Anyone ever tried a 1" bore SE ram? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-26-2012, 09:56 PM   #1 (permalink)
Member # 79762
Buddy is building a Harbor Freight/Cal-Ranch sponsored rig, meaning it has been built on a very tight budget. It is all broken in and performing very well but he would like some steering assist.
We have always run 1.5" rams but have noticed with stock pumps a little bit of slow response, he wants to keep his stock pump. We are wondering how a 1" ram would react to a stock yota pump with roughly 1200 psi at idle, probably lower due to it's age. The working pressure of the ram is 1500 psi.
Doing the math the area of a 1 inch ram versus a 1.5 inch ram is almost double the piston size, same as a 1.5 inch to 2 inch. We tried to source a 1.25 inch bore ram for some middle ground but no go.
Searching online I really see no mention of anyone running that small bore of a ram, anyone have an opinion before we order?
kidkrawler is offline   Reply With Quote Quick reply to this message
Old 04-26-2012, 10:00 PM   #2 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Don't forget to subtract the shaft size.
& Blaine
:tank:
Old 04-26-2012, 10:01 PM   #3 (permalink)
Member # 43587
Send a message via AIM to TBItoy
It'll help, but of course, wont have as much power.
Any reason he wants to keep the stock pump? I assume 22r/re?
A Jeep Cherokee TC Saginaw pump can be swapped on for cheap, and is capable of much more flow and pressure than a Toyota pump.
I'd almost guarantee that the stock Yota pump is not putting out 1200psi. I put a gauge on mine and it would barely make 1000 with the motor revved.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 04-26-2012, 10:09 PM   #4 (permalink)
Wilson's Avatar
Member # 7233
Back in the day, we swapped a stock Gm saginaw "p" pump onto a 22r to run hydro
Old 04-27-2012, 12:57 AM   #5 (permalink)
ToadRacing's Avatar
Member # 102078
Do you have any pictures of the bracket for that?
Nikolai
ToadRacing is offline   Reply With Quote Quick reply to this message
Old 04-27-2012, 01:30 AM   #6 (permalink)
Member # 15354
Send a message via AIM to iniviate
a 1" bore ram would push 864lbs @ 1100psi.
a 1.5" ram would push 1944lbs @ 1100psi.
a 2" ram would push 3456lbs @ 1100psi.
pulling would be less, obviously.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote Quick reply to this message
Old 04-27-2012, 06:07 AM   #7 (permalink)
Member # 213125
Swap in a Saginaw pump. You'd be lucky to get 700 to 800 psi out of a Toyota pump at idle.
Aisin is offline   Reply With Quote Quick reply to this message
Old 04-27-2012, 08:22 AM   #8 (permalink)
Wilson's Avatar
Member # 7233
Nikolai
Doubtful, it was the rockme single seater. Whatever there was build-wise would be in the toy section. This was 10 yrs ago
Old 04-27-2012, 10:49 AM   #9 (permalink)
Member # 213125
A P style Saginaw is huge. Is there even room under the hood of a Toyota?
Old 04-27-2012, 11:00 AM   #10 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
TC pump on a 22RE is a common swap.
I traded some guy on PBB for his 1.25" ram. Works great on my 4Runner--one-finger steering on the highway, and no lag.
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 04-27-2012, 01:18 PM   #11 (permalink)
ToadRacing's Avatar
Member # 102078
No worries, I was just curious. I've run a TC pump on the 22r but I'd love to go to a p pump as I have a couple of the PSC ones sitting around here. I'm not sure how to build the bracket.
Nikolai
Old 04-27-2012, 01:59 PM   #12 (permalink)
89lc's Avatar
Member # 121143
Nikolai
I would imagine that if you used a different length belt, you could fit one pretty easy. Then again, my imagination is off sometimes.
I have a
I don't care what you want to smoke, who you want to poke. I don't care what you want to shoot or how many bullets you can have.
I just want people to mind their own business and leave me the fawk alone if I'm not fucking up thier shit.
89lc is offline   Reply With Quote Quick reply to this message
Old 04-30-2012, 05:49 PM   #13 (permalink)
Member # 43587
There was a guy building a Sag P pump swap bracket that replaced the A/C bracket.
Yunit was the username I think.
Old 05-01-2012, 07:18 AM   #14 (permalink)
the glassman's Avatar
Member # 33365
Send a message via MSN to the glassman
i had a 1 1/4 inch bore with 1 in ram cylender on my xj with 44 boggers and stock pump...
not the best but just good enough ..
walk a mile in someone elses shoes. then you'll be a mile away and have their shoes.
the glassman is offline   Reply With Quote Quick reply to this message
Old 05-01-2012, 10:05 AM   #15 (permalink)
Member # 79762
Where are you guys sourcing a 1.25" ram? Seems like a great in between setup.
Old 05-01-2012, 10:14 AM   #16 (permalink)
Member # 43587
1.25" cylinders pop up on surpluscenter.com from time to time for cheap.
They work very good for hydro assist.
