The rebuild of our 2005 Jeep Rubicon - Page 14 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2016, 06:48 PM   #326 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
An easy solution can be if you put the Hot side on the bottom of one side and the out/cool side to diagonally on the top fitting. My coolers are the same. No plate but has 4 fittings.
Offroad Design ♦ Atomic MC ♦ Jantz Engineering
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 02-22-2016, 06:46 PM   #327 (permalink)
Member # 115832
I will move the lines this weekend. I also took the radiator to CBR on Friday and they are going to cut off one of the end tanks and add a heat exchanger and also add an -16 an fitting for the upper coolant hose and a -20 an fitting for the bottom coolant hose and -10 an fittings for the oil lines.
RallyeX is offline   Reply With Quote Quick reply to this message
Old 02-23-2016, 07:54 AM   #328 (permalink)
Member # 29113
Send a message via Yahoo to pitchitpitchit
What is the stall of your torque conveter? A high stall will be harder to keep cool but better power off the line. Also does it have a lockup? If you continue to have heat problems this is something to play with.
pitchitpitchit is offline   Reply With Quote Quick reply to this message
Old 03-05-2016, 03:20 PM   #329 (permalink)
Member # 115832
Had CBR remove one of the end tanks on the radiator and add a heat exchanger with AN fittings and also add a -16 an fitting for the the top coolant hose and a -20 an for the bottom hose. I couldn't get the original hoses to stop leaking.Also bought a new water pump and installed a upper hose an fitting, -20 an thermostat housing and added a restricter plate . Also picked up a few misc items at Kar-Tech. Also had to get another set of plug wires.
Also moved the lines on the remote coolers to there correct location. It was plumbed so both lines in/out where on the same side. Moved it so it goes in on the bottom on 1 side and out the top on the other side. That should be good for about a 15 degree drop in temp.
Old 03-15-2016, 08:41 PM   #330 (permalink)
Member # 115832
Got the pully today to replace the A/C. Working on the coolant plumbing, rearranging the wiring in the cab,moving the intake to under the dash, moving the VHF radio and intercom, have to replumb the tranny lines, new hood pins, spare lug nut carrier, lap belt quick connects and some new plug wires.
Old 03-16-2016, 07:30 AM   #331 (permalink)
Member # 481234
Must've been a "selfie" stick you used.
[QUOTE=DirtRoads;44405898]All you need to go wheeling is a credit score these days[/QUOTE]
Juicysluice is offline   Reply With Quote Quick reply to this message
Old 03-19-2016, 08:55 PM   #332 (permalink)
Member # 115832
Working on plumbing the radiator. -16an on top hose and -20an for the lower hose.
Old 03-29-2016, 01:45 PM   #333 (permalink)
reklund5's Avatar
Member # 27179
Send a message via AIM to reklund5
Why are you ditching the AC and Heater?
reklund5 is offline   Reply With Quote Quick reply to this message
Old 03-29-2016, 07:12 PM   #334 (permalink)
Member # 115832
After 11 days at KOH I don't think it will hold up so I removed it so I can sell it before it gets to fucked up. Now I have the room so I moved the air filter to under the dash. Should have it up and running in the next week or 2.
Old 05-07-2016, 10:40 PM   #335 (permalink)
Member # 202773
Any updates on your jeep?
DannyP is offline   Reply With Quote Quick reply to this message
Old 06-02-2016, 12:29 PM   #336 (permalink)
Member # 125646
Whats going on with this thing. Need some motivation.
usethis is offline   Reply With Quote Quick reply to this message
Old 06-03-2016, 11:03 AM   #337 (permalink)
Member # 115832
I got it all back together and running last weekend. The only problem is it's back firing. Runs good at idle but back fires after a couple of minutes of driving. So I have to check fuel pressure while driving, coils,plug wires,plugs,plug gap, header temp ( all tubes should be with in 50dg of each other). I have been working 6 days a week so haven't had time for the Jeep. Now I'm mostly working 4 12s.
Old 06-17-2016, 06:59 AM   #338 (permalink)
mcutler1's Avatar
Member # 167368
Anymore discovery of the use of sharkhide over mavcoat? Looking for best protection of bare chassis for my new project.
Love this build btw
Matt
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 10-05-2016, 07:20 PM   #339 (permalink)
Member # 125646
Checking in on this awesome build. Is it running?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 10-06-2016, 10:37 AM   #340 (permalink)
ISDTBower's Avatar
Member # 94026
They had the rig at Offroad Expo in Pomona last weekend. Looked awesome. They have more plans for plug-in onboard air and to shift weight back for KOH 2017. I know they have been wheel'in it.
You couldn't walk past it without seeing something you wanted to do to yours.
ISDTBower is offline   Reply With Quote Quick reply to this message
Old 10-06-2016, 08:44 PM   #341 (permalink)
Member # 115832
It's coming along. Finally got the rear shock springs swapped out. Need to go shock tune soon. I am also moving the engine and trans coolers to the roof right above the spare tire.
Old 01-25-2017, 02:30 PM   #342 (permalink)
Member # 166453
bump for updates
NoTraffic is offline   Reply With Quote Quick reply to this message
Old 07-27-2017, 07:45 PM   #343 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
Updates?
TRAIL WORTHY FAB
| 316.337.5311
Old 09-27-2018, 05:47 PM   #344 (permalink)
SKT
Member # 123745
Any updates or fresh pics?
SKT is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 08:55 AM   #345 (permalink)
Member # 502649
Updates? Gotta be one of my favorite Jeep builds on here!
Twmdodge99 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 09:09 AM   #346 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
https://www.pirate4x4.com/forum/vehi...p-rubicon.html
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 06-07-2019, 06:05 AM   #347 (permalink)
Member # 502649
wonder if it sold? thatís the thing with these ridiculous builds, hard to get a buyer.
