Swapping inputs on Atlas question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-14-2015, 05:36 PM   #1 (permalink)
Member # 102813
I have a 32 spline input on my Atlas and need to swap it over to a 23 spline. My plan was to get the input and seal kit, no big deal right?
I PMed a few vendors for parts quotes but only had one tell me this
"Am I correct in assuming you have an Atlas that has a different input spline on than the 23 spline you need? If so and you are not just fixing a broken/damage 23 spline input this is not as simple as just buying an input. I will need the serial number off the case."
What is the deal? I have never owned a Atlas until now and am learning about them.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 01-14-2015, 05:41 PM   #2 (permalink)
Jeepman14wheel's Avatar
Member # 46071
I swapped an input and did not go through that....
Instagram @mike_fought
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 01-14-2015, 05:45 PM   #3 (permalink)
RebelRider's Avatar
Member # 80854
When I swapped my input, the serial number was needed to find out how old my case was. They have changed input shaft designs a couple of times.
RebelRider is offline   Reply With Quote Quick reply to this message
Old 01-14-2015, 08:19 PM   #4 (permalink)
Wilson's Avatar
Member # 7233
^This, the swap is the same and simple, but AA has used two different input shaft splines (coarse and fine, essentially).
Old 01-15-2015, 05:42 AM   #5 (permalink)
Member # 148067
I also had to verify my case when buying a new input. As stated above, they made some updates.
Just call Advanced Adapters and get what you need. Or at least the list of part numbers.
Tony Simeone
Youngstown, Ohio
Running925 is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 07:22 AM   #6 (permalink)
Member # 186874
Same thing when I Rebuilt my two speed, had a very early production t case and aa sold me all the updates after giving them the number off the case.
homeboy is offline   Reply With Quote Quick reply to this message
Old 01-15-2015, 07:41 AM   #7 (permalink)
Member # 102813
Thanks guys!
[/COLOR]
