How do I get stronger power steering? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-05-2001, 11:17 PM   #1 (permalink)
Member # 848
I just found out my Bronco II steering gear interchanges with tons of stuff up to F-350 Super Doo Doo's. So I've appearantly got a good steering gear. Will a better pump increase the power? or is it a limitation of stock ford steering gears?
SNOWTREK.org
Nobody is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 12:30 AM   #2 (permalink)
Member # 1408
Send a message via AIM to RockRanger
So are the bigger boxes stronger bolt in ones then? Mine is taking a crap so I am planning on replacing it. So if I get one for say a 90 f350 it will be a stonger box? Will it use my same pitman arm?
Matt
93 Ranger on 37"s
RockRanger is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 08:22 AM   #3 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I'm not sure exactly what you mean by "power", but I do knwo that if you put a smaller pulley on the pump that you can increase your gallons/minute. I can't remember if this will just make it turns faster, or stronger, or both.
J. J.
Old 12-06-2001, 08:51 AM   #4 (permalink)
Member # 5982
Try this link
http://www.off-road.com/~jweed/pwrstr.htm
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 09:09 AM   #5 (permalink)
Member # 848
Matt
They are the exact same box up till 97 or something. I just always assumed I had a light duty steering gear and pump. When I found out the steering gear was used in the super doo doo's I began wondering why my PS sucked so bad. According to the link below, the pump is the limiting factor. Pitman arms will most likely be different, but that's no big deal.
jdjanda thanks for the link. I think Ill try that out. Will this mod shorten the life of the pump?
SNOWTREK.org
Old 12-06-2001, 11:43 AM   #6 (permalink)
welndmn's Avatar
Member # 398
you can't do that to a Ford Box though, your best bet is to just swap a Sag pump on there, they work about 100x better then a ford pump
Mark
Old 12-06-2001, 11:54 AM   #7 (permalink)
Member # 595
Nobody pumps are cheap you know where put a sag pump on it made mine about 3x better. I have not bumped the spring yet .
There is a shop in Everett by L.O.W.E.S. ( less of what eagle sold ) I can't remember the name but it is rite there between them and Everett industrial they made my high pressure hose for under $20.
1967 Bronco for sale $13,000 in classifieds
Injected 5L, Dana 60, ARB, Swampers, Hydroboost
EBSTEVE is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 06:54 PM   #8 (permalink)
Member # 848
Someone's always gotta piss in my cheerios
SNOWTREK.org
Old 12-06-2001, 06:55 PM   #9 (permalink)
Member # 848
Uhhh where?
Think my stock hose won't hold up?
SNOWTREK.org
Old 12-06-2001, 07:22 PM   #10 (permalink)
Member # 4406
...L.O.W.E.S. ( less of what eagle sold ) ...
Nice. Its usually refered to as BLowes around our house, though. Geez that place sucks now. Still not as bad as the big orange place, though.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 08:54 PM   #11 (permalink)
Member # 848
Lowes sucks big time. Every once in awhile, I have a relapse and go in there. Everytime, I quickly remember why I vowed never to go in that place again. They fawking suck!
Less Of What Eagle Sold for sure. They cut their inventory by over 50%, and are always out of stock of the remaining inventory. Fired all the decent help, and have 1 fucking moron working a register so the line is a mile fucking long.
And to top it off, they got rid of the hotdog stand outside.
FUCK LOWES!!
SNOWTREK.org
Old 12-06-2001, 10:27 PM   #12 (permalink)
Member # 595
Originally posted by Nobody
Uhhh where?
It might not fit
Old 12-06-2001, 10:33 PM   #13 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Is there a Saginaw pump that will fit the Ford aluminum bracket and will take the Ford serpentine pulley?
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 12-06-2001, 10:48 PM   #14 (permalink)
Member # 4073
Look for the bracket and Sag pump off a Ford van with the same engine as yours.
Dustin S.
I had a brain-eating disease that died of starvation.
Dustball is offline   Reply With Quote Quick reply to this message
Old 12-07-2001, 10:25 AM   #15 (permalink)
Member # 595
Yes and I am not sure. I modified an aluminum bracket to get the sag pump to fit and there are a ton of the pumps around that have the serpentine setup on them already.
