Hydro ram problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-06-2012, 01:20 PM   #1 (permalink)
camarohrod's Avatar
Member # 159226
Hydro ram problems
I have a full hydro setup and I have developed a problem with my ram not retracting all the way, it's a tractor supply ram, it will extend all the way but it will not retract all the way. Anybody have any ideas on why it won't?
87 sammi, 400/400/205, d60/14b, 5.38's, full spool, 42" rockers
camarohrod is offline   Reply With Quote Quick reply to this message
Old 05-06-2012, 01:31 PM   #2 (permalink)
MADE IN USA
ChassisUltd's Avatar
Member # 24529
Was it originally working when it was set up? Sounds like you have an air cavitie in the system some were. Have you tried bleeding the system?
or you have a bad pressure oring or seal in the cyl..or crack? Dent in the cyl.?
A bit more info on other components used, than the ram could help us too
Pirate Discount Code "PIRATE4X4" To Save 10% OFF On All Chassis Unlimited Made Products
***Dont forget***
Free Ground Shipping on orders over $499
Low Prices, Hundred's of Parts & Unlimited Tech Support
Like Us on Facebook @
ChassisUltd is offline   Reply With Quote Quick reply to this message
Old 05-06-2012, 03:27 PM   #3 (permalink)
angryblack's Avatar
Member # 142394
Yup sounds like air trapped and possible binding..Do you have a 60 with springless caps on the kingpins..You may have too much preload and some air in the cylinder. Also n the ram with the hoses off and fluid bled out of the cylinder,cycle the steering by hand at the knuckles..During the complete travel best case you would be able to rotate the mounting pins with a pair of pliers or channel locks..If they cant spin it could be binding too much..
I had this issue with my full hydro..After taking the rig out the binding went away..Im sure it did due to the pins wearing some to give it the needed clearance from the off angle its mounted..that and the air bled out fully.
angryblack is offline   Reply With Quote Quick reply to this message
Old 05-08-2012, 05:25 PM   #4 (permalink)
camarohrod's Avatar
Member # 159226
yes i have a king pin 60, its been workin fine for years and it just started doin this when i wheeled it last weekend, i have not tried bleeding it, that will be my next thing to do.
Old 05-08-2012, 10:20 PM   #5 (permalink)
Member # 163633
Hydro ram problems
If it's a ag ram the piston inside the cyl connected to the ram could have come loose and bottoming out
socal nick is offline   Reply With Quote Quick reply to this message
Old 05-10-2012, 01:14 PM   #6 (permalink)
Member # 97574
Is it bent?
https://www.facebook.com/groups/OFFROADCNCFILESHARING/
ROXROES is offline   Reply With Quote Quick reply to this message
