holesaw tire cutter - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-03-2015, 01:34 PM   #1 (permalink)
ZAG
ZAG's Avatar
Member # 14113
holesaw tire cutter
bit hack job but
took old hole saw and grinded the teeth out and sharpened edge from inside.
cuts lugs from boggers pretty easy.
ZAG is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 01:44 PM   #2 (permalink)
Member # 481234
Fuck it, looks a lot faster than other techniques I've seen. Depth of the saw is an issue. Could you open a side slot more to kind of eject/trim off each cut? Or adapt a piece of tubing to give it a deeper throat to make one continuous lug pass?
[QUOTE=DirtRoads;44405898]All you need to go wheeling is a credit score these days[/QUOTE]
Juicysluice is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 01:50 PM   #3 (permalink)
Member # 62420
It looks like it does the job. I like the oscillating tool the best for lug removal though.
"wtf is elwenil?" -odd dodge
driver351 is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 05:25 PM   #4 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
With a deeper hole saw you could take off a "hole" lug at once
guidolyons is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 05:46 PM   #5 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
looks like a solid way to do it. i like the depth you are able to cut with the hole saw. i would worry about it easily getting away from me if it had a longer cutting head aka more leverage. to avoid having to stop and fiddle with the lug chucks how about using a cut-off wheel to pre-split the lugs to be removed so you can use the hole saw to cut the lugs basically non stop other than shaking out the freshly removed lug chunks. keep up the great tool builds
carslut is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 06:11 PM   #6 (permalink)
Member # 91399
Seen an electric limbing saw used too. More of a mess but works fast.
Jackel is offline   Reply With Quote Quick reply to this message
Old 06-04-2015, 06:59 AM   #7 (permalink)
finally fuckin in
sterlingfire's Avatar
Member # 232666
This is a great idea Imo. Like said above, the longer hole saw might get away from you. But instead of cutting vertically into the lugs with a cut off wheel, couldn't you just cut vertically into the lugs with the hole saw? Then the length of lug you cut horizontally would fit into the hole saw.
sterlingfire is offline   Reply With Quote Quick reply to this message
Old 06-04-2015, 09:20 AM   #8 (permalink)
Member # 481234
Yeah, that sounds better. Last thing anybody wants it out of control rotating equipment. Zag, I'm giving this a try when it comes time to buy the first set of tires for my buggy
Old 06-04-2015, 09:29 AM   #9 (permalink)
ZAG
ZAG's Avatar
Member # 14113
i wound when i reach hole saw depht just tilt the saw upwards and it will cut the piece off and slings it away.
Old 06-04-2015, 12:27 PM   #10 (permalink)
ZAG
ZAG's Avatar
Member # 14113
took 10kg/22lbs rubber out off 37" boggers.
hole saw worked great. didnt even try to cut the bottom smooth just made 3 passes for lug to leave some texture there.
