Any thoughts on the two bearing/seal setups that came out of my Ford 9"? I was told that it has Alloy USA shafts but didn't see any indications or markings on them.
Obviously one of the races stayed in the housing, but I'm curious about the rest of the setup. It also has a retainer that is clearly not OEM.
The alloy USA shafts that I've see have their "alloy" logo engraved on the face of the flange. Does not mean they are not chromo, but likely not alloy USA.
The alloy USA shafts I just got had an aluminum logo plate stuck on the end which I promptly smashed pressing the bearings on. There was also no hole in the axle flange to access the retainer bolts. Not sure if they are all like that, but my scout shafts were and that appeared to match the photo on their site. That was the only thing that stood out as not oe style.
This looks like a repair axle bearing. If the axle is worn/damaged where the bearing rides, you can buy this style bearing where it transfers the load to a unworn part of the axle.
I'm not saying they are great but they do work for DD's
thats just a tapered 9" bearing assembly- the pressed ring is to keep the bearing from coming off the axle, just looks like two different mfg's.. that retainer ring is std type stuff for that bearing..
Got any stock shafts laying around? Take a file to a stock shaft and then to the shafts in question. If the new shafts are harder to file on then most likely they are an aftermarket shaft.
set 10 bearings usually have the smaller press on ring like the right and set 20 have the larger one like on the left but both fit on the same shaft just larger OD bearing.
While I'm sure I haven't seen all the iterations of the Set 10 shaft collars, the smaller of the two pictured still appears to be a fair bit larger than any of the 100's I've installed. I've also never seen one with that taper on one end either.
that race will pull off the other axle you posted, the one side just stuck in the housing.. ball bearing type will have a seal inside the bearing in the housing, tapered has the seal on the outside with the horseshoe retainer like you posted..
