Dodge Dana 60 Steering arm into Chevy question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2013, 08:40 AM   #1 (permalink)
Member # 269170
Howdy, I have a 1993 Dodge Dana 60 that I am putting into a 75 chevy truck.
I am wondering what to do with the steering arm.
Can I just drill / taper the Dodge hole to accept the Chevy end?
If so what degree taper?
If I swap in a chevy steering arm will I need the spacer & longer studs?
This truck is not lifted, so no need for fancy parts.
Thanks for helping me in advance.
Auctioneerhere is offline   Reply With Quote Quick reply to this message
Old 05-09-2013, 10:03 AM   #2 (permalink)
77k5's Avatar
Member # 35786
You can ream out the Dodge Dana 60 arm, the taper is 1.5"/ft. The Dodge steering arm also places the draglink hole in a different spot front/back, so you'd have to adjust length as well.
If it were me, I'd post up in the wanted section for a stock Chevy D60 steering arm. There are tons of guys that remove those when they switch to crossover steering, I bet you can get an arm cheaper than the reamer.
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
970-945-7777
77k5 is offline   Reply With Quote Quick reply to this message
Old 05-11-2013, 07:01 PM   #3 (permalink)
mj
Member # 1919
the shortened drag link will give you more bump steer.
I had the dodge stuff under a chev
mj is offline   Reply With Quote Quick reply to this message
Old 05-15-2013, 08:54 PM   #4 (permalink)
Member # 269170
I just bought a steering arm for a chevy off eBay.
My Chevy only has 2 leafs & the Dodge D60 spring plates jam into the 60 housing. Might have to add about a 1/2 inch to clear it or grind the case for some clearance.
I'm building a pulling truck, so I have no use for a thick leaf pack.
Old 05-17-2013, 08:59 PM   #5 (permalink)
Member # 269170
Well got the Dodge D60 in today. the fit was a little snug with the 5/8 u bolts I had made. Didn't realize the dodge cam w/ 9/16 u bolts.
For those who have done this swap, Did your front driveshaft work without modification?
Mine with a 4 speed & 205 is a whisker bit long now. Going to have to shorten it some.
