Family Wagon 1996 ZJ Build - Page 21 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2019, 03:24 PM   #501 (permalink)
Member # 21320
Console looks really good
TDI swapped lwb Samurai
BCzuk is offline   Reply With Quote Quick reply to this message
Old 07-23-2019, 03:46 PM   #502 (permalink)
scottapher's Avatar
Member # 126355
Originally Posted by Kraqa View Post
... I will make some foam inserts to better fit a beer.
Hopefully tomorrow I can make some progress on the lid. I want to get this powder coated ASAP.
Cool console...Iíd imagine an oldschool, thick koozie would work just as good as some foam?
Bent Fabrications Evo 2 Coupe
IG: @RxOffroad
scottapher is offline   Reply With Quote Quick reply to this message
Old 07-25-2019, 09:44 PM   #503 (permalink)
Kraqa's Avatar
Member # 24741
Send a message via AIM to Kraqa Send a message via MSN to Kraqa
i needed a bulkhead for running the three brake lines through the floor of the jeep. this is the supply to the cutting brake and the 2 returns going to the rear axle.
i was going to cut bend and tig weld one...but then i remembered we bought 3d printer. so here we go.
the design
printed from onyx resin reinforced with fibreglass.
here is all the parts with both rubber gaskets.
here is the rubber gasket installed in the top part. the 3 dimples are holes where the brake lines will pass through.
here it is put together.
[SIZE="6"][COLOR="Red"]REDWOOD PLASTICS RACING[/COLOR][/SIZE]
Toyo Tires Offroad Race Team | EMF Rod Ends | Mulitia Muffler | VancouverWaterjet.com | RCV Performance Shafts | Redwood Plastics & Rubber
Instagram & Twitter: @Kraqa
Kraqa is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 10:04 AM   #504 (permalink)
Member # 135947
Slick.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 11-08-2019, 04:07 PM   #505 (permalink)
Kraqa's Avatar
Member # 24741
i got some more progress on the truck. I got my boatside plastic installed so i needed a rail for my highlift jack as well as a foundation for the fender bars i need to bend up when i start the cage.
Old 11-08-2019, 04:07 PM   #506 (permalink)
Kraqa's Avatar
Member # 24741
Old 11-12-2019, 08:42 AM   #507 (permalink)
Member # 21100
Still my favourite build on here. How are you feeling?
This was already the most interesting thread on pirate, then a tank shows up.
Bondage is offline   Reply With Quote Quick reply to this message
Old 11-12-2019, 11:45 AM   #508 (permalink)
Kraqa's Avatar
Member # 24741
I'm doing good. each day is different. The recovery from my colostomy reversal has been long and rough.
I went wheeling on Saturday and i'm still feeling it today.
Old 11-17-2019, 08:39 AM   #509 (permalink)
Member # 232666
the design
I really like this bulkhead. How does a guy go about getting you to make one for him?
This is a super nice and well thought out rig. Great job!
Hope your recovery keeps looking up too! Good luck
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is offline   Reply With Quote Quick reply to this message
Old 12-23-2019, 10:28 AM   #510 (permalink)
Kraqa's Avatar
Member # 24741
I can print what ever you need. Just let me know.
This thing has been burning lots of coolant. I dont have any overheating issues, the temp does fluctuate a lot though.
The last time out i was probably driving for 5 to 6 hours and it burnt a full jug of coolant.
I was going to pull the plugs and take a look then start pulling the top end off it and see whats going on. I feel like a new motor is going to be in its near future.
Old 02-12-2020, 07:09 AM   #511 (permalink)
Kraqa's Avatar
Member # 24741
well shit. photobucket fixed my pics.
I should be making some more progress on this soon. i bought an upgraded PS pump while i was on the lake bed. My steering has always been good but a tad bit slow. SO this should make a huge difference
Old 02-13-2020, 11:06 AM   #512 (permalink)
Member # 865018
so i'm going crazy here not being able to drive the jeep i got complete 1 project and start another.
i got my steel racks up.
and i started to adapt the factory ebrake handles to some CNC cutting brakes for a new center console i will be building.
i still need to sort out a bracket to hold everything. i want this to look factory and be able to use the ratcheting mechanism to hold the cutting brake. i'm hoping if i get pulled over the cops wont know any better when they ask me to pull the ebrake. i do plan on leaving all the factory cables under the car in place so it also looks like i have a mechanical brake.
When the cutting brake (either side) is activated, it pressurizes the rear brake that it is plumbed to. What prevents the brake fluid from going back to the master cylinder, filling the master cylinder vice activating the brake? Is there a check valve involved? Maybe Iím overthinking this, it seems like each side needs to block the flow back to the master cylinder when either handle is pulled.
1985 CJ-7
Axhammer is offline   Reply With Quote Quick reply to this message
Old 02-18-2020, 11:42 AM   #513 (permalink)
Kraqa's Avatar
Member # 24741
You are totally over thinking this. Cutting brakes are a proven thing. This is nothing new. The plunger works the same as a master cylinder. You don't see master cylinders pressurizing they reservoir when you step on the petal do you?
Old 02-18-2020, 11:58 AM   #514 (permalink)
Member # 3007
I love your work, but the stock handles look ridiculous IMO
Bones is online now   Reply With Quote Quick reply to this message
Old 02-19-2020, 09:04 AM   #515 (permalink)
Kraqa's Avatar
Member # 24741
i wanted the stock look because i need a factory Ebrake to pass an inspection. So this helps keep things looking closer to stock if i ever get pulled over. Cops like to see things look factory around here. when they seen custom of janky they start handing out tickets.
Old 02-19-2020, 09:49 AM   #516 (permalink)
Member # 502649
The magnum heads are notorious for cracking between valves and burning coolant.
Twmdodge99 is offline   Reply With Quote Quick reply to this message
Old 02-19-2020, 12:16 PM   #517 (permalink)
Kraqa's Avatar
Member # 24741
i've done the heads on one of these before for the same reason.
i just am at the point where i'm wondering how much money I throw at this thing before i just say fuck it and do an LS swap.
Old 02-19-2020, 12:56 PM   #518 (permalink)
Member # 55560
The answer is always LS swap.
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 02-19-2020, 04:27 PM   #519 (permalink)
Member # 502649
Heads shouldn’t be much and if you’re fine with the power of the 5.2 I say keep it. While your in there make sure the plenum plate isn’t leaking and cut and port the kegger intake. Get a few more ponies for free.
Old 02-20-2020, 09:14 AM   #520 (permalink)
Kraqa's Avatar
Member # 24741
Heads shouldnít be much and if youíre fine with the power of the 5.2 I say keep it. While your in there make sure the plenum plate isnít leaking and cut and port the kegger intake. Get a few more ponies for free.
i did the kegger mod 3 years ago and didn't really notice much if anything. but the motor is pretty tired. I did a quick search for heads and didn't find anything. i'm going to keep an eye out and see if i can find a good deal on them.
Old 02-20-2020, 10:55 AM   #521 (permalink)
Old School
Technohead's Avatar
Member # 130090
. . . I did a quick search for heads and didn't find anything. i'm going to keep an eye out and see if i can find a good deal on them.
Not sure what your definition of good deal is but I run these on the 5.2 in my ZJ:
Hughes Engines
I lived with the coolant issue for (many) years before swapping heads. Despite the constant smell of coolant in the exhaust the engine seemed to run fine otherwise. Head swap did not bring much to the table except no more coolant smell.
Technohead is offline   Reply With Quote Quick reply to this message
Old 02-20-2020, 10:59 AM   #522 (permalink)
Kraqa's Avatar
Member # 24741
Hughes Engines
see for about that cost i can swap an LS and have a more modern ECU and motor. No oil leaks. better power and more reliable.
the last 5.2 i swapped head on i found a set for $250 CDN. if i'm goign to spend more than $500 then i might as well swap motors.
