DIY Pre-luber?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2003, 06:06 AM   #1 (permalink)
Member # 12101
DIY Pre-luber??
$600 seems a little steep for one of these systems, but I like the idea. Does anyone know what type of pump they are using? (http://preluber.com). Maybe a pump like this is available for less than the $350 they are offering it for by itself...
I have a motor that's been sitting for several years, and I don't want to crank it over without oil pressure....any ideas?
Thanks for any help
Ed in Oregon
85 4Runner 2.5L turbo diesel
35's, electric lockers, etc..
dieseltoy is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 07:03 AM   #2 (permalink)
Member # 12498
Dieseltoy,
If the engine has a distributor driven oil pump, just remove the distributor and drive the pump with an pneumatic or electric drill. If that is not the case, drain the oil (you will want to do this anyway) and use a pressure can refill the crankcase from the oil pressure sender fitting. I would change the oil filter also and fill it with oil prior to installing. When you start the engine every thing will be well oiled and the pressure will come up quickly.
mywillie is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 09:13 AM   #3 (permalink)
Member # 2242
You can use a Moroso oil accumulator as a pre-luber.
Harry Wagner
Freelance 4WD Writing & Photography
Vehicle Features, Tech, & Trail Reports
Dirty Harry is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 09:56 AM   #4 (permalink)
Member # 1176
Buy it direct $ 168
http://www.enginegearonline.com/item...5&PRID=1009965
Many oild burners pre lube and that the reason an engine will last so long. Most wear on gas or diesel is at the startup
I want to put one on my 2F landcruiser motor.
June 28th 2003
Berg is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 02:18 PM   #5 (permalink)
Member # 6848
Does it go through the oil filter outlet? Seems like if you combine it with a remote filter you'd have a pretty good setup. Put it on a manual switch and when you are going up or down nasty inclines and your oil pressure drops, just flip the switch.
Think that would work? If it did, it seems like it'd be pretty easy!
Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 02:21 PM   #6 (permalink)
Member # 1176
Jack
Locate your oil sender
Remove oil sender
Install adapter tee
Replace oil sender
June 28th 2003
Old 08-19-2003, 02:38 PM   #7 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Remove oil sender
Install adapter tee
Replace oil sender
You want to pump all that oil thru a 1/4" fitting?
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 08-19-2003, 02:45 PM   #8 (permalink)
Member # 1176
3 gal per minute maximum on the pump.. just need it on long enough to pressurize the oil system.. maybe 10-15 seconds to show 60 psi before you start. Not a bad way to go IMO.
June 28th 2003
Old 08-19-2003, 04:38 PM   #9 (permalink)
Member # 12101
Thanks for the link. It also keeps oil pressure up when the sump tube is sucking air. this would be helpfull in extreme angle conditions.....the pre-luber draws from the oil pan, so it would not work as well in this situation.
$180 shipped from summit or jeg's.
the only thing it seems to lack over the pre-luber is the ability to pump out all your oil for easy oil changes.
With a solenoid activated valve, you could prelube every time you start the motor. (it gains pressure while the motor is running, then a check valve is activated. then on startup, check valve is released)
AW crap. get em both! ;-D
Old 09-06-2003, 09:07 PM   #10 (permalink)
Member # 12101
Jack
I tried the Moroso oil accumulator, but does not work so well as a pre-;uber, since the motor needs to be running in order to build pressure (or you have to "air it up"). Also, a solenoid activated valve to close it off after pressure is formed by the engine, then released for starting later....
So, I bought the 12v pump from engine gear ($189-I guess they must have raised prices shortly before my order).
Now that I am about to hook it up, I can see what you meant by having a filter. As a pre-luber, these are usually hooked up between the oil drain plug and a sender "T", with a check-valve before the "T" to keep oil pressure from forcing oil back through the pump after the motor is started.
Problem: this would bypass the oil filter, and pump oil directly from your pan into your oil journals - bad idea. There needs to be a filter between the pan and the pre-luber pump.
I don't think a regular remote mount, full sized oil filter is required, just some in-line sort of thing, kind of like a fuel filter.. any ideas?
Thanks!
Ed
Old 09-07-2003, 01:08 AM   #11 (permalink)
Member # 22456
Just try running a synthetic oil or lucas oil in the mix. The Lucas and synthetics stay stuck to everything and prevent alot of startup wear. They also almost prevent thermal breakdown. I once read a story of a guy who was running Pikes peak in some kind of a purpose built race car. He lost oil pressure at the bottom of the track and decided to run the hill with on oil. Since he was running Mobil 1 in his car he made it to the top like it had oil the entire time. later the motor was dissasembles and there was no abnormal wear.
SJ410Rocker is offline   Reply With Quote Quick reply to this message
