Bombproof 14 bolt pinion guard - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-26-2014, 05:40 AM   #1 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Which manufacturer makes the most bombproof 14 bolt pinion guard. I've bent them up to 3/8" and finally plated the one I have. 1/4" wouldn't get me off the trailer. This is for another build. Might as well start with the best.
Thoughts?
https://
https://www.facebook.com/diddysbigblockraceshop/
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 05:42 AM   #2 (permalink)
Member # 103621
I like RuffStuffs.
EDIT:
LInky
http://www.ruffstuffspecialties.com/catalog/14BPNG.html
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 06:30 AM   #3 (permalink)
FOF
kdub0013's Avatar
Member # 103588
WFO makes a nice setup that ties into the truss.
COMBAT VET - USMC 01-05
FRIENDS OF FORDYCE
kdub0013 is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 06:36 AM   #4 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
I think my diy4x is 1/2" on the guard part. Kert made me one with a flange on top so I could tie it into my truss too.
http://diy4x.com/cart/index.php?rout...&product_id=70
MNorby is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 06:39 AM   #5 (permalink)
Member # 37213
I copied one spidr made way back.
Its a touch ghetto and currently doesn't leave room to get at ubolt yokes..
But it's tough as all hell and was easy to put together
Toyota with Stickies, links, beverage holder and other accessories
metchosin joe is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 06:45 AM   #6 (permalink)
Member # 53677
Thoughts?
I have seen the ruffstuff ones that have been plated further and braced a bit more take some SERIOUS beatings and be fine.
That being said...I am more interested in this "other build" you have going on more than what fawking pinion guard you are going to use
post that shit!
2017 JK Buggy / LQ9 / Solid Mfg HP60 / 14bolt / 42" Maxxis / Method Wheels / Radflo
IG: @partiallycommittedracing
slravene is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 07:25 AM   #7 (permalink)
Member # 53528
https://www.wfoconcepts.com/pr/14-bo...3210/3312/4319
and you wont need one
Old 11-26-2014, 07:49 AM   #8 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
The one I had was the main reason we didn't finish KOH14.
I think it was a Blue Torch one. Bent up and broke the 1410 yoke. More driver than part, and it had been on there for 10+ years. I cut it off and built a new one with a sharper angle on the bottom using AR plate. 2 pcs of 3/16" AR400 laminated and braced. it amazing how much they will bend up.
Offroad Design ♦ Atomic MC ♦ Jantz Engineering
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 08:35 AM   #9 (permalink)
Brian1's Avatar
Member # 2205
I like and use the GLO guard the best. Use them on 2 different 14B's without problems.
Ford 9" & 14 Bolt Yoke Guard
That DIY4x4 one does look like some beef though!
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 08:41 AM   #10 (permalink)
Wilson's Avatar
Member # 7233
Just run companion flanges?
Old 11-26-2014, 08:43 AM   #11 (permalink)
Buckon37s's Avatar
Member # 20394
Quick dumb question. If you run the 14 bolt upside down, is the pattern consistent where you can mount it upside down?
[I]BUCK[/I] Wild Racing
Team 911
Thank you all for your support
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Tom Woods Drive Shafts
Buckon37s is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 09:48 AM   #12 (permalink)
generalee7's Avatar
Member # 16522
I like my Ruff Stuff guard. Some other manufacturers hang below the housing and I didn't like that. I have a Ballistic 14 bolt pinion guard I can sell ya for cheap
generalee7 is offline   Reply With Quote Quick reply to this message
Old 11-26-2014, 01:02 PM   #13 (permalink)
Member # 21215
14BFF Guardsman
This is the beefiest one I've seen yet. I dig how it's notched to fit over a 1410 yoke. And comes with hardware. Can you post a picture of your installed?
https://
Old 11-26-2014, 01:10 PM   #14 (permalink)
MNorby's Avatar
Member # 11448
About the best shot I have from during the build
Old 11-26-2014, 01:26 PM   #15 (permalink)
Member # 103621
The ruffstuff one clears a 1410 yoke just fine. No mods needed.
Old 11-27-2014, 04:38 AM   #16 (permalink)
Member # 189239
Yes. NO they will not. 2 holes will have to be slotted out 1/8"
YROC FAB. is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 05:30 AM   #17 (permalink)
Member # 123295
I think the bolt pattern is not symmetrical. I had pinion guard made here locally, bolt pattern copied from the axle, but it was welded "upside down" and could be bolted up only that way. The pattern looks symmetrical, but I m 99% sure it isn't. To use it i would have to cut the guard off form the flange and weld it in different postion. It was 1986 cucv 14B ff axle.
1978 K5, LS1+th350+np203+D60/14B 4,56:1 + Detroits. 38,5x14,5x16 Creepys. Hyd assist, 52"s etc.
K5-EINARI is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 05:46 AM   #18 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
flanges, then you dont need to deal with straps or ubolt failures.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 06:12 AM   #19 (permalink)
Member # 43587
Send a message via AIM to TBItoy
That was my thought... I never really liked the big digger guards hanging down...
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 11:16 AM   #20 (permalink)
Buckon37s's Avatar
Member # 20394
Originally Posted by YROC FAB. View Post
Yes
Hmmm.
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 11-27-2014, 11:21 AM   #21 (permalink)
onetoncv's Avatar
Member # 2160
A good quality flange solves the problem .
- Also see us on facebook @ High Angle Driveline
530-877-2875
onetoncv is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 11:58 AM   #22 (permalink)
Member # 189239
Hmmm.
I have a flipped 14 bolt for my rear engine buggy with a blue torch fab pinion shovel bolted on with no modification right now sitting in my shop.
I r retarded. K5-EINARI is correct. I only had 2 bolts in mine at the time.
4/6 will line up no problem. The other two i had to slot out 1/8" across from each other on the sides.
Old 11-27-2014, 12:02 PM   #23 (permalink)
Buckon37s's Avatar
Member # 20394
Thanks!
Team 911
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Old 11-27-2014, 12:37 PM   #24 (permalink)
Member # 176679
Made one. Few hours at a buddies shop, cut, bent, blasted and punched out of 1/2" plate and eventually powder coated. Artec on the right.
Savage Amusement TJ 6.0/4L80E/flat 205/Linked/16"co's/60/14/42's SOLD
XJsavage is offline   Reply With Quote Quick reply to this message
Old 11-27-2014, 02:26 PM   #25 (permalink)
Member # 103782
This ^^ this is exactly why toyota guys have such good luck running yota driveshafts on tons
-'86 runner SAS cookie cutter build....links coming soon!
-'89 xtracab mild built 22re, stock ifs with timbren bumps, 4.56s, 95 4runner front clip, fresh paint, full dynamat, clean interior, heated seats, a/c.... Nice 20mpg dd, wish it had cruise control.
iwannabemro is offline   Reply With Quote Quick reply to this message
