2WD 4l80, cut output shaft??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2015, 07:52 PM   #1 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
Can you cut the 32 spline output of a 2wd 4l80, and bolt to np241, black box, atlas, etc?
any special adapter?
using a 2wd because I want the built in rear VSS (1997 and up)
KOH CAR 415, McCarthy Motorsports
THE ROCK GODS, Reno Nv
Hey Tech Fabrication
HTF buggy, 6.0, 40s, Spidertrax/Megas,
RZR XP1000
B2Krawler is offline   Reply With Quote Quick reply to this message
Old 01-11-2015, 08:06 PM   #2 (permalink)
Member # 203330
I cut the output on my 4l80e
Used a slightly modified t400 adaptor
Bolted on a ford np205
Zero issues
Have you ever noticed that "common sense" isnt that common anymore
bentupcj is offline   Reply With Quote Quick reply to this message
Old 01-11-2015, 08:14 PM   #3 (permalink)
Member # 15502
You can cut the output shaft, just make sure you keep any shavings from entering the trans housing. I cut my TH400 shaft with an angle grinder/cut-off wheel and then cleaned up the splines with a flap disc, no issues.
Working on going fast.
f0cker is offline   Reply With Quote Quick reply to this message
Old 01-11-2015, 08:59 PM   #4 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
I understand that this will work with a 205, but could you bolt a GM round 6 bolt pattern TC like a 241, atlas, etc. to cut down 2wd 4l80? any pics?
RZR XP1000
Old 01-11-2015, 09:10 PM   #5 (permalink)
Member # 80854
I cut mine and added an Atlas behind an Oem adapter. GM PN# 15724745
This pic is before I cut it with a cutoff wheel.
94' Yota, LQ4/Atlas/Tons
RebelRider is offline   Reply With Quote Quick reply to this message
Old 01-11-2015, 09:27 PM   #6 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
so those splines must go in quite a ways (where you have the towels) in order for that atlas to end up flush with the oem adapter?
did you start with a 2wd on purpose for the VSS?
RZR XP1000
Old 01-11-2015, 09:36 PM   #7 (permalink)
Member # 80854
Yes, they go in a ways. The donor truck I bought for the 6.0 was 2wd so it's just what I had. I'll get a pic tomorrow of how much I had to cut off. You also have to notch out the hole at the 7 o'clock position on the adapter in order for the atlas to bolt up. No big deal at all. Here's the 2wd tail housing removed.
Edit: I think I cut off 3.25".
Old 01-11-2015, 09:53 PM   #8 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
thanks, this helps a lot
RZR XP1000
Old 01-11-2015, 09:57 PM   #9 (permalink)
Member # 80854
No problem. My rig runs an drives with no issues. VSS works as it should also. It's a 2000 model 4L80E. I think I paid $60 shipped for the adapter new from gmpartsdirect.com
Also, I can't take credit for all of the research. I picked a lot of it up from Hardline crawlers forum.
Old 01-12-2015, 07:23 AM   #10 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
There are a couple 4l80 2wd ouputs, make sure you have the one with tons of splines. Some are only splined a little ways, others are fully splined, from what I can rememeber.
Kelly Kaiser
Vertical Limits Inc
913.731.3040
for the fastest quick release extinguisher mounts available and UTV parts
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 01-12-2015, 07:39 AM   #11 (permalink)
Member # 80854
Yes, I should have mentioned that also. IIRC, it's the early 4L80's that aren't splined all the way down. Don't hold me to that though.
Old 01-12-2015, 08:41 AM   #12 (permalink)
THE ROCK GODS
B2Krawler's Avatar
Member # 18818
shift kit in 4l80?
I have been told the 4l80 has to be completely disassembled in order to install a shift kit and cannot be done just through the pan/VB, can anyone confirm this?
I would like for it still to shift normal in Drive, but be able to hold 1st and 2nd
RZR XP1000
Old 01-12-2015, 12:30 PM   #13 (permalink)
inphobic's Avatar
Member # 8422
Send a message via AIM to inphobic
My 4l60 holds 1st and 2nd like a ford transmission. (As far as I know it's factory)
Jake Good
inphobic is offline   Reply With Quote Quick reply to this message
Old 09-08-2015, 01:57 PM   #14 (permalink)
etcv97's Avatar
Member # 607810
will this 2wd 4l80/ np205 swap work in a 2007 2500hd classic with no electrical issues? I want to get rid of my chain drive stock case.
etcv97 is offline   Reply With Quote Quick reply to this message
Old 09-08-2015, 02:10 PM   #15 (permalink)
Jeepman14wheel's Avatar
Member # 46071
shift kit in 4l80?
Take a look on TransGo website, you do not have to disassemble the whole thing. It can be done pan/VB. You can also modify it for a FMVB and get away from the electronics.
Instagram @mike_fought
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 09-08-2015, 05:05 PM   #16 (permalink)
Member # 80854
There will be no wires going to the t-case if you use a 2wd trans. If you have an electric shift stock case, I don't know if unplugging it will set off any lights.
Old 09-09-2015, 11:19 AM   #17 (permalink)
etcv97's Avatar
Member # 607810
My truck has the manual floor shift but I haven't looked at anything real close yet.
Old 09-10-2015, 01:08 AM   #18 (permalink)
Member # 368602
Zero issues
More info on this please. I am attempting todo the same thing but was going to use a doubler as the 4l80e to 205 adapter.
sardo_67 is offline   Reply With Quote Quick reply to this message
Old 09-10-2015, 01:11 AM   #19 (permalink)
Member # 368602
Also this will help too
https://www.pirate4x4.com/forum/chevy...e-2wd-4wd.html
Old 11-11-2015, 10:37 PM   #20 (permalink)
Member # 203330
I used a 2wd 4L80e witch had a output shaft with a long 32 count. ( don't remember exactly how much I cut off. If I remember correctly about 1.5 to 2 inches. But don't quote me on that.)
Had to obtain and install a gm 32 spline input for the Ford np205 tc
Used a TH400 advanced Adaptors, adaptor witch I had to have the outer Oring boss milled out just a bit.
I found the biggest advantage by going with a 2wd tranny verses a 4wd one was the fact that both speed sensors were in the tranny case verses one in the tranny and one in the tc .
No screwing around with gettin a speed sensor into the 205 and getting it reading correctly, or opening up the tranny to swap in the sensor.
( I'm not 100% sure it even needs both sensors but my tranny shifts just like it did in the donor, and no tuning problems too deal with )
Is my way the best or only way ?? Probably not😉
Did it work out ?? Sure did !!😄
Best part about the whole thing, I was able to reuse parts I already had laying around. 😎
Old 03-01-2018, 05:18 PM   #21 (permalink)
Member # 5799
I know this is old but did you change the plug in the back of the tranny with a plug that didnt have a hole in it?
Esteban
Esteban86K5 is offline   Reply With Quote Quick reply to this message
Old 03-02-2018, 12:56 PM   #22 (permalink)
Member # 41764
One should.
Also plug that stupid return hole to the pan on the bottom. Fluid just pours out of it on climbs and then leaks between your stupid clocking ring and t-case
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 03-03-2018, 10:16 AM   #23 (permalink)
Member # 5799
Originally Posted by bggrnchvy View Post
One should.
What up Kyle!
So in theory, if I plug both those holes, then the oring on the adapter is not needed right?
Esteban
Old 03-05-2018, 08:38 AM   #24 (permalink)
Member # 41764
What up Kyle!
Living the dream
Yea, I guess you could forgo the o-ring that seals the adapter. If anything it, won't let pressure build in that section since you blocked off all the fluid paths.
Old 03-05-2018, 11:34 AM   #25 (permalink)
Member # 5799
Living the dream
I may try to do that. The less portholes to allow the fluids to leak the better.
Esteban
