Solid Knuckles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2015, 05:30 PM   #1 (permalink)
Member # 110118
Solid Knuckles
Screwed up my passenger side D60 KP knuckle over the weekend. Looking at options and I like how the Solids are keyed, but have heard that there are some issues with fitting brakes and shafts. Any experience with this?
I was thinking of doing the Solid knuckles with the Artec ultimate high steer arms in double shear. Of course I could do the same with Reids, but the Solids are cheaper and given the failure I had I really like the key taking the force rather than just the studs. Don't want to order the Solids and have them not fit, and couldn't find any threads about reviews.
'93 YJ, 60 front w/3-link, 14 bolt rear w/4-link, 39" Krawlers
1993 YJ is offline   Reply With Quote Quick reply to this message
Old 05-26-2015, 06:14 PM   #2 (permalink)
Member # 130927
I run them and my brakes and shafts worked. My Yukon shafts are rubbing the solid c's though
chevcruiser is offline   Reply With Quote Quick reply to this message
Old 05-26-2015, 09:46 PM   #3 (permalink)
homeboy's Avatar
Member # 186874
I had to grind the outter parts of my solid 60 knuckles to fit some 3/4 ton swap brake brackets, the solids have a shit load of extra meat.
one of the best investments I ever did on my buggy. Seen a few broken stock knuckles on the trail.
homeboy is offline   Reply With Quote Quick reply to this message
Old 05-26-2015, 09:52 PM   #4 (permalink)
Member # 55444
https://www.pirate4x4.com/forum/gener...ce-issues.html
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 05-27-2015, 12:42 AM   #5 (permalink)
Member # 161823
Yep grind till the calipers fit
rocks to a jeep are like crack to an addict
gearhead1985 is offline   Reply With Quote Quick reply to this message
Old 05-27-2015, 07:56 AM   #6 (permalink)
kmkommes's Avatar
Member # 34955
I'm running the Ford version on my TJ. I had to grind to get the caliper bracket to fit. It only took about 5 minutes. I contacted Solid about the clearance issue and they told me to grind it. I am running stock shafts so I can't comment there. OEM shafts fit fine.
kmkommes is offline   Reply With Quote Quick reply to this message
Old 05-27-2015, 08:04 AM   #7 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
with the stock GM 1-ton calipers I had to grind a little to get the brake line fitting to clear.
Here is a picture with the 1-ton stock calipers:
And a picture with the 3/4 ton calipers with TMR brackets (same previously ground knuckle but am sure would easily fit this caliper w/o grinding):
MNorby is offline   Reply With Quote Quick reply to this message
Old 05-27-2015, 08:19 AM   #8 (permalink)
Member # 110118
Thanks for the info. Contacted Matt at Solid and he said that they have changed the design from a few year back, but in some instances some grinding may still be necessary. If I end up going this route I will post how it goes.
Old 05-27-2015, 11:41 PM   #9 (permalink)
LastGen's Avatar
Member # 158800
those brake lines
Ultra4 4489
LastGen is offline   Reply With Quote Quick reply to this message
Old 05-28-2015, 05:21 AM   #10 (permalink)
MNorby's Avatar
Member # 11448
Originally Posted by LastGen View Post
those brake lines
Did you have a problem while running those kind of brake lines?
