PS reservoir mount input needed... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2015, 03:10 PM   #1 (permalink)
Member # 111580
Ok, the PS pump is mounted pretty high on my engine because of how tight the chassis is to the engine down lower, the issue I am running into is getting the reservoir up high enough. this is what I ended up mocking up.
the question I have is will this give me enough height above the inlet of the pump to keep it happy, or am I going to have starvation issues?
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 05-31-2015, 03:14 PM   #2 (permalink)
Member # 103621
As long as its a straight shot to the pump, I don't see an issue with it being short, or even shorter than that. Ive seen some plumb the reservoir pretty much straight into the pump inlet with only 3" of hose split between each fitting. Those, however, were all engine mounted though so everything moved together. If you are mounting it to the chassis, I would use more than that to take up for the movement of the engine (even though it should be minimal)
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 05-31-2015, 03:26 PM   #3 (permalink)
flatblack51's Avatar
Member # 121033
gravity is king. the second you go vertical your pump is going to starve the way you have it.
Thank you to My sponsors:
Pro Comp tires
PRP Seats
Maximum Transmissions
Goatbuilt
Trail Ready Beadlocks
Yukon Gear and Axle
ADS Racing Shocks
WARN Ind.
Socal Print Shop
Broadsword Racing
#4889
flatblack51 is offline   Reply With Quote Quick reply to this message
Old 05-31-2015, 03:27 PM   #4 (permalink)
Member # 111580
Yes, I can rotate the inlet of the pump, and it will be almost a direst straight shot to the reservoir. I'm worried that when I am climbing something the pump is going to run dry, but there is a lot of fluid in the resi.
BUCK OFAMA
4 seater LS1 buggy
Old 05-31-2015, 03:28 PM   #5 (permalink)
Member # 111580
There is simply no option to mount it like you have it. The pump barly clears the chassis as it is, and if I put the resi any higher it will be sticking through the hood...
BUCK OFAMA
4 seater LS1 buggy
Old 05-31-2015, 03:28 PM   #6 (permalink)
Member # 121033
Your best bet is to get a bracket to drop your pump lower on the motor not to pricey and you can thank me later. goatbuilt has the bracket you'll need
Pro Comp tires
PRP Seats
Goatbuilt
Yukon Gear and Axle
ADS Racing Shocks
WARN Ind.
Socal Print Shop
Broadsword Racing
#4889
Old 05-31-2015, 03:30 PM   #7 (permalink)
Member # 121033
Mines going to be close to the hood even as it sits now. If you have to relocate a tube to make it work so be it. My shocks didn't fit with my chassis so I had to cut out a tube i'll get it back in there eventually but car was made for 2.0's. Also the pump is up against the block pretty good the headers we have actually stick out farther.
Pro Comp tires
PRP Seats
Goatbuilt
Yukon Gear and Axle
ADS Racing Shocks
WARN Ind.
Socal Print Shop
Broadsword Racing
#4889
Old 05-31-2015, 03:31 PM   #8 (permalink)
Member # 111580
I can't put the pump lower, I had the rock tactics setup that puts it in the same place, it's not even remotly close to having enough room to make that work... I may need to look into another type of reservoir maybe...
BUCK OFAMA
4 seater LS1 buggy
Old 05-31-2015, 07:06 PM   #9 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
Best pic I could find of mine but I have never had a problem with it. The res is mounted pretty high and sticks through the hood but its well below my sight line.
MNorby is offline   Reply With Quote Quick reply to this message
Old 06-01-2015, 06:09 AM   #10 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
Here's what I came up with on my 73 Bronco.
It's worked great.
TAWL_BOY is offline   Reply With Quote Quick reply to this message
Old 06-01-2015, 09:55 AM   #11 (permalink)
Member # 145218
I would do what ever you can to move the pump down and get the res above the pump , the way it's is it will starve when the rig is pointed up hill
johny5.0 is offline   Reply With Quote Quick reply to this message
Old 06-01-2015, 02:19 PM   #12 (permalink)
Member # 97574
The new Insane Racing Formula Offroad car's setup.
https://www.facebook.com/groups/OFFROADCNCFILESHARING/
ROXROES is offline   Reply With Quote Quick reply to this message
Old 06-01-2015, 03:09 PM   #13 (permalink)
Member # 53528
if you cant move the pump down or the reservoir up then i would move the reservoir closer to the pump so it wont starve for fluid on a steep hill as easily as it will with where its at now.
Old 06-01-2015, 03:12 PM   #14 (permalink)
Member # 53528
that thing looks like its even worse then the OP setup, how is that thing not gonna starve when going up a steep hill?
Old 06-01-2015, 03:26 PM   #15 (permalink)
Member # 104966
Mine is snuggled in about as tight as possible, but it works awesome and doesn't starve on climbs.
bbaxter51 is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 06:22 AM   #16 (permalink)
Member # 97574
That's exactly my point, but it works.
Old 06-02-2015, 06:40 AM   #17 (permalink)
MNorby's Avatar
Member # 11448
Is that formula 4x rig a pressurized setup?
Old 06-02-2015, 07:22 AM   #18 (permalink)
Member # 51335
Just for the record, that Formula 4X set up isn't working. Short pump life. Very short.
LG
[COLOR="Red"][SIZE="4"][B]Official Steering of King of the Hammers![/B][/SIZE][/COLOR]
[SIZE="4"][B]817-270-0102[/B][/SIZE]
PSC Motorsports is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 08:21 AM   #19 (permalink)
Member # 97574
LG
I was wondering, was trying to dig up the post they had on here and I remember some comments in regards to that.
Old 06-02-2015, 08:30 AM   #20 (permalink)
Member # 66173
on a side note, I am facing the same issue on my jeep but I got my res. mounted much closer to the pump. On the new style PSC res. what is the AUX port for? Can you use it piggy back a 2nd res for more capacity?.
2000 XJ
jonzer12 is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 08:47 AM   #21 (permalink)
Member # 51335
Aux=Hydro boost, and some race applications with ext pressure bypass valves.
LG
Old 06-02-2015, 10:49 AM   #22 (permalink)
Member # 111580
LG
My pump has 2 feed ports (I believe) can I plumb the aux to the second feed port and would it make a difference? What is your opinion on the setup I posted?
BUCK OFAMA
4 seater LS1 buggy
Old 06-02-2015, 01:14 PM   #23 (permalink)
RCKRATZ's Avatar
Member # 2485
Send a message via Yahoo to RCKRATZ
Height wise my setup is about the same, although i mounted the reservoir almost right on top of the pump. Has been fine to date.
Keith Ratzburg aka "El Rolo"
Ratz Racing #4821
Big thanks to the vendors that have helped us out!
Goatbuilt, South Bay Driveline, East Coast Gear Supply, Rugged Radios, 150tunes.com, Pro Comp, Raceline Wheels, FOX Shocks
RCKRATZ is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 05:23 PM   #24 (permalink)
Erics Tacoma's Avatar
Member # 169872
I don't have a super cool buggy like you guys, but I've ran into the same problem. So... I moved the PS pump.
Original position is literally at the same height of the top of the engine. I made a bracket that used the original PS mount and welded it together and then bolted that piece to the stock mounts on the alternator.
And put it pretty low now.
Don't mind the bungies, gotta do whatcha gotta do right?
Position it would of been in if I kept pump there... Clearly way to high and through the hood
New position
2000 XtraCab 2.7L 4x4 3-Link, Supercharged, Won Tons.
Erics Tacoma is offline   Reply With Quote Quick reply to this message
Old 06-02-2015, 10:34 PM   #25 (permalink)
Member # 102813
Why don't you just make your own Rez?
You would think that the aftermarket crowd would understand the issues that a tall narrow rez presents and have other shorter/wider/baffled options.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
