JGS's F150 IRS/IFS 4x4 sand truggy build... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-06-2015, 07:11 AM   #1 (permalink)
Tubing Junky
Member # 225995
Figured I'd venture outside the shop section to share the start of the planning stages of my next build...
F150 because well good models are available for pre-planning. But basically we'll just use the cab, hood and fenders.... maybe bed sides.
Exo-cage the cab and 100% tube chassis the rest.
Rear Engine chevy 5.3L Turbo to Ford C4 (done before) or Turbo400 then to the baddest transfer case I can afford or build and some 8.8 IRS diffs front/rear. Axles I'm thinking GM 1-Ton outer CVs for the rear and custom 300m axles. Front F150 outer CVs and 300m axles.
4 corner A-Arm 4x4. Flat bed cover with 2x Paddle tire mounts. On-board air jacks as well . Street Legal (no emissions), able to recover buggies and then go play [smilie=lmao.gif]
Gonna be a year of planning... Basically take all my buggy suspension designs and stick them under a truck.
Somebody going to talk me out of it? Its gonna be a buggy wearing an enough of an F150.
Want to get a model and start designing, the TubePro needs another job
Trying to CNC everything on a beer budget...
JGSturbo is offline   Reply With Quote Quick reply to this message
Old 01-10-2015, 06:30 AM   #2 (permalink)
Tubing Junky
Member # 225995
Working with this big of model is painful
It begins
Old 01-10-2015, 08:27 AM   #3 (permalink)
ISDTBower's Avatar
Member # 94026
Another big project. Cheers!
ISDTBower is offline   Reply With Quote Quick reply to this message
Old 01-10-2015, 08:56 AM   #4 (permalink)
Tubing Junky
Member # 225995
All digital at this point! Learning how to work the bigger assemblies, finding out how much computer power I need.
I'll be hitting the 'yards for the parts I need as I draw.
I have a lot of designs to pull from that are already tested, makes thinks go faster.
Even if this 3D F150 model isn't 100% correct I can make adjustments to the design once I finally get a truck.
Old 01-10-2015, 11:06 AM   #5 (permalink)
Tubing Junky
Member # 225995
Progress...
I think I will slide the cab in from the bed side since its just a giant wedge. Have the bed bars remove-able like an engine cage.
Old 01-10-2015, 09:22 PM   #6 (permalink)
Tubing Junky
Member # 225995
Gonna need to clearance the sheet metal for 35s (duh)
Old 01-10-2015, 09:32 PM   #7 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
If it please sand car, why bother with the big gay Exo?
& Blaine
:tank:
Old 01-11-2015, 07:27 AM   #8 (permalink)
Tubing Junky
Member # 225995
-More interior room.
-Cab will stay more water tight with my plans.
-No plexi back window.
-With a big rig you do end up rubbing trees every now and then.
-Sand is just the main task, I'll be up for some other slower activities later.
-Our dunes are tight and crowded it might have to defect UTVs and ATVs depending on the idiot level of the day.
Also thought it would be fun to deco it like a big slow crawler/billy-jo-jim-bob got him self a tube bender rig. Only part of this plan that's going hurt is the shocks ... The front might do with 2.5s but the back ummm I'm not sure.
Old 01-11-2015, 10:19 AM   #9 (permalink)
Tubing Junky
Member # 225995
The bump limits of the hood give plenty of reasons to drop mount the front suspension.... I love it more as it takes more shape
Old 01-11-2015, 06:16 PM   #10 (permalink)
Tubing Junky
Member # 225995
In goes the motor.
Old 01-11-2015, 09:44 PM   #11 (permalink)
Tubing Junky
Member # 225995
Uprights from an old drawing...droop may be a bit excessive.
Old 01-15-2015, 09:41 PM   #12 (permalink)
Tubing Junky
Member # 225995
Still have to test steering for max angle.. so it could go down.
Old 01-17-2015, 07:39 PM   #13 (permalink)
Tubing Junky
Member # 225995
Widened the flares out to 90.5" Tucking the little tires now.
Overall more progress, showing ride height in that shot.
Liking it alot. Like a buggy ate an F150 cab.
Old 01-18-2015, 05:26 AM   #14 (permalink)
Member # 10
Would it be better to model it around some aftermarket wide-flare front fenders? Typical fiberglass desert-truck stuff. Would leave more room for tires to stuff, also...
Either way--subscribing.
Carl Whitmore
I Lean is offline   Reply With Quote Quick reply to this message
Old 01-18-2015, 06:44 AM   #15 (permalink)
Tubing Junky
Member # 225995
I do want tube to rub against tree hazards in the oregon dunes.
I do plan on doing panels on top on the flares, maybe thin liners on the inside. I really want it to show lots of tube, being a tube pro demo example
Old 01-18-2015, 05:42 PM   #16 (permalink)
Tubing Junky
Member # 225995
Rear drive train layout, can't wait for my GM 9.25 diffs to show up tomorrow so I can start modeling it and building around it.
Old 01-20-2015, 09:48 PM   #17 (permalink)
Tubing Junky
Member # 225995
Tweaked the front lower A-arms, Kinect scanned the 9.25AAM for some fit tests. not beautiful but gives me a clue about if its gonna work... I think it looks good.
Old 01-21-2015, 08:13 AM   #18 (permalink)
Member # 20490
Send a message via AIM to clemsonjeep
Can I play the computer design idiot for just a moment? How do you go about getting the F-150 design into the program...the 5.3...etc? The 8.8 looks to be scanned...which I understand, but the other parts look more refined.
Badass skills and just looking forward to watching it play out...
'88 Sammy
91 1.6L 8v EFI w/ K03 Turbo
03-72LE 4 Speed Auto / 6.5 tcase
Toy's cyro'd 5.29s ARB HP front
Elocker rear w/ cryo'd lock collar & side gears
Trunnion bearing eliminator
Longfields/chromo hub gears
4 link air shocks front / 4 link air shocks rear
39 BFG Reds
Raceline Monsters
clemsonjeep is offline   Reply With Quote Quick reply to this message
Old 01-21-2015, 09:31 AM   #19 (permalink)
Tubing Junky
Member # 225995
The LS model and 4l80 model are free from the rally fighter file you can down load.
The f150 model was bought from a 3D file site, $96. But its worth it.
The 9.25 I scanned with a kinect cam and kscan 3d. You need a fairly hotrod pc to handle these bigger models too.
Old 01-25-2015, 09:37 AM   #20 (permalink)
Tubing Junky
Member # 225995
Got that 8.8 scanned in and in-place. Then I realized I needed to rework the front bulkhead bars and plates.
Old 01-25-2015, 10:18 AM   #21 (permalink)
ISDTBower's Avatar
Member # 94026
AWEsome
Old 01-25-2015, 10:24 AM   #22 (permalink)
Member # 7412
Cool
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 01-26-2015, 05:51 AM   #23 (permalink)
Member # 20490
Gotcha...thanks for the reply...now I know!
'88 Sammy
39 BFG Reds
Raceline Monsters
Old 01-27-2015, 09:54 PM   #24 (permalink)
Tubing Junky
Member # 225995
There are some serious fender law around here. Wonder how it'll look with some skins on the flares.
Old 02-01-2015, 09:36 PM   #25 (permalink)
Tubing Junky
Member # 225995
Working on fender liners
