Improved Racing Baffling System - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-03-2014, 01:14 AM   #1 (permalink)
Member # 100323
Knuckle Busters Racing is looking forward to participating in some of the most competitive offroad desert and rock crawl races in the nation. With great anticipation we look forward to flogging our car properly so we looked to Improved Racing to improve our oil delivery system.
After a very quick and basic install we noticed that the F body oil pan that they supplied us has definitely given us an advantage. The increased clearance that the pan allows us is vital to our success in the rock crawling sections of our endurance races.
As far as the baffling system, it works flawlessly. We no longer experience a decrease in oil pressure like we did before. We're able to work some of the gnarliest waterfalls and huge sweeping turns with out having to back off because of decreased oil pressure.
If you are into racing like we are and are running an LS Based engine. You can trust that Improved Racing can help deliver that extra edge that you need to stay competitive.
Improved Racing | GM LS Parts, Oil Pan Baffles, Thermostats, Intakes, Performance Oiling & Suspension
-Israel Estares
ijestares is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 07:39 AM   #2 (permalink)
Hosejockey's Avatar
Member # 26577
ok
Hosejockey is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 08:18 AM   #3 (permalink)
matzell's Avatar
Member # 42081
yellow star?
Rob Matzell
2014 4WD EASTERN 4500 CLASS CHAMPION
EMC 2013,14, 15, 16, 17
Matzell Motorsports #4573
Thanks to: Weldone Fabrication, Maxxis, Fox, PRP, PSC, Raceline, Reid Racing, Ruffstuff, Willow Lawn Service Center, JB Custom Fab, Yukon Gear, Dynomax, 150tunes.com,Lugnut4x4
matzell is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 09:08 AM   #4 (permalink)
Member # 11985
been looking at this one. Baffled Racing Oil Pan for LS1 Camaro / Firebird (F-Body) EGM-408
anyone have experience with it?
fawk this, let's go wheelin
M&M Offroad triple threat chassis #27
1TFROT is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 05:42 PM   #5 (permalink)
homeboy's Avatar
Member # 186874
I run one with my f body pan but over fill a quart to keep oil pressure on steeper climbs. if you got room get a oil accumulator. I'll be adding one eventually to my system.
homeboy is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 06:11 PM   #6 (permalink)
Member # 1636
I've got one in my new build and ran one in my old buggy. They're good enough if you already have an F-body pan that you got cheap. Definitely 100x better than without.
If you need the pan also, it's cheaper to get the Mast pan with built-in baffle from Wide Open Design
chris demartini is offline   Reply With Quote Quick reply to this message
Old 08-03-2014, 06:12 PM   #7 (permalink)
Member # 1636
I've got one in my new build and ran one in my old buggy. They are a necessity if you're running an F-body pan.
If you need to buy the pan also, it's cheaper to get the Mast pan with built-in baffle from Wide Open Design.
Old 08-03-2014, 06:22 PM   #8 (permalink)
Member # 11985
Chris, is the Mast pan the same size as the oe f-body pan? we need the f-body pan for it's size (I currently have the truck pan and need the f-body to free up some space)
Old 08-03-2014, 06:46 PM   #9 (permalink)
Member # 1636
Yeah they make a 5" deep one that I believe is the same depth as an F-body. It's a really nice piece. If I didn't get a complete F-body pan setup for $100, I'd be running one on my new buggy.
It's just about even with the bottom of a TH400 O.E. truck pan
Old 08-03-2014, 06:49 PM   #10 (permalink)
Member # 11985
thank you sir. will look at that one since I need the pan as well.
