6L intake questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2013, 05:43 PM   #1 (permalink)
SKOP's Avatar
Member # 109734
Question 6L intake questions
My question is
I currently have a 2008 LY6-6L out of a truck,I need to swap on a car intake but was wanting to know will an ls6 intake fit n is it the best option for me?
**TTC-2013**
Thx to my Sponsors:
-Western Canadian Rockwell
-NorthWest Fabworks
IG: @big_skop
SKOP is offline   Reply With Quote Quick reply to this message
Old 09-24-2013, 05:57 PM   #2 (permalink)
Bo185's Avatar
Member # 48545
No the LS6 will not work. You need an LS3/L99 intake. The LY6 is square intake ports like the LS3. The LS6 intake is cathedral ports and will not work.
'73 IH Scout II Vortec 6.0L 4L65e np241
'73 IH 1210 Travelette SV392 V8, T34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 09-24-2013, 06:12 PM   #3 (permalink)
SKOP's Avatar
Member # 109734
Ok thx for clearing that up I've been searching PBB for answers couldn't find anything
So the ls3/l99 intake would be the best Intake for my motor
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-24-2013, 06:22 PM   #4 (permalink)
Bo185's Avatar
Member # 48545
Best well it will work and is affordable. It will flow more than the truck intake on the top end, as for best. Well whats your budget?
A Fast 102mm square port intake is pretty good too!! Not cheap.
FAST LSXR 102mm LS3 Intake Manifold
Now you can get he LS3 one ported internal. Guy does it over on LS1tech. They have decent gains with the porting. But a stock LS3 one will work fine on a stock Ly6
Old 09-24-2013, 06:44 PM   #5 (permalink)
SKOP's Avatar
Member # 109734
Thx for the quick reply man
Much appreciated
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-24-2013, 08:57 PM   #6 (permalink)
Member # 1636
Like Bo said you need an L99 or LS3 with square port heads. They are the same intake between the two engines. I have an LS3 intake mounted backwards on my LY6. Check LS1 tech and Ebay they are for sale often for around $300-350. Get one with the rail and injectors so you don't need to spend extra money piecing that stuff together separately.
The truck throttle body will bolt right on. You can either use a truck MAP sensor with a second o-ring, or a car MAP sensor and change the connector on the harness. If you mount it forwards you'll need to trim around the upper water neck, and trim a piece off the truck accessory bracket if you are using it. If you mount it backwards like I did you need to cut the oil pressure switch off the valley cover and fill in the hole, and move some wires around on the harness, no big deal. There's lots of info on LS1tech.com
chris demartini is offline   Reply With Quote Quick reply to this message
Old 09-24-2013, 11:59 PM   #7 (permalink)
SKOP's Avatar
Member # 109734
Awesome thx man
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-25-2013, 01:26 PM   #8 (permalink)
SKOP's Avatar
Member # 109734
Anyone reading this have ls3 intake with injectors n fuel rails ??
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-25-2013, 01:50 PM   #9 (permalink)
Rocco's Avatar
Member # 4655
LS3 Intake Manifold | eBay
Roccworks Motorsports #308
Big Country Customs
Ruffstuff Specialties
Sharp-rite Tooling and mfg.
CrawlinBC.com
F-O-A
Amsoil
Dynomax
Rocco is offline   Reply With Quote Quick reply to this message
Old 09-25-2013, 02:16 PM   #10 (permalink)
SKOP's Avatar
Member # 109734
I read somewhere that the newer ls3 intakes won't work for me,was I misinformed ????
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-25-2013, 02:45 PM   #11 (permalink)
Member # 1636
Try calling places like Turnkey, Schwake, or CBM that might have some take-offs available.
Old 09-25-2013, 10:05 PM   #12 (permalink)
homeboy's Avatar
Member # 186874
look on ls1tech.com
I found my ls1 intake that came with everything for cheap.
homeboy is offline   Reply With Quote Quick reply to this message
Old 09-25-2013, 10:10 PM   #13 (permalink)
SKOP's Avatar
Member # 109734
Yah I made a PM already
But can someone answer my question. Above
Does a newer intake off a 2013 ls3 work for me ??
**TTC-2013**
Thx to my Sponsors:
-NorthWest Fabworks
IG: @big_skop
Old 09-26-2013, 05:12 AM   #14 (permalink)
Bo185's Avatar
Member # 48545
The 2013 will work as mentioned map sensors are differnet. The 2013 is no different than the earlier ones pretty much
