switching over my rear Hi9 to a megaHi9, and need to know what type of seals to run, I understand the mega needs to be completely submerged in oil, and they recommend running inner axle seals because you need to completely fill up the housing. I currently run seals on the end of the axle shaft because my wheel bearings require the diff fluid for lubrication, (semi float 40 spline Mosers)
so should I run inner axle seals (spidertrax style), and convert my outers to a sealed bearing? This way Im not filling the axle tubes as well with oil?
or
keep my current bearings and seals and just fill up the entire diff and tubes, seems like this would keep it running cooler, which i know is an issue for the mega, but it seems it would cause leaking at the end of my shaft/tube, I dont need my rotors coverd in diff fluid, these seals are already prone to leaking even with the diff/tubes not full, seems like they would leak for sure with all that oil?
guys at true Hi9 said to only run $wepco 203 diff fluid, that stuff is $70/gal, I probably need 5 gallons to do both diffs, any suggestion on a place to buy it or an alternative?
The last Swepco I bought was $64. Redline HD Shockproof is around $50/gallon. I really think that Redline or Amsoil Severe Gear 250 would be fine. You're still gonna spend $250+ on gear oil though. You might be able to save some money by getting a 5 gallon bucket.
Has anyone played with running some sort of pump to inject oil up in the pinion bearings? I hvae no personal experience, just heard of them. Might allow you to run regular oil levels, and save money in the long run with how expensive the fluids are.
I am running 40 spline full floaters and no seals in the rear and just fill the crap out of the axle and don't look at the CC bill . Are you going to run the currie pinion support?
Currie now makes the c-clip style pinion support for Hi9 according to Hi9, but I did notice Currie charges $100 less, Hi9 told me that the one they have made by Currie is specifically for the mega and has improved oiling, but im not sure about that since both are just sitting in the oil.
looking at Spidertrax web site it says their seal are designed upto 35 spline, so not sure about that one?
I added a internal baffle to shield the swepco off vent hole , So housing would breath easier , I ran into a problem with overfilling the housing like recomended, in the rear it tends to block vent building pressure and forcing oil by axle seals . Ps My Spidertax housing needed only 1.5 gals per diff.
When I built my front 609 I bought some speedway engineering seals to stuff in the axle tubes. You can slide it to any location within the axle tube, and it came with 3 seals per side :smokin:. Probably more expensive than the spidertrax though Speedway Engineering's Inner Axle Seals
The Currie pinion support for the hi 9 is different because its a high pinion third and the oil passages are different. Thats too bad the price is higher. The other Currie models are for low pinion thirds in either 9 or 10" varieties that are only high pinion when running them in rear/mid engine rigs.
If i run inner axle tube seals like the ones above, i need to switch out my outer bearings to a sealed/self lubricated bearing, which would be a regular roller bearing with a retainer holding it on (semi float), I currently have tapered roller bearings that are lubricated by the diff oil. when i ordered my axles/bearings years ago from Moser, they told me i should stick with a tapered roller bearing that is lubed by diff fluid, because it is stronger than a standard roller bearing that would be sealed, espically in a rockcrawler application due to side loading on the wheels?
Any thoughts here?
should i avoid a standard sealed bearing?
Taper roller bearing will always be stronger than a conventional roller bearing. Maybe upping your maintenance schedule & replacing a sealed unit is the answer.
Would an option be drilling & tapping a stop (maybe either side of seal) for the Speedway seals somewhere up the tubes work ??
I do like the idea of allowing more fluid into the centre for cooling purposes & those speedway seals would allow extra having them up the tubes a couple inches.
