Full float axle shaft flanges - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-25-2013, 05:02 PM   #1 (permalink)
Member # 226913
I read on a forum a while back stating the bolt flange to the hub on sterling 10.25/.5 axles is the same as the flange on the Dana 60, but I can't seem to find the forum or an answer on any forums, I was just wondering if anyone could confirm this? Maybe somebody with both these axles can snap a picture of the flanges with a measurement across from bolt hole to hole, or anything? Thanks in advance.
Flame suit on.
FSBronco is offline   Reply With Quote Quick reply to this message
Old 02-25-2013, 06:21 PM   #2 (permalink)
mj
Member # 1919
they look the same.
just held a ford d70u shaft to the flange of my 10.25.
mj is offline   Reply With Quote Quick reply to this message
Old 02-25-2013, 06:22 PM   #3 (permalink)
Member # 226913
Re: Full float axle shaft flanges
Originally Posted by mj View Post
they look the same.
Did you try to bolt it down?
Old 02-25-2013, 06:45 PM   #4 (permalink)
mj
Member # 1919
nope. not pulling a shaft from my daily driver to check.
I have some econoline rear brakes that are going on the sterling soon, will check the flanges then
like I said, they look the same.
did you try yukon catalogue to compare what
Old 02-25-2013, 06:53 PM   #5 (permalink)
Member # 226913
I tried but Yukon hasn't started producing shafts for sterling axles yet, thank you
Old 02-25-2013, 08:32 PM   #6 (permalink)
mj
Member # 1919
really?
Yukon axle shaft for F10.25 / F10.5, full float, Excusrion & F250, left hand. - YA F100008
Old 02-25-2013, 08:46 PM   #7 (permalink)
Member # 226913
First I've ever seen of those and I'm always looking for some
Old 02-25-2013, 08:56 PM   #8 (permalink)
Launch it
Georgia boy '88's Avatar
Member # 43592
Send a message via MSN to Georgia boy '88
Flame suit on.
I've got a 10.5 and 10.25 I can pull the measurement on this week, but you're on your own for 60 stuff.
94 xj-tons, stretched, caged... I should have built a buggy.
Georgia boy '88 is offline   Reply With Quote Quick reply to this message
Old 02-25-2013, 09:07 PM   #9 (permalink)
Member # 226913
Alright thank you,
Old 02-26-2013, 03:18 PM   #10 (permalink)
Launch it
Member # 43592
Alright thank you,
Sorry, but I didn't feel like digging into the 93 10.25 today, but did pull a shaft from the 01 10.5.
8bolt pattern of course and found my dial caliper more easily than my tape measure, so...
My attempted center of hole to center of hole was: 3.977" / 4"?
Outer diameter of flange: 4.765"
Outer flange thickness:
Inner flange diameter:
Total flange thickness:
Old 02-26-2013, 06:35 PM   #11 (permalink)
Member # 226913
Thank you very much
Old 02-26-2013, 07:32 PM   #12 (permalink)
mj
Member # 1919
dana stuff I have does not use the inner flange with O ring. my 10.25 does
I can duplicate those pics with a d70u axle or a durasolid 4340 in a few minutes
Old 02-26-2013, 07:40 PM   #13 (permalink)
Launch it
Member # 43592
From info I had found in the past, I think it is a unique sterling feature, that was why I included it in the measurements.
Old 02-26-2013, 09:03 PM   #14 (permalink)
Member # 226913
Oh yeah, I forgot about the o ring, I guess I'll have to just get custom shafts made, I was planning on running rcv double splined shafts with their Dana 60 drive flange if the measurements matched, guess I can't without the o ring
Old 02-27-2013, 10:55 AM   #15 (permalink)
Visa Master
Mutt's Avatar
Member # 8649
Just run RTV or the standard steel gasket instead of the o-ring .
Ford went with the o-ring same reason as the ratcheting rear spindle nut. Makes it easier for the dealer to deal with and to assemble on the line.
-Steve
43" Grooved SX's, H1's, Ori's, Ord Magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required...Muttlock guy
Mutt is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 02:16 PM   #16 (permalink)
Member # 226913
Alright
Old 02-27-2013, 09:16 PM   #17 (permalink)
Launch it
Member # 43592
I was wondering if that would work, since it is what other axles do. Not that it matters to me, not sure I can break a stock shaft with a worn out 4.0 and 40ish" tires.
Old 02-27-2013, 09:30 PM   #18 (permalink)
Member # 53528
unless youre my friend that breaks a 14b shaft with a 22re and 36" tires
Old 02-27-2013, 09:41 PM   #19 (permalink)
Launch it
Member # 43592
I mean, I'm the guy in my wheeling group that could break a steel ball in a rubber room... But my money is on breaking a 30 spline stub first once my 1ton swap is done.
Old 02-27-2013, 09:50 PM   #20 (permalink)
Member # 43587
Send a message via AIM to TBItoy
I wouldn't even waste time wheelin with stock 30 spline outers
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 02-27-2013, 10:47 PM   #21 (permalink)
Launch it
Member # 43592
While I want to agree, budget and deadline say, not yet. They should be upgraded before I step up from the nearly bald 38's I'll be running at first though.
Old 02-28-2013, 01:37 PM   #22 (permalink)
that guy
MAD MAC's Avatar
Member # 10887
Send a message via AIM to MAD MAC Send a message via Yahoo to MAD MAC
The Flanges are not the same they also use metric bolts and the diameters are metric
MAD MAC is offline   Reply With Quote Quick reply to this message
Old 02-28-2013, 02:40 PM   #23 (permalink)
Launch it
Member # 43592
How much would someone be looking at to have a set of flanges made, to run double spline shafts?
And I know the stock shafts are 35 spline, but are they the same as Dana 35 spline?
