Rancho u-bolt kit.......anyone.......anyone?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2001, 09:32 AM   #1 (permalink)
Member # 2685
I went to Checker's Auto Parts website and set my vehicle as an '82 k10. Searched around for ubolts and came across a rancho front u-bolt lift kit.......part# rs705 for 2.5-4" lift. $32.99
I've been all over the net looking for ubolts for the chevy 44 in my toy. None of the local stores carry them. So my question is didn't the k10's come stock with the ubolts flipped?? The plates should work on my toy, right??
Has anybody used this kit. That's pretty cheap if it's ubolts and plates. That's still not a bad price even if it's just u-bolt. Rancho's site didn't have anything on there about it.
Thanks
www.PoorBoys4wd.com
convertiyota is offline   Reply With Quote Quick reply to this message
Old 12-04-2001, 10:02 AM   #2 (permalink)
Whitewater's Avatar
Member # 89
Send a message via MSN to Whitewater Send a message via Yahoo to Whitewater
Only thing to really consider is spring width and axle tube size, what housing are you running? I made the mistake of using a U-Bolt that was a little too wide in the cup for the housing. The extra play ended up cracking the housing. That was a stock Toy rear end.
[SIZE="2"][COLOR="SeaGreen"]
"Having too many 'things', American's spend their hours and money on the couch searching for a soul. A strange species we are... If I wanted to destroy a nation, I would give it too much and I would have it on it's knees, miserable, greedy and sick." -John Steinbeck
[/SIZE][/COLOR]
Whitewater is offline   Reply With Quote Quick reply to this message
Old 12-04-2001, 10:12 AM   #3 (permalink)
RustoleumWhite's Avatar
Member # 4506
There are two kits (IIRC), the 705 and the 703.
The 705, like you found, is listed for the '78 and later trucks, normaly with a 10-bolt. However, it works for the HD D44's as well. 3" axle tube dia.
The 703 kit is listed for pre-'78, D44's. Same kit, but for 2-3/4" axle tubes. Measure your tubes and purchase apropreatly.
nice kits, 9/16" dia u-bolts, yellow-cad plated, with washers and nylock-nuts, and some cheasy aluminum shims.
No spring plates. If you find a source for the GM cast style for cheap, please let me know.
good luck
-mark
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 12-04-2001, 10:16 AM   #4 (permalink)
Member # 2685
good luck
-mark
That's the info I was looking for. Thanks a lot.
Is the 3" tubes the only thing that makes a 44 a HD44??
www.PoorBoys4wd.com
Old 12-04-2001, 11:40 AM   #5 (permalink)
Member # 192
Most are 8 lug.
brector is offline   Reply With Quote Quick reply to this message
Old 12-04-2001, 11:55 AM   #6 (permalink)
Member # 2685
Originally posted by brector
Most are 8 lug.
Most or all??
www.PoorBoys4wd.com
Old 12-04-2001, 11:57 AM   #7 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Most or all??
all.
FYI - check for a spring shop local to you, you may be surprised how cheap custom U bolts in any shape or size you want can be
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
