Does anyone make a kit for outboard disc brakes on a Rockwell axle? I know my buddy is going to think I am crazy and so will a lot of you but there is something about the pinion brake setup that I am just not fond of. Any ideas or information on this would be appreciated. Just to fill everyone in I purchased a rig with high pinion 60 axles front and rear. The front I was not to concerned with but the rear I knew wouild not hold up, I have another build where I can use the front axle and will probably sell the rear if I can. Both axles are Dynatrac high pinion 60 with 5.13 gears are they were. I striped the ring gear the first trip out on the rear as I thought I would. I plan to stick a set of government rebuilt 2 1/2 ton steering Rocks under it with lockers, remove the stock brakes and so on but I am having second thoughts on the pinion brakes.
