Project LQ4 BUGGY: Iraq out with my kawq out - Page 50 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-28-2015, 04:57 PM   #1226 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Weird huh?
Name:  ImageUploadedByAG Free1443484592.352530.jpg
COMBAT VET - USMC 01-05
FRIENDS OF FORDYCE
kdub0013 is offline   Reply With Quote Quick reply to this message
Old 09-28-2015, 05:43 PM   #1227 (permalink)
Member # 207814
If there's no port there then don't worry about it. Mine doesn't have one there either. I just thought you had one since it was drawn in your purdy diagram. Lol
NorIdaWheeler is offline   Reply With Quote Quick reply to this message
Old 09-28-2015, 05:58 PM   #1228 (permalink)
Chkn's Avatar
Member # 228921
Exactly what I was going to say.
Cool story Hansel.
Chkn is offline   Reply With Quote Quick reply to this message
Old 09-28-2015, 06:32 PM   #1229 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Sweet thanks for the input I appreciate it. I can put this to rest now. What's next....
FRIENDS OF FORDYCE
Old 09-29-2015, 07:41 PM   #1230 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Was going to email drew but what is the best method for routing the vent and rollover valve?Name:  ImageUploadedByAG Free1443580897.145591.jpg
FRIENDS OF FORDYCE
Old 09-30-2015, 05:25 AM   #1231 (permalink)
scottapher's Avatar
Member # 126355
Tie those two vents together (or cap the one on the sender) then three sides of the tank and down
Bent Fabrications Evo 2 Coupe
IG: @RxOffroad
scottapher is offline   Reply With Quote Quick reply to this message
Old 10-02-2015, 12:13 PM   #1232 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Thanks dude
Moving on now my tranny gauge and cooler setup. I want to make sure I am understanding this correctly. The derale fan setup I have comes with a temp switch that is inline on the pressure side of my th400. That switch does one thing and turns the fan on and off automatically. Any need to run this on a toggle switch as well?
The second part of this is my equus gauge. It needs a temp sender which equus has and goes to an 1/8 npt fitting. That seems easy too. All I need for that is an in line block on that same pressure line as well correct? Then I just run the signal up to the gauge.
I am going to run this
http://www.improvedracing.com/an-ada...ort-p-294.html
with this
https://www.oreillyauto.com/site/c/cart.oap
FRIENDS OF FORDYCE
Old 10-02-2015, 01:59 PM   #1233 (permalink)
Member # 1636
Put the thermostatic switch for the fan in the hot trans line. Put the gauge sender in the test port on the side of the trans. It's the outlet side of the pump and is already 1/8" npt.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 10-02-2015, 02:20 PM   #1234 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Yes that's right I forgot about that thanks
FRIENDS OF FORDYCE
Old 10-02-2015, 05:30 PM   #1235 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Not wired yet but got tired of seeing it sit on jack stands so I rolled her out
Name:  ImageUploadedByAG Free1443832167.404229.jpg
Name:  ImageUploadedByAG Free1443832180.003626.jpg
Name:  ImageUploadedByAG Free1443832194.254559.jpg
Name:  ImageUploadedByAG Free1443832206.486034.jpg
FRIENDS OF FORDYCE
Old 10-02-2015, 07:03 PM   #1236 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Originally Posted by flatblack51 View Post
best I could do since the car is together
Bumping this so I remember post 828
FRIENDS OF FORDYCE
Old 10-02-2015, 08:20 PM   #1237 (permalink)
Member # 506761
Talking
[QUOTE=kdub0013;33647514]Not wired yet but got tired of seeing it sit on jack stands so I rolled her out :smokin
Bout damn time. Looks good, and stout, I like it.
SnowLynx is offline   Reply With Quote Quick reply to this message
Old 10-02-2015, 08:32 PM   #1238 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Thanks I'm pumped now. Few odds and ends left but wiring is the big one then hopefully everything works when I fire it up!
FRIENDS OF FORDYCE
Old 10-02-2015, 10:37 PM   #1239 (permalink)
dfowlkes's Avatar
Member # 231443
Kudos to doing that in a single car garage
85 Toyota fruggy
dfowlkes is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 07:17 AM   #1240 (permalink)
Member # 1636
I feel you pain with the small space. It's great when you finally roll it outside and look back at how empty the garage looks!
Old 10-03-2015, 08:10 AM   #1241 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
Get her wired up! You're almost there!Looks good Keith! It's always cool to get a good look at the car from more than 2 feet away.
Opinions are like assholes.Everybody has one,and most stink!
DEER TICK is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 09:18 AM   #1242 (permalink)
Member # 39436
Hell yeah Dude!!!
Public lands for Public use
dirtyjed is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 09:44 AM   #1243 (permalink)
FOF
kdub0013's Avatar
Member # 103588
It feels pretty good.
Picking up a bunch of different front springs for the Kings to try out. Also, was looking at my calipers and bolts that came with my 14 bolt disc brake kit and threads are different. I sent a text to Brian at 4x4 outlet to ask what was up see if he can send me the right ones.
Name:  ImageUploadedByAG Free1443890684.618787.jpg
Name:  ImageUploadedByAG Free1443890694.204875.jpg
FRIENDS OF FORDYCE
Old 10-03-2015, 11:40 AM   #1244 (permalink)
Member # 121033
I'm running 14" 125on top and 16" 200 on the bottom. I'm pretty happy with it. just need a couple runs on it to dial them in. I also have the internal bypass ADS shocks so that helps to. I'd go with 150 over 225 to start.
Thank you to My sponsors:
Pro Comp tires
PRP Seats
Maximum Transmissions
Goatbuilt
Trail Ready Beadlocks
Yukon Gear and Axle
ADS Racing Shocks
WARN Ind.
Socal Print Shop
Broadsword Racing
#4889
flatblack51 is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 01:04 PM   #1245 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
Originally Posted by kdub0013 View Post
Was going to email drew but what is the best method for routing the vent and rollover valve?Attachment 1936970
The center port of the pump has a really good roll over valve in it. I am only using that vent and not the Goat Built valve. I put a 5/16" push on fuel hose on it without any fittings and just have it running down the side of the tank.
You might want to rigid mount or protect the hoses that connect to the fuel pump with the AN fittings, if you snag a hose the pump fittings can break off very easy. Under the bed of a stock truck it was not a design requirement.
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 03:32 PM   #1246 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Awesome good to know thanks for sharing that!
FRIENDS OF FORDYCE
Old 10-03-2015, 03:35 PM   #1247 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Picked up a few different springs to try from a buddy today and started playing around with them. Right now I'm about 18" belly with pretty much flat lower links at ride height. I have about 5-6" of shaft showing in the front and about 7" on the 16s in the rear. Never owned a linked rig so I'll run it like this until I feel something I don't like.
Name:  ImageUploadedByAG Free1443911676.324495.jpg
Name:  ImageUploadedByAG Free1443911687.455146.jpg
Name:  ImageUploadedByAG Free1443911697.511583.jpg
FRIENDS OF FORDYCE
Old 10-03-2015, 03:56 PM   #1248 (permalink)
Provience's Avatar
Member # 138976
Looks good! Glad to see it out of the garage
Old 10-03-2015, 04:51 PM   #1249 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Originally Posted by haustow View Post
Awesome build man. Very impressive. I'm doing a similar build and am at the point of engine placement, liking the looks of where you placed everything. If you have a minute can you post up the measurement from the engine crank pulley to very front of chassis? Also the width between your frame rails where the bottom of your radiator mounts? Again, badass build can't wait to see it done.
Sorry about the delay. I'm 33" from crank pulley to front of chassis and 25.5" between the frame rails at the rad.
FRIENDS OF FORDYCE
Old 10-04-2015, 04:29 PM   #1250 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Pcv catch cans in. Rock lights and reverse lights in. Snugged up the fuel lines and brake lines as well. As I move forward though the ass and is a little higher than the front and it seems tall. Two options either I ditch the 16s and go down to 14s or I angle the 16s forward or back a bit and redo the upper mounts, thoughts?Name:  ImageUploadedByAG Free1444001317.845310.jpg
Name:  ImageUploadedByAG Free1444001326.981152.jpg
Name:  ImageUploadedByAG Free1444001338.314566.jpg
Name:  ImageUploadedByAG Free1444001350.601540.jpg
Name:  ImageUploadedByAG Free1444001358.653853.jpg
Name:  ImageUploadedByAG Free1444001370.466515.jpg
FRIENDS OF FORDYCE
