Axletech 4000 planetary steer axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-31-2012, 10:29 PM   #1 (permalink)
spinneybent's Avatar
Member # 93198
6.8 ratio, air lockers, 45 degree steering, 9 ton
"Use the sand from your vagina for traction".
TTC 2011 co dawg
spinneybent is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 10:33 PM   #2 (permalink)
Member # 93198
wheel bearing!!!
TTC 2011 co dawg
Old 08-31-2012, 10:37 PM   #3 (permalink)
Member # 93198
brake caliper
Axle started at 1370 lbs and is now down to 990 just from taking off the calipers, rotors, and caliper brackets. Just the bolts holding the brakets on weighed 18 lbs.
TTC 2011 co dawg
Old 08-31-2012, 10:57 PM   #4 (permalink)
Member # 55444
Now we're talkin. Whatcha doing with those?
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 11:04 PM   #5 (permalink)
Member # 201841
damn
the 59 fiat is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 11:11 PM   #6 (permalink)
Member # 93198
Just checkin em out for now. They showed up this mornin. Baddest ass axles I've seen yet. Took 190 lbs off of one side from debraking it. Should be just under 1000 when ready to run. 6.8 ratio, air lockers, 45 degree steering, 9 ton.
TTC 2011 co dawg
Old 08-31-2012, 11:17 PM   #7 (permalink)
Member # 93198
we will biuld a chassis around the axles, tires, and drive train. Been slowly biulding a 600 ci Merlin. Thinkin 60 ish r2's
TTC 2011 co dawg
Old 08-31-2012, 11:27 PM   #8 (permalink)
Member # 10736
They most likely use the spider gear planetaries. What was the price?
masonmachines is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 11:34 PM   #9 (permalink)
Member # 93198
Nope. 4 pinion planetaries. Axletech 4000s . They put these in military Cougars and some other mine sweeping vehicles.
I put em on my tab down at Harry's Speed Shop.
TTC 2011 co dawg
Old 09-01-2012, 05:19 AM   #10 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Thats funny, I still drop that line every once and a while.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 11:42 AM   #11 (permalink)
Member # 22301
There might be a lot of these axles showing up as the military swaps the solid axles to independent in a lot of the MRAP's. Definitely beefy axles.
phillyzj is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 04:50 PM   #12 (permalink)
onetoncv's Avatar
Member # 2160
There's a good chance the paint it C.a.r.c - Don't sand it - Jess
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 05:35 PM   #13 (permalink)
Idaho4x4Bronco's Avatar
Member # 139619
Nice score Ben! Put them under the Cruiser
Fuck It Sums It Up
Idaho4x4Bronco is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 06:24 PM   #14 (permalink)
Member # 6170
So now that you've debraked them, what are you doing for brakes?
Kevo
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 08:36 PM   #15 (permalink)
dan58's Avatar
Member # 19330
Send a message via AIM to dan58
Unless they've been blasted and repainted, they are. If it's the new waterborne stuff, it's a non issue.
dan58 is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 10:42 PM   #16 (permalink)
Member # 93198
what is c.a.r.c.? The paint is very thick! There is one spot where the paint chipped off and there is a sticky black coating. What the heck is it and whats it for?
Kevo
I will design and fabricate a pinion brake setup. Already have it designed. Should work excellent.
They are brand new so not blasted and painted. Whats wrong with the paint thats on them? Can't I just paint over the dessert tan?
Thanks for the info
TTC 2011 co dawg
Old 09-01-2012, 10:58 PM   #17 (permalink)
Member # 200478
what is c.a.r.c.?
chemical agent restisting coating. Don't know what is in it, but as stated don't breathe the dust. Or create it, for thay matter.
isbj60 is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 11:43 PM   #18 (permalink)
Member # 55444
Its toxic. Nasty stuff.
Old 09-02-2012, 12:00 AM   #19 (permalink)
MUDYCRAWLER's Avatar
Member # 47029
Hey Ben What are you up to now ? Holy Crap Those look intresting
Big Red Motorsports Ultra4 Car #775 Battle Born Team
Thank You to my Sponsors,
Ruff Stuff
AxleTech
Stazworks
Griffin Thermal
Poly Performance
A1 Upholstery
A-1 UPHOLSTERY 775-577-0600
MUDYCRAWLER is offline   Reply With Quote Quick reply to this message
Old 09-02-2012, 12:34 AM   #20 (permalink)
Member # 93198
Hey Rob. Time for somethin different and out of the box. Always wanted to biuld somethin with planetaries. These are a little heavier but alot stronger than the dueces that we usualy run. 45 degree steering with a 60 inch tire is hard to beat also.
TTC 2011 co dawg
Old 09-02-2012, 09:49 AM   #21 (permalink)
ChestonScout's Avatar
Member # 109153
I checked these out at Boyce awhile back. Pretty cool
RIP TTC
Dont let the haters get you down, alexray55!!! I would rather see ten homebrew rigs built with ingenuity and sweat than ten rigs built with a checkbook or credit card.
ChestonScout is offline   Reply With Quote Quick reply to this message
Old 09-02-2012, 10:04 AM   #22 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
You make that sound like it is an easy swap ... are they built to accept either or something?
Old 09-02-2012, 11:42 AM   #23 (permalink)
Member # 93198
I think some of those rigs may definatly be designed to accept ifs or solid axles. The axletech website shows the complete ifs units that look like they would bolt rite in.
TTC 2011 co dawg
Old 09-02-2012, 12:07 PM   #24 (permalink)
dan58's Avatar
Member # 19330
CARC is for quick and effective decon of military equipment. The older version was full of VOCs, but the DOD has be transitioning to the newer formulation called WD-CARC.
http://www.ndcee.ctc.com/fact_sheets/WDCARC.pdf
Old 09-02-2012, 09:09 PM   #25 (permalink)
Member # 93198
Thanks for the info and the link. Sounds like it's less toxic than it used to be. I'm gonna still take some precautions when I work on it.
TTC 2011 co dawg
