Gear pattern check - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2014, 11:07 PM   #1 (permalink)
Member # 85140
Gear pattern check
check my pattern? Sterling 10.5
These are 5.38 gears, arb carrier, B/L .008. Pinion bearings at proper preload, and carrier bearings preloaded so the carrier takes a bit of effort to remove. ( no case spreader provision, used super carrier shims so they can be hammered in tight)
Drive
Coast
shaggy10000 is offline   Reply With Quote Quick reply to this message
Old 03-30-2014, 06:35 AM   #2 (permalink)
87yj38's Avatar
Member # 14010
Send a message via AIM to 87yj38
It is a little deep. If it were me, I'd take out about 0.003-0.005" and re check the pattern.
You are pretty close but just a hair deep.
Beat up Ranger on stickies
87yj38 is offline   Reply With Quote Quick reply to this message
Old 03-30-2014, 08:02 AM   #3 (permalink)
AgitatedPancake's Avatar
Member # 42341
Yep, pinion is a little deep. Remove some shim and try it again
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 03-30-2014, 08:15 AM   #4 (permalink)
Member # 85140
Thanks guys. My last pattern was just a touch higher . I thought it was too high so I went to this. Added .005 I'll go back to that and repost pics
Old 03-30-2014, 08:49 PM   #5 (permalink)
Member # 85140
Took out .003
Drive
Coast
Old 03-30-2014, 08:54 PM   #6 (permalink)
Member # 42341
Still too deep. Sorry I'm not great with guessing how much, but I'd try a larger jump for this next one
Old 03-30-2014, 10:31 PM   #7 (permalink)
Member # 171926
Definitely still too deep.
What I like to do during my initial patterns is make pretty big changes at first, like .010" at a time until you see the pattern flop to the opposite extreme. If you notice the sharp, distinct line at the root of the pattern, that is what is telling us and you that the pattern is too deep. When you go far enough in the opposite extreme you will see that sharp, distinct line in the paint at the top of the tooth instead. As soon as the pattern jumps to showing that the pinion is too shallow, stop removing pinion shims. Going far enough to see the pattern shift to the opposite extreme (too shallow) will help you understand what you are looking for as far as the ideal pattern. Once it does, you know your pattern is somewhere in between your last .010" change and you can start making small changes back in the other direction.
[B][SIZE="4"]
[/SIZE][/B]
Instagram: @OMSMike
MO2500 is offline   Reply With Quote Quick reply to this message
Old 03-30-2014, 10:47 PM   #8 (permalink)
Member # 85140
Is it the sweeping toward the toe that indicates its too deep? More so than the actual depth of the pattern? Kind of a dumb question I guess on my part. Just trying to wrap my head around gear voodoo a little better
Tomorrow after work I'm gonna try and get another change in before I take my kid to softball. Ill have to shuffle the carrier as well to get the B/L back in spec.
I definitely appreciate your help
Old 03-30-2014, 10:53 PM   #9 (permalink)
Member # 42341
When I look at gear patterns, inside to outside movements of the pattern on the teeth play little role and usually fall into place when you get the other aspects of gear setup in place. When looking at pinion depth and trying to decide the next step, I see the pattern either frowning at me (deep), or smiling at me (shallow). If you look at the tip of the teeth as the "top", and the root as the "bottom", your patten has a flat bottom line, and a "frowning" upper cutoff line which represents a pattern too deep. If your pattern has a flat upper cutoff line, but a "smiling lower cutoff line (your pattern flipped upside down, top to bottom), it is too shallow. When you have a pattern dialed in, there isn't a distinct pattern with one flat line and one curved line, it becomes a soft oval.
This doesn't apply to used gears though, I hate working with used gears.
*edit* I just realized I just said what MO2500 said, oops! Well explained.
Old 03-30-2014, 10:57 PM   #10 (permalink)
Member # 85140
This answered my previous question. Thanks
Old 03-30-2014, 11:40 PM   #11 (permalink)
waynehartwig's Avatar
Member # 35700
Way too deep. I'd probably pull .020 just to see it move and make sure.
I hate being where I think you are right now. Making changes and not seeing anything positive. Chasing my tail for hours with nothing good to come of it. Anymore, when that happens, I make a huge change. Get that pinion so shallow the only way is deeper. For me, this is way faster for me and I can usually nail it in 1 or 2 more tries.
Hartwig Motorsports 4516, Team Yukon Gear and Axle
10% PIRATE COUPON CODE (not valid for harnesses and PCM tuning): pirate4x4
Special thanks to: My Family and Friends, Yukon Gear and Axle, DynoMAX Exhaust, AllTech Motorsports, Radflo Shocks, PAC Racing Springs, JM Rigging Supply, Reid Racing, Rugged Radios, Trail-Gear, Life-Time LED Lights, RuffStuff Specialties, Randy's Racing Transmissions, A1 Performance Converters, Maxxis Tires, Jesse Haines Fab, CBR Performance, PRP Seats, Exhaust Solutions, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote Quick reply to this message
Old 03-30-2014, 11:41 PM   #12 (permalink)
Member # 35700
Exactly lol
Old 03-31-2014, 10:24 PM   #13 (permalink)
Member # 85140
Ok I had exactly 40 minutes today to get another change in. So I made it count. Took out .015 which is exactly what was under the OEM pinion. I also moved carrier .010 closer to increase B/L since it was too far out. The drive is looking good and the coast is better, but the B/L is .004. So I'll open that up a touch tomorrow and see where the coast goes.
Thanks for bearing with me on this one. I've learned a lot so far
Coast
Drive
Old 04-01-2014, 12:20 PM   #14 (permalink)
Member # 35700
That's looking good... But unless your backlash is set correctly, checking the pattern is worthless. Each time you make a pinion depth change, you must reset the backlash to spec! If spec is calling for .006-.010, I usually run in the middle at .008.
.004 is way too tight... You run the chance of not only a noisy gear set, but also busting the head off the pinion
Old 04-01-2014, 01:30 PM   #15 (permalink)
Member # 85140
Thanks. I just ran out of time last night or I would have opened it up a little more. I was just a little impatient. More progress tonight
Old 04-01-2014, 01:33 PM   #16 (permalink)
Member # 35700
As long as you already know
Old 04-01-2014, 07:37 PM   #17 (permalink)
Member # 85140
I took your advise and moved the pinion a bunch. Sure enough the frown turned to a smile. Then I made small changes back until the edges feathered on the drive side.
The coast side has a faint line but any corrections there put my drive side slightly off.
I have to admit that I got confused on the order of the pics on those changes. So for now I'll leave those out of the mix. I marked #'s on these last ones so I know I got the right ones. I'm gonna go out on a limb here and call this good enough to run. I have no problem working it a little more if necessary though. Again thank you guys for your help on this.
B/L is .007
Drive side
Coast
Old 04-01-2014, 07:39 PM   #18 (permalink)
Member # 85140
FYI B/L spec says .006-.010
Old 04-02-2014, 04:13 AM   #19 (permalink)
Member # 81098
Run it !!!!
DanTech Motorsports is offline   Reply With Quote Quick reply to this message
Old 04-02-2014, 09:47 AM   #20 (permalink)
Member # 35700
Looks a little deep. I like a little deep
Old 04-02-2014, 09:58 AM   #21 (permalink)
Member # 85140
Guess that means Run It! LOL This is going in a trailer queen. It will probably never see more than 60mph
Old 04-02-2014, 10:42 AM   #22 (permalink)
Member # 21914
Run it. You got good advice and learned a lot. For what it's worth, most "good" aftermarket gears today should set up within +/- .005 of stock shim. This won't always be the case, but outside that range leads to a lot of gear returns as the average installer won't make the large shim changes needed to find the sweet spot, they try a few and send back as "won't set up".
Ron
CARBON Off Road
Racing Ron is offline   Reply With Quote Quick reply to this message
Old 04-02-2014, 11:54 AM   #23 (permalink)
Member # 85140
Ron
This is an understatement for sure. I did learn a lot and im grateful for the help
Its funny you mention being close to the old specs. THis one is damn near exactly the same as the old pattern. I just figured since i was going from a stock carrier to an ARB that i couldnt count on that.
Old 04-02-2014, 01:03 PM   #24 (permalink)
Member # 35700
Yeah, run the shit out of it! lol
I always start with the stock shim thicknesses. Regardless if I'm just doing a re-gear or changing carrier or even both. Sometimes it's not possible, but that is the exception to the rule.
I also always take a before pattern, if possible. See what the gears tell you before you even take it apart. Check the backlash and pinion preload as well. Learn everything from what your working on, then tear it down and clean it really well. It does take a little extra time to do this, but it sure makes for a quality setup when your done and less headache while working on it.
