81189
The cutting part isn't the issue. If you simply trim a coil back, the trimmed end isn't going to sit flat. So, you must bend the trimmed end of the spring which requires heating. The heating process if overdone will ruin the spring steel.
The heating & bending part is my concern.
Old 04-24-2012, 09:48 PM   #8 (permalink)
Kraqa's Avatar
Member # 24741
Send a message via AIM to Kraqa Send a message via MSN to Kraqa
I just used a cut off wheel and left the spring as it was. No issues.
REDWOOD PLASTICS RACING
Toyo Tires Offroad Race Team | EMF Rod Ends | Mulitia Muffler | VancouverWaterjet.com | RCV Performance Shafts | Redwood Plastics & Rubber
Instagram & Twitter: @Kraqa
Kraqa is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 01:12 AM   #9 (permalink)
Member # 127650
If you heat spring steel to the point you can bend it, you've annealed the steel and it takes the strength out of it. It will likely break where you heated it because that part of the spring is softer than the rest and it will be forced to flex more.
RanchTruck is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 06:51 AM   #10 (permalink)
Member # 43587
I've bent a "pig tail" into a couple springs, I clamped a pair of vise grips on the spring and hung some wet rags around it to absorb the heat. It never got hot past the vise grips.
Old 04-25-2012, 07:24 AM   #11 (permalink)
Member # 81189
I had no idea wet rags absorbed heat
I just need the last 4" or so of coil to bend up a smidge so I can trap it down with my mounting plates.
Old 04-25-2012, 07:29 AM   #12 (permalink)
JayMcJay's Avatar
Member # 111999
Wet rags dont absorb heat exactly, but the water converting to steam required a bunch of energy. A the heat travels up the coil it will heat the water in the rags making steam. There certainly is a cooling effect.
JayMcJay is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 07:33 AM   #13 (permalink)
Member # 43587
really? or are you being a smartass?
The vise grips help also, by redirecting part of the heat flow.
You just don't want to overheat the spring. If you run the torch hot where it will heat up the spot you need to bend quickly, then it wont heat the rest of the coil as bad.
How are your mounting plates made?
Old 04-25-2012, 11:07 AM   #14 (permalink)
Member # 81189
Worked perfect.
Trimmed it to length, put the end rung in the vise & collapsed it to where I wanted it so the bottom is flat. Ground off the paint & heated a 2" section of the bottom rung where I needed the bend to occur. Used a map gas hand torch, wasnt even red hot. Let the vise loose, and she stayed in place.
I used a wet rag clamped to the rung to keep heat from spreading up the coil.
Old 04-25-2012, 11:14 AM   #15 (permalink)
nate379's Avatar
Member # 20099
I did it on a car I didn't want to put more $$ into. Took a piece of old driveshaft tube as a form to bend the end around, heated it up and bent it. Worked fine.
nate379 is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 02:35 PM   #16 (permalink)
ErikB's Avatar
Member # 59
Should work fine, I've never had any problems.
Keep in mind that cutting it shorter increases the spring rate though.
[color=black].[/color]
Old 04-25-2012, 06:15 PM   #17 (permalink)
Member # 81189
I'll keep that in mind. It's prob not a bad thing to be honest.
They're soft!
