Dana 60U used pattern help please - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2014, 07:07 AM   #1 (permalink)
Chief Rocka's Avatar
Member # 196079
Doing 1st locker/gear setup and need some help with the pattern.
-rear dana 60U used gear pattern, unknown orig cond from 1999 E350
-setting up for hwy miles/speeds to/from trail
IP .050, OP .069 @25in/lb (new IP cone, dummy IP cup, dummy OP cone, new OP cup), RGS .055, NRGS .053, BL .006375 (avg of 4 measurements)
[IMG][/IMG]
[IMG][/IMG]
Orig pattern/marks:
[IMG][/IMG]
[IMG][/IMG]
Thanks for the help,
Chan
Chief Rocka is offline   Reply With Quote Quick reply to this message
Old 01-03-2015, 04:18 PM   #2 (permalink)
Member # 196079
What do you all think? Am I even close? BTW, these are used orig dana 4.10 gears.
I was thinking add .002 and will try to get it tomorrow.
Can I completely ignore the drive pattern on used gears?
For used gears that will see hwy speeds and mileage, should BL be set on the tight or loose side?
Not sure if camera getting knocked over caused bad pics or my lack of photography skills, but here goes.
0.040 (removed 0.010):
[IMG][/IMG]
and
[IMG][/IMG]
Then 0.045 (added 0.05):
and
Old 01-04-2015, 10:02 AM   #3 (permalink)
Member # 187
run it
[FONT="Arial Black"][SIZE="5"][/SIZE][/FONT]
:flipoff2:
GearMan is offline   Reply With Quote Quick reply to this message
Old 01-04-2015, 12:12 PM   #4 (permalink)
Member # 196079
Gearman,
Which one are you saying to run?
Thanks
Old 01-05-2015, 04:37 PM   #5 (permalink)
Member # 187
last one
:flipoff2:
Old 01-06-2015, 06:29 PM   #6 (permalink)
Member # 196079
Thanks, appreciate the help!
Old 01-06-2015, 08:07 PM   #7 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
.045 for sure
NorCalPR is offline   Reply With Quote Quick reply to this message
