Project LQ4 BUGGY: Iraq out with my kawq out - Page 57 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-04-2015, 09:10 PM   #1401 (permalink)
homeboy's Avatar
Member # 186874
edit double post
homeboy is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 09:11 PM   #1402 (permalink)
homeboy's Avatar
Member # 186874
Originally Posted by kdub0013 View Post
What is this and where does it run to since my rmvb eliminated this?
Attachment 1988953
More random
Attachment 1988961
its a vacuum modulator and no where you dont use it anymore, it is used to adjust line pressure based on engine vacuum to shift. with your manual valve body you always have full line pressure.
just remove it and plug it, most manual valve body kits come with a plug in the box.
Old 11-04-2015, 09:17 PM   #1403 (permalink)
Wilson's Avatar
Member # 7233
It goes to manifold vac Keith.
Old 11-04-2015, 09:17 PM   #1404 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Right but I'm just trying to run a stock th400 for now so don't want to swap parts around the two if possible.
COMBAT VET - USMC 01-05
FRIENDS OF FORDYCE
kdub0013 is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 09:21 PM   #1405 (permalink)
homeboy's Avatar
Member # 186874
then you need it to go to intake vacuum with a stock th400. I run a stage two shift kit in my th350 which holds 1st and 2nd and 3rd is standard D that uses the vacuum to shift through the gears on my 6.0 with LS1 intake, tied it into the rear vacuum port off the back of the intake.
use vacuum line and hook it up off a factory vacuum port to it. if you dont it will shock load the transmission as it trys to shift ( all sort of bad )
seen a broken th350 case partially due to that.
Old 11-04-2015, 10:42 PM   #1406 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
Those would be my 3 year olds boots!
I was gonna say they looked a little girly.
Opinions are like assholes.Everybody has one,and most stink!
DEER TICK is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 10:21 AM   #1407 (permalink)
Member # 111580
Don't lie, I've seen him in them, he says they are comfy.
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 06:21 PM   #1408 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Ok so I guess that port I plugged in the back of the intake can be used for this vac line?
Got the trans in and everything bolted and rtvd. Even got the torque converter bolts in but what a pain in the ass that was. Going to try and get everything buttoned up this weekend.
Name:  ImageUploadedByAG Free1446772861.529660.jpg
Name:  ImageUploadedByAG Free1446772871.183975.jpg
FRIENDS OF FORDYCE
Old 11-05-2015, 07:16 PM   #1409 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
Ok.I might be way out of line but,cant you bolt the converter to the flex plate,then put the Trans to the converter/motor? This is what I did,and it worked fine.The Trans mounting bolts sucked the Trans to the motor. No leaks,and everything works fine. I'm just curious?? Anybody care to enlighten me? Sorry to clog up your thread Keith, but you said it was a pain in the ass to bolt up the converter.
Old 11-05-2015, 07:30 PM   #1410 (permalink)
homeboy's Avatar
Member # 186874
No you won't fully seat the converter and I always pre fill the converter with a quart of oil if its new upon install.
Old 11-05-2015, 08:55 PM   #1411 (permalink)
Wilson's Avatar
Member # 7233
It's not the proper way. As said, you cannot make sure the converter is properly seated and you run a far greater risk of nicking the pump hub seal.
Old 11-05-2015, 09:31 PM   #1412 (permalink)
Member # 111580
that is the bigger issue. It's pretty easy to tell if the converter is into the pump right, but trying to stab the end through the seal blind while holding the trans up is a long shot, at best.
BUCK OFAMA
4 seater LS1 buggy
Old 11-05-2015, 10:39 PM   #1413 (permalink)
Member # 1636
I'm having difficulty understanding how it's easier to bolt the converter to the flexplate before putting the transmission on.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 11-06-2015, 07:31 AM   #1414 (permalink)
The dude abides
DEER TICK's Avatar
Member # 114517
I put it all together out of the rig.Guess I got lucky.Next time I'll try the right way.
Old 11-06-2015, 07:51 AM   #1415 (permalink)
FOF
kdub0013's Avatar
Member # 103588
OK so I am going to grab some vacuum hose today from napa is there a different adapter or something I Can use to temporarily swap that plug out I installed on the back side of the intake? Figured worse case I would epoxy a barb pitting in the plastic plug or something like that.
FRIENDS OF FORDYCE
Old 11-06-2015, 08:03 AM   #1416 (permalink)
Wilson's Avatar
Member # 7233
If it's threaded, pick up a brass barb adapter at the hardware store.
Old 11-06-2015, 08:07 AM   #1417 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
If your talking the big one that you put the plug in on the upper section, just put the stock one back in it and get some of the crappy adapters to make it work for now since its only a temp setup.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 11-06-2015, 08:57 AM   #1418 (permalink)
FOF
kdub0013's Avatar
Member # 103588
I can't find the stock piece I pulled out but the plug is only a 1/2" push to connect setup so I should be able to just stab some sort of 1/2" OD tube in and clamp a hose to it.
FRIENDS OF FORDYCE
Old 11-07-2015, 07:42 PM   #1419 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Trans back in and I have all gears now!
http://youtu.be/KWOXizBQ6tI
http://youtu.be/IIuAfvzh7pw
FRIENDS OF FORDYCE
Old 11-07-2015, 08:30 PM   #1420 (permalink)
Member # 232324
Congratulations! Your neighbors may dislike you by tomorrow evening...haha
jeepyjca is offline   Reply With Quote Quick reply to this message
Old 11-08-2015, 08:01 PM   #1421 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Thanks!
I got it moving under its own power and off jack stands tonight. Need to button up a few things and I will be doing hot laps up and down my street tomorrow
FRIENDS OF FORDYCE
Old 11-10-2015, 07:56 PM   #1422 (permalink)
FOF
kdub0013's Avatar
Member # 103588
Well she runs, drives and moves. Fordyce here I come. I ran it up and down the street and backed it into the garage. It's not 100% but it's wheel able. I'm stoked.
Name:  ImageUploadedByAG Free1447210580.931881.jpg
Name:  ImageUploadedByAG Free1447210604.950336.jpg
Name:  ImageUploadedByAG Free1447210614.250984.jpg
FRIENDS OF FORDYCE
Old 11-10-2015, 08:00 PM   #1423 (permalink)
jemarshall's Avatar
Member # 50690
Now go beat on it already
Old 11-10-2015, 08:03 PM   #1424 (permalink)
Wilson's Avatar
Member # 7233
One week too late
Old 11-10-2015, 08:15 PM   #1425 (permalink)
YotaAtieToo's Avatar
Member # 25632
One week too late
I was going to say the same thing, the weather forecast is not looking good for a while either. Probably have to wait until spring
YotaAtieToo is online now   Reply With Quote Quick reply to this message
