C6 bolt pattern and spline count - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-03-2003, 12:55 PM   #1 (permalink)
Member # 5718
Send a message via AIM to rockmutt
Is the bolt pattern on a C6 the round 6 bolt pattern, and 31 spine count on all years??? and will an atlas bolt directly to an ATLAS???????
Rockmutt--- 351, c6, atlas, Mog 404'z, 39 Iroks, All steer,18" Fox Air shock ect.......
rockmutt is offline   Reply With Quote Quick reply to this message
Old 08-03-2003, 01:36 PM   #2 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Hey hows it goin? Yes ALL Ford 4x4 transmissions had a 31 spline output shaft up untill ? year...but for your '78 or '79 it is 31 spline and I can check the pattern if you want But I think it's the round 6.
desertCJ is online now   Reply With Quote Quick reply to this message
Old 08-03-2003, 01:47 PM   #3 (permalink)
Member # 5718
hey man! we have decided to go with a C6 on the buggy rather than the granny box. the granny box had the round 6 bolt pattern, and if the ford C6 has a round 6 bolt pattern, and is a 31 spline, im home free. Then the atlas wont need an adapter.
Old 08-03-2003, 05:07 PM   #4 (permalink)
Member # 11497
The C-6 adapter to t-case has the round pattern if that is what your talking about. The C-6 to adapter pattern is not round.
SittonHigh is offline   Reply With Quote Quick reply to this message
Old 08-03-2003, 11:33 PM   #5 (permalink)
Member # 5718
so, in other words, i can take a t-case from a 4 speed, and put it onto a C6??
Old 08-04-2003, 08:11 AM   #6 (permalink)
Member # 11497
Yes, as long as you are swapping just the t-case and not the adapter. The only probelm you might have is if you are converting to a np205. The 205 adapter has a notch for the shifter linkage cut into it.
Old 08-04-2003, 11:25 AM   #7 (permalink)
payton's Avatar
Member # 11067
Send a message via AIM to payton Send a message via Yahoo to payton
most c6s for the small block has a 203.. simply grind a small section out. and go wif it.. ive got 2 of them.. the main difference is the long vs short out put.. thats the only difference..
as far as it bolting up to the atlas im not sure.. but its sumthing i wouldnt mind knowing my self..
payton
this space for sale
payton is offline   Reply With Quote Quick reply to this message
Old 08-04-2003, 12:27 PM   #8 (permalink)
Member # 11612
I was told by AA that there is no adaptor needed to use an Atlas w/ a ZF
I know the ZF has the same output (31) & rd. 6 bolt pattern as a C6.
So I am ASSuming that there would be no adaptor for the C6.
Franklin is offline   Reply With Quote Quick reply to this message
Old 08-04-2003, 02:29 PM   #9 (permalink)
Member # 15084
I have an Atlas behind a ZF and it came with a spacer. I think it is 1" thick. I got them to throw it in for free, otherwise it was $40 or something. I am about 95% sure the ZF pattern, depth, and spline count is the same as a C6.
SuperRanger is offline   Reply With Quote Quick reply to this message
