Pirate4x4.Com : 4x4 and Off-Road Forum (/forum/)
-   General 4x4 Discussion (https://www.pirate4x4.com/forum/16-general-4x4-discussion/)
-   -   tq issues with ultra bell (https://www.pirate4x4.com/forum/general-4x4-discussion/1062618-tq-issues-ultra-bell.html)
Nskeeter99 04-29-2012 01:50 PM
I snapped my bell housing on my 700. So i figured i would just up grad to the ultra bell. when i bolt it up to the motor, the tq is too tight. If i line it up with the raised bolt holes in the flywheel its super tight and you cant move it. If i line it up beside the holes with some effort you can move it. I don't have to back off the bolts much at all to get it to move. my tq is set in the pump. Am i stuck getting a new tq, are can i grind my mounts down a Little?. Maybe even cut the pump eats down a Little more.
chimaira989 04-29-2012 02:19 PM
do you mean torque converter when you say "tq"?
Is the converter seated completely in the transmission pump? I want to say you should feel 2 distinct clunks when installing it. It helps to turn it as you gently push it on.
You should have about 1/8th inch of clearance between the flexplate and converter, so either you have the wrong or defective bellhousing, or don't have the converter seated fully in the transmission if I am to understand your question..
Nskeeter99 04-29-2012 02:30 PM
Yea I Maent torque converter dont know why i put tq instead of tc. It seated good. there is less than an 8th between the tc and the pump bolts. http://www.race-mart.com/JW_Performa...92450-700.html is the one i got. now that i have it not getting a lot of answers on email. actually nun.
Halogrinder 04-29-2012 05:28 PM
step back and re-read your posts. they are hard as hell to understand what you are trying to say.
take pictures, drawings, anything........ because your spelling and description sucks to try and help you :D
it sounds like you "stacked the pump" on your transmission.... the torque converter isnt fully seated.
Corey Young 04-29-2012 06:03 PM
It might be a race bellhousing with a big diameter non race converter.
Nskeeter99 04-29-2012 06:13 PM
I don't know what stacked the pump means. I'm assuming you mean that the tc shaft is on the pump ears instead of in the tc notches. I don't think that is the issue the tc cant go back much. I cant get a standard flat tip screw drive between the tc and the pump bolts its that close. its almost like the bell is just a littel short.
Nskeeter99 04-29-2012 07:31 PM
it is a racing bell, however the stock converter is sopsed to fit but guess not
Halogrinder 04-29-2012 07:45 PM
well, this is easy then. start to pull it up to the tranny and spin the converter untill you cant move it. rock it back and forth, pull trans out and look for scrapes of paint/marks on the converter and the bell housing. nothing complicated there!
