Raising The Gavel- Jason Scherer's new #76 Build Thread - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2014, 05:51 PM   #76 (permalink)
ISDTBower's Avatar
Member # 94026
It has been pretty enlightening hanging around the shop as the build continues. Yes, there were drawings, from detailed (IFS) to a rough frame with seats, rear links, etc. But, as you will see there is a lot of in-process scoping from the builders and crew to get it right. Work, back-off, work, back-off, etc. What you might also see is the relatively simple ways that the parts are put into place. What you are not seeing are the bending, coping, cut-off, and other special tools that keep the tolerances tight. Plus the Masterfabber to adapt from the drawings the small changes.
Here, is about Mid March, as parts start to be positioned in-place and should encourage "above normal" builders that they could really do it "at home." Today it is non-photogenic as it looks like meatballs and spaghetti with out the sauce and parmigiana. The story and recent pics are being created and I do hear some roller/dyno scheduling dates being thrown around so...
I think that it should also be said that Jason and Dan have "builit" several winning cars, and know where they are going with this build. In the early years of KOH Jason would build, race/test, and come home to cut out what they had built the weekend before. Many of his rigs had multiple re-works, looking for learning and perfection. J's comment about more scrub to search for traction when stuck in the rocks, is learning from previous (crawler) builds, and maybe not needing 0 scrub in the fast, as was thought. " Intended compromises."
ISDTBower is offline   Reply With Quote Quick reply to this message
Old 05-16-2014, 05:57 PM   #77 (permalink)
ISDTBower's Avatar
Member # 94026
A few more.
Old 05-16-2014, 08:45 PM   #78 (permalink)
ISDTBower's Avatar
Member # 94026
Originally Posted by DOUG38S View Post
J why the change in design of the uniball to what looks like a stud?
To try to keep J in the shop and our cameras have been banned, I will try to answer. Actually Dallas or Tim should. They had to work extra hard to get the geometry to work with the uniballs. The top uniball actually covers over the fastener at full articulation. But, I believe the short answer is turning. There wasn't a way to get the turning that this design is capable of with vertical balls.
On desert cars, where turning is minimal and articulation is the greatest, they probably prefer vertical omniballs for more strength and best wear. When the race leaves the ball at the flats, it accumulates crud and wears quickly.
Full load on the front end at full lock and articulation doesn't happen that often...Hopefully. Horizontal balls are now common on the top to get good geometry with a reasonable upright design. It is the lower uniball that gets re-oriented depending on steering. (As I see it)
Can't wait to see Loren's build also!!!! It is interesting that the top teams seem to be using the pro's to design the 4X4 IFS geometry and parts. I tried to do it myself, and I am now on Dallas' list.
Old 05-16-2014, 09:25 PM   #79 (permalink)
AgitatedPancake's Avatar
Member # 42341
Sitting beside the transmission, now that's what I'm talking about! I like what I'm seeing here, and as always Trout's fab is second to none
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 05-17-2014, 04:49 AM   #80 (permalink)
Member # 152591
Loren has some awesome pics up on facebook of the new car.
Losing House...Still got the Jeep
CO80jeep is offline   Reply With Quote Quick reply to this message
Old 05-17-2014, 06:58 AM   #81 (permalink)
ON THE RCKS's Avatar
Member # 23617
Doug, the limiting factor in my last car was the uniballs / amount of misalignment. Figure about 32' of angle for those, then cycle the suspension and find out that if you have to limit those almost 5 degrees with the Ackerman and bump steer and you have a whopping 27' of steering. When we finally bought the rezeppa style outer 30 series cv's from RCV we found they turned 45' stock. So the new design was based around maximizing the steering while still having the same or more travel. It's looking awesome but it's a lot more work to get a arm clearance, strength and geometry than just traditional arms.
Jason Scherer
Rage 4th - "I just want to go fast"
ON THE RCKS is offline   Reply With Quote Quick reply to this message
Old 05-18-2014, 07:51 PM   #82 (permalink)
BigWoodyWag's Avatar
Member # 26468
Send a message via AIM to BigWoodyWag
Gen2 4wd IFS I love it!!!
Keep pushing the envelope J, the rest of us are soaking up your coattails like Krazy MOFO's!
#555 Triple Nickel Racing, & TGTW Lemons Racing
Build Thread
BigWoodyWag is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 06:00 AM   #83 (permalink)
Member # 134887
That aged beard is awesome, much respect
Team Lock n load
Aussie Rock Crawling
ethann is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 06:09 AM   #84 (permalink)
Member # 151204
Feel lucky to see the much reclusive Ole! Greatest guy ever!
Tribe4x4 is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 08:05 AM   #85 (permalink)
Member # 6576
That beard isn't even that old.... he had to start over again a couple years ago after a power tool incident
Brian Whitford
4554 OCD Racing
Rage 4th............ "safety is our #2 concern"
1uglyranger is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 09:07 AM   #86 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
The bartender only serves brown liquor in hell, and that sure sounds like heaven to me.
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 09:11 AM   #87 (permalink)
Member # 3007
That's a Brolex
Bones is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 09:47 AM   #88 (permalink)
rockslammer84's Avatar
Member # 218479
awesome build i cant wait to see how it turns out, ive always been on the fence about the ifs cars but after reading through a few build threads on here im becoming a believer. i sure hope one day i can build at a caliper close to that of this build.
rockslammer84 is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 10:30 AM   #89 (permalink)
Member # 23617
More pics and Part 3 of the series is up and running. We've been having a few issues fight us but the solutions are pretty solid...loving the way it's coming out.
Fingers crossed we can fire this motor off Wednesday night and get on the dyno Saturday to get it tuned...then it's off to testing and testing and testing.
We have a few items we are trying that might not work...and we know it...but we have to try. If they don't work we've got some late nights to get ready for Stampede but if they do it's going to be a cool setup. One of them is the severe angle from the trans to the t-case. The angles will cancel but the joints will work pretty hard. If they get hotter than about 200 degrees we have to move the t-case....the dyno runs should tell us
DrivingLine | The Clock Keeps Ticking – Part 3 of Jason Scherer’s Innovative New ULTRA4 Car
Jason Scherer
Old 05-22-2014, 08:19 AM   #90 (permalink)
Member # 1597
Send a message via Yahoo to BigRob
The build is looking badass! I love seeing builds like this come out of NorCal and for someone i know. Jason way to pick a bitchin group of individuals who all think outside the box!! TSP... I can't wait for Stampede.
Rock Zombie
That's too bad about your feelings, now make me another cocktail
Originally Posted by Gunmetalcruz
I have broken so many parts in the last decade. Did I beat it, yes every time I turned the key. Parts brake when racing this witch hunt is gay.
BigRob is offline   Reply With Quote Quick reply to this message
Old 05-22-2014, 10:16 AM   #91 (permalink)
Member # 75114
last night was productive.
keeptahoewhite is offline   Reply With Quote Quick reply to this message
Old 05-22-2014, 11:00 AM   #92 (permalink)
Member # 14882
whats special about 200 degrees for ujoint temp? grease or seals? if you're interested I know a grease guy there in southern California that makes grease all day that lives at 200 and above. i'll get you his info if interested.
great looking build, thanks for sharing on pirate!
blay127 is offline   Reply With Quote Quick reply to this message
Old 05-22-2014, 11:06 AM   #93 (permalink)
Race Radio Vendor
RuggedRadios's Avatar
Member # 122268
pics or it didnt happen!
Haha I joke. Can't wait for the next update!!
Rugged Radios
(888) 541-7223
Forum members receive 10% off retail! Use coupon code PIRATE10
RuggedRadios is offline   Reply With Quote Quick reply to this message
Old 05-22-2014, 11:53 AM   #94 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
Originally Posted by RuggedRadios View Post
Video or it didnt happen!
Im thinking this is what you want!
Bunk is offline   Reply With Quote Quick reply to this message
Old 05-22-2014, 03:34 PM   #95 (permalink)
Member # 151204
I heard it took a breath of life yesterday!
Old 05-22-2014, 03:52 PM   #96 (permalink)
Race Radio Vendor
Member # 122268
Originally Posted by Bunk View Post
video or it didnt happen!
Not at first....
Then this was said... so YES VIDEO!
Rugged Radios
(888) 541-7223
Old 05-22-2014, 04:43 PM   #97 (permalink)
Member # 23617
You know that's a good question...I think the number was thrown out there.
What it needs is a good 45 minute WFO session and then full inspection. Maybe do a 15 minute run first and check to make sure it's not melting the seals and rollers out first but you are spot on, the temp is arbitrary, its the damage that occurs if it gets to that unknown temp. Either way it's something we need to go test and that should be able to happen in about 8 days!
Jason Scherer
Old 05-22-2014, 04:47 PM   #98 (permalink)
Member # 23617
Yesterday was awesome...everyone pitched in and we got a ton of little lose ends done and fired it off. It was pretty awesome to see it fire on the first push, then it took a little throttle as the TPS either needs a little tuning or I need to throw a hole in the butterfly but either way it runs perfect and everything looks great....oh and it sounds Angry
Jason Scherer
Old 05-22-2014, 04:48 PM   #99 (permalink)
Member # 75114
I wouldn't be the first one to post it...
Old 05-22-2014, 10:03 PM   #100 (permalink)
ISDTBower's Avatar
Member # 94026
I got an OK.......For the Cool Pirate guys.
Great evening guys! J SPARED the neighbors from a 10PM ear splitting. I am sure it will sound different on the DYNO!
Car looked small until J got in! Now, all the rest!
Gavel Startup - YouTube
