Member # 102813
Bushing span distance question
I'm figuring out tranny mounting options on my tube chassis crawler. The easiest mount option is a 10" bushing span. The sleeve would be a 5/8 ID, 1/8 wall, and 7/8 OD. I would use a 5/8 threaded rod and .120 wall 1 3/4 DOM on the outside.
Think this is to long of a span?
[COLOR="Magenta"]Help bring back Swartz Canyon, Join To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/COLOR] [COLOR="Lime"]The good guys...[/COLOR] [COLOR="Red"]Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF [/COLOR] |
Member # 102813
In this location.
Sponsored Links |
Permanent Newb
Member # 176672
I don't quite understand but that span looks fine to me.
I wouldn't use threaded rod though. If you can get a hardened bolt that's long enough, maybe 2 short bushings and 2 bolts instead of that one long one?
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question. Peterson's 4 Wheel & Off-road UA2014 Alumni. |
Member # 55444
I cut the flanges off bushings to span the gap between so there is no way for the bushings to pinch and pull into the tube, I also did one that I welded a washer onto the inner sleeve to serve the same purpose. Dosent make me comfortable thinking that it could pull in.
[CENTER]I have Dumb Ideas[/CENTER] |
Member # 120768
Why not use 2 sets of bushings? One at each end of your 10" tube, turned 90* from the way you have it planned. You would then have two shorter bolts and no questions on the bushing span.
OG13 King
Member # 8524
The span is isn't that crucial. Wider has better leverage but sometimes it's too much depending on the rest of the mounts. Motor and trans mounts need to breath together without one taking all the torque.
Whatever the span is, the bolt needs to be accessed. If it's a 10" span, the mounting bolt needs to be pulled through without hitting frame rails etc. Sometimes it's better to work with what hardware is available. A 10" span means a 11-12 inch bolt. Get the bolt first and make everything around it. I don't recommend using all-thread.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Member # 40301
Could you make a new inner steel sleeve that's threaded on both sides and use 2 short bolts on either side? Just a thought.
You can't believe everything you read on the internet. That is how WWI got started. |
Member # 120768
Jr brings up a good point. My trans mount bushings are the same width apart as my motor mounts. If possible, they should be the same or the narrower if the two will do most the work, and promote flex throughout the drivetrain. People get away with different size mounts all the time, but it doesn't make it right.
Thread Tools | |
Display Modes | |
