Braking = foot & knee pain - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-07-2015, 01:00 PM   #1 (permalink)
Member # 157355
braking my race buggy is killing me, I have to fix this but don't know where to start.
After a day trail riding my knee hurts bad and it lasts 2-3 days, the truck ride homes are rough.
After completing one lap last weekend (9 miles of racing) my foot is all screwed up. It hurts, like tendon and muscle pain. It was hard to push my tow rig clutch in the next day.
12" pedal
Wilwood High-Performance Disc Brakes - Pedal No: 340-1287
Dual 7/8 masters
Wilwood High-Performance Disc Brakes - MasterCylinder No: 260-6765
The buggy stops fine its just very hard to push. Front are dual piston ford dana 60 calipers, rear calipers are 3/4 chevy.
Any way to make this easier to brake? Is this an ergonomics issue with my set up?
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
Old 05-07-2015, 01:09 PM   #2 (permalink)
AgitatedPancake's Avatar
Member # 42341
How stiff is the pedal? If it's plenty stiff right now, you can step to one/both smaller master cylinders. Softer pedal, more PSI. What about getting a vacuum or hydraulic booster?
Dovenosed 5 speed WJ on 9"s
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Old 05-07-2015, 01:30 PM   #3 (permalink)
crashinaz's Avatar
Member # 4669
Smaller MCs or a larger pedal ratio. I run dual 7/8ths with 3/4 calipers, but with the CNC 8.7:1 pedal. I would call it a spongy pedal, but the brakes work well and without fatigue.
crashinaz is offline   Reply With Quote Quick reply to this message
Old 05-07-2015, 01:34 PM   #4 (permalink)
Member # 157355
an 8:1 ratio would be easier to push?
Or would changing to a 3/4 bore be a better starting point?
Old 05-07-2015, 01:40 PM   #5 (permalink)
Member # 130492
I've been through this but my solution was not to screw with the pedal. It was the angle of the seat and distance to the pedals that caused the pain.
My foot was at a weird angle due to being too close to the pedals and my foot would start to hurt, then within an hour my leg would be killing me.
Not saying it will solve the issue, as stiffness may be the problem. But its another factor in the equation.
Tnsejed420 is offline   Reply With Quote Quick reply to this message
Old 05-07-2015, 01:45 PM   #6 (permalink)
crashinaz's Avatar
Member # 4669
Yes. You're gaining a mechanical advantage over the masters with the larger ratio pedal and a hydraulic advantage over the calipers with the smaller bore masters. Each is going to net you a softer pedal with a longer travel for any given braking force. The masters are going to be cheaper and won't require any configuration change. I'd order up a couple 3/4s, replace the front and see if you like it. You can judge if you like that direction from there.
Old 05-07-2015, 01:55 PM   #7 (permalink)
Member # 157355
I get full pedal movement, it will go down a long ways when pressed. Its hard to push throughout the full range.
Old 05-07-2015, 02:12 PM   #8 (permalink)
Member # 157355
due to the knee joint and foot joint pain, this was actually what I suspected. the brake is much closer to me, and higher than the gas.
The brake is slightly depressed in this picture BUT it will go almost to the floor, I need to be cautious how and where I move it.
Old 05-07-2015, 02:19 PM   #9 (permalink)
crashinaz's Avatar
Member # 4669
I think the guy in post 5 is more on the right track then... Judging by your pics you're pushing considerably down and forward. My seat to pedal configuration is more along the lines of a sports car where I mostly just push forward. I've got years worth of motocross damage to my knees as well and it's not an issue.
Old 05-07-2015, 02:45 PM   #10 (permalink)
Member # 130492
That's more or less how mine was. I was able to get the pedal pain to stop by changing my seat position so I wasn't pushing down and forward. I found that as the brake depressed my ankle would make a weird move. The brake pedal also wasn't in line with my leg. My theory is that doesn't help either.
By trying to make it more like CrushinAZ's sports car position it got much better.
Old 05-07-2015, 09:18 PM   #11 (permalink)
Member # 30026
Send a message via AIM to beartj
fix the geometry but how about some aleeve twice daily for a day before and a few days after the ride?
er
beartj is offline   Reply With Quote Quick reply to this message
Old 05-07-2015, 09:59 PM   #12 (permalink)
BigBlue&Goldie's Avatar
Member # 113019
..........white people problems.
BigBlue&Goldie is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 12:41 AM   #13 (permalink)
RCKRATZ's Avatar
Member # 2485
Send a message via Yahoo to RCKRATZ
Have you looked into going hydroboost? Some of the setups are fairly large but could help with the amount of pedal pressure needed
Keith Ratzburg aka "El Rolo"
Ratz Racing #4821
Big thanks to the vendors that have helped us out!
Goatbuilt, South Bay Driveline, East Coast Gear Supply, Rugged Radios, 150tunes.com, Pro Comp, Raceline Wheels, FOX Shocks
RCKRATZ is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 06:11 AM   #14 (permalink)
Member # 149176
I'm just guessing here no expert but is just your knee moving when you step on the pedal or is your whole leg, I would think you would want to push with your thigh muscles as if you are standing.
Can you just tilt the master or adjust the pedal way out so you are pushing in more of a downward motion, since you sit so high, so you are more like standing on the pedal using your thigh muscles not just your knee.
Sponsors:
Corbeau, Tom Wood, PSC, Polyperformance, Inner Air Lock, Miller Welds, Heavymetal Concepts, Clayton Offroad, Baileigh
customcreationsllc is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 07:16 AM   #15 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Smaller M/Cs will give you a much easier pedal but it will feel spongy but you'll likely stop easier. Here's a thread I started with good info
https://www.pirate4x4.com/forum/gener...ed-better.html
I had 1" MCs with a 7:1 pedal ratio. Dropped to 3/4" MCs and it was a night and day difference.
You may just be a huge vag and if that's the case you'll never be happy without a true hydroboost setup
Hydroboost Brake Assembly :: Wide Open Design
https://
https://www.facebook.com/diddysbigblockraceshop/
redneckengineered is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 07:46 AM   #16 (permalink)
Member # 157355
I'd prefer a properly set up brake over taking pills...WTF? was that a real suggestion?
Old 05-08-2015, 08:19 AM   #17 (permalink)
Member # 157355
You problem was a hard brake that barely moves. I've got a pretty long range of motion on mine. I wouldn't want to make it any longer at all. Would a 3/4 make my travel longer?
maybe I'm just a vag
Old 05-08-2015, 09:37 AM   #18 (permalink)
Member # 21215
It's possible although it can only travel so far regardless of your master size. I would drop to 3/4 masters. You can always adjust the throw.
https://
Old 05-08-2015, 09:57 AM   #19 (permalink)
crashinaz's Avatar
Member # 4669
You will get more travel going to 3/4. No way around it and you said the pedal already nearly goes to the floor. The thing that MIGHT help is that the hard part of the travel will be further away from you which would mean your leg would be straighter at the point you're standing on the pedal hard... Add the additional braking force and you might have an acceptable work around to your problem even if you have to relieve the floor a bit. As I said before, you can always swap a 3/4 into the front and reevaluate from there.
Old 05-08-2015, 03:47 PM   #20 (permalink)
Member # 1636
I would look more at your seating position than pedal components. Looks like your legs and ankles are bent a lot with your feet on the pedal. I know it's not the easiest solution, but try moving the front of the seat up to support your legs, or move the seat back so your legs are straighter.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 05-08-2015, 03:59 PM   #21 (permalink)
Member # 84361
I'm going with pedal position as well. I glanced at your picture before reading your description and instantly though OUCH. The angle of your ankle looks terrible.
Toy, 4.3, 4l60, d300, tons, 38's, Trail Slut
JHF GB Chassis in progress.
crazybluerider is offline   Reply With Quote Quick reply to this message
Old 05-11-2015, 06:25 PM   #22 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Do you ware heavy steel towed boots while driving? lighter shoes will be less safe but can help with fatigue. If pedal throw is maxed out keep the MC you have and adjust mounting position and angles.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 05-12-2015, 06:54 AM   #23 (permalink)
Member # 157355
That was an early build pic I found, the seat the pedal were mounted, so that angle remains the same. I wear Sparco fire resistance racing shoes, they are pretty light. I do where boots trail riding but the pain is similar with either.
Old 05-12-2015, 07:00 AM   #24 (permalink)
Member # 157355
I will be taking measurements in both my truck and my car. angles, distances, etc. It should give me a good range as one is a 2500 ram and the other is a WRX. I am hoping I can use those measurements and angles as a max/min then adjust things till I fall within those numbers. If I don't have the room, I'll just get as close as I can to them.
A floor mounted pedal might be needed to make it happen. I'll make some changes and update the thread.
Edit - I just had a thought. These general angles and distances have to already been studied and documented. Any thoughts on where one could find them? Maybe the info can help others to not repeat my mistake.
Old 05-12-2015, 11:19 AM   #25 (permalink)
crashinaz's Avatar
Member # 4669
Hope this helps. Here's mine.
Floor to top seat edge - 8.5"
Floor to center of pedal - 7.5"
Seat edge to pedal at rest - 21"
Seat edge to pedal standing on the brakes hard - 27"
I'm 6'2 and I like it.
