creeping hydro assist - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-14-2003, 07:03 PM   #1 (permalink)
Member # 12548
I joined the ranks of everyone running their homemade hydro assist steering. My YJ has a 5.0 and 37's. I couldn't turn the tires sitting still with the ford pump screaming at me so I did the ram. Kept the stock pump for now, will put saginaw pump later. Worked great! Now can steer with one finger!
I did notice something that didn't seem right. With the ram disconnected and the motor on. The ram would creep out to full extension with no steering wheel input. I thought there had to be strain on the system before the ram worked? Or just normal behaviour?
Would debris in the system cause this? Should I put in a cooler and filter just to be safe or is there another problem? I didn't notice the system getting hot or anything.
I did a search and found lots of stuff about over heating and such but not the problem I described.
Thoughts?
92 YJ Sahara grill.... And a pile of pipe.....with tires. One turd short of a pile of shit...
DamnJeep is offline   Reply With Quote Quick reply to this message
Old 05-14-2003, 11:54 PM   #2 (permalink)
Erik D_lux's Avatar
Member # 1007
I am not positive on this but I think that the ram would want to go either in or out when its not hooked up. I think there would be just enough pressure coming from the pump. I bet you could hold it back with your hands though so I wouldnt worry about it.
I would run a cooler since its so cheep, its good insurance.
Erik D_lux is offline   Reply With Quote Quick reply to this message
Old 05-15-2003, 07:12 AM   #3 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
AFAIK it shouldnt move as you described, seems maybee your orbital isnt shutting off the flow all the way.
and yes.. you need to run a cooler.
My mom wrote a kids book!
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote Quick reply to this message
Old 05-15-2003, 07:39 AM   #4 (permalink)
Member # 7444
I don't think that it is a serious problem.
Looks like there is a small amout of oil coming thru the valve.
On single ended cylinders if the pressure is the same at both ports the rod will extend.
I don't know if this cause a slight pull to one side when going straight.
hth
K.
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats."
-- H. L. Mencken
Keyster is offline   Reply With Quote Quick reply to this message
Old 05-15-2003, 08:32 AM   #5 (permalink)
Member # 14644
i'm not positive, but if i remember correctly, a properly installed ram(i.e. lines hooked up correctly) with the vehicle off the ground, the tires should drift to one side...if they don't, then the lines are likely crossed. i believe your system is fine.
greg
1986.5 Nissan crawler - dual cases, one tons, 42's
bignissan is offline   Reply With Quote Quick reply to this message
Old 05-15-2003, 08:49 AM   #6 (permalink)
Eric Ruhl's Avatar
Member # 37
It's fine. On a single-ended ram the piston area is larger on one side than the other (retraction side is smaller because the shaft reduces the piston area). So, with equal pressure on both sides of the piston it will extend.
Filter is up to you, but a cooler is HIGHLY recommended. Any tranny cooler will work.
Wheel the Rockies
Eric Ruhl is offline   Reply With Quote Quick reply to this message
Old 05-15-2003, 02:16 PM   #7 (permalink)
Member # 12548
Thanks!
Thanks guys! I will be putting a cooler on ASAP and guess I won't worry about the rest!
