RSG 6 speed for 4x4 Trucks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2014, 07:18 PM   #1 (permalink)
Member # 435138
Found this on google and there website said
"Rockland Standard Gear is making available a Tremec T56 6 speed transmission for 4 wheel drive pickup trucks.
These units will have transmission ratios of 2.97 1st, 2.06 2nd, 1.43 3rd, 1-1 4th, 0.80 5th, 0.62 6th, for great performance and gas saving highway use. All gear train is Corvette T56 with triple cone 1-2 synchronizers and double cone 3-4-5/6 synchronizers with carbon fiber synchro rings throughout.
These units will accept Chevy, Ford and Dodge transfer cases with 5 and 6 bolt flanges. Available with 27 or 32 spline out put shafts.
Measurements- 27.5" from back of block to back of rear adaptor (1/2") longer than GM or Dodge 3500 trans) 19" from back of block to shifter (2") longer than GM or Dodge 3500 trans."
When do these come out or has any one got one yet?
REVSH*TRyan is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 07:32 PM   #2 (permalink)
Member # 133589
Well the 2.97 is a joke ratio for first gear. way easier/cheaper to find a junkyard truck transmission.
lie and get by, or comply and die........
mvanhelden is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 08:06 PM   #3 (permalink)
Member # 435138
I m just looking in to it just to see if anyone is playing around with one. With 6th gear at .62 you could run something like 4.88 with 33s to off set the low first. Any thing over 5 speeds never really made to much sense to me. More gears equals more parts higher probability for failure. I ll never do it but if I won the lotto or made decent money I d mess around with one.
Old 04-25-2014, 08:08 PM   #4 (permalink)
Member # 53528
https://www.pirate4x4.com/forum/gener...rans-ever.html
Old 04-25-2014, 08:28 PM   #5 (permalink)
Member # 13970
wasn't there a hgtd burban tractor guy gunna do some 6 spd manual torque converter thingy here on Tuesday? bet he knows.
bottom_dweller is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 08:33 PM   #6 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
NV5600 Gear Ratios:
RANGE RATIO
1ST 5.63
2ND 3.38
3RD 2.04
4TH 1.39
5TH 1.00
6TH 0.73
REVERSE 5.63
I'd rather adjust gear and tire size for the 0.73 sixth than the 2.97 first...
’94 GMC 6.5TD K1500 Yukon SLE / ’93 Chevy 6.5TD K2500
’85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 08:43 PM   #7 (permalink)
Ho Shorts's Avatar
Member # 109328
The T56 is a garbage trans in the vette, why would anyone want to put it in a truck?!?
I have one tore apart at the shop right now with a busted reverse gear and 5th 6th synchro bad. Came out of a car with 27,000 miles
I had a clogged sewer pipe. After cutting the pipe, reaching in past my elbow, and removing the obstruction; about 12lbs of shit started flowing. Bits of corn and peanuts washed over my neck, down my shirt, some even got in my mouth.
It was still a better experience than buying from Ballistic Fab
Ho Shorts is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 08:47 PM   #8 (permalink)
Member # 11921
I have a tow rig application where the NV5600/ZF-6 doesn't physically fit. I think the T56 would physically fit much better and the 32 spline Chevy output is sweet.
I would have to go from 4.10s to 4.88s to maintain my stock 0.75 OD. but that might be cheaper and easier than re-doing my entire floorpan to fit a ZF-6. Plus, gives me an excuse to do a front locker.
Towing, a six speed makes plenty of sense, 7-9 speeds would be better.
My build thread:
ramv is offline   Reply With Quote Quick reply to this message
Old 04-25-2014, 08:50 PM   #9 (permalink)
Member # 53528
for trail riding the lower first gear would be good, for ultra4 go fast i would think the 1st being numerically closer to second gear would be better.
also with low gears in the transfer case you dont really need the low first, i prefer the higher 1st gear ratio in my r151/r150 hybrid toy tranny vs my previous r151 tranny, going from 1st to second feels better.
im not an ultra4 racer though i just pretend to be one with a gutless 4banger so take it for what it is
Old 04-25-2014, 08:53 PM   #10 (permalink)
Member # 53528
x2 i just swapped in an nv4500 into my 1st gen cummins a few months ago and im really wishing i would have spent the extra 1k$ and went with a nv5600, towing a heavy load up a steep grade going from second to 3rd and then 3rd to 4th sucks.
Old 04-26-2014, 07:41 PM   #11 (permalink)
Member # 11921
That's my problem now. 4 spd auto with fairly tight spacing. I don't miss a low first (I have 4 lo if I need it) but the gaps are too big.
My build thread:
Old 04-26-2014, 07:44 PM   #12 (permalink)
Member # 53528
im gonna turn the pump up a bit and put a 3200 gov spring in to help, but yea should have went 6spd
Old 04-26-2014, 09:39 PM   #13 (permalink)
107096's Avatar
Member # 107096
Did he really? What a chump
107096 is offline   Reply With Quote Quick reply to this message
