Making a removable engine crossmember for my 83 dodge w150. When I did the ton swap the high steer ended up to close to the existing one.
I going to maintain the upper portions where the engine mounts currently sit. All I'm doing is replacing the portion spanning from the bottom of the engine mounts under the oil pan.
Question? How far from the bottom of the pan should I go? I'd like it to be about 1/2" but don't know if that is to close. I don't see there being that much movement in the rubber mounts.
This was in newbie and I know I missed Tuesday.
