Help with broken camber kit piece - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-11-2015, 06:52 PM   #1 (permalink)
Member # 217684
So the d44 on my H3 had a little too much camber, 1.5 degrees on the passenger side and 1/2 degree on the driver's side. The kit comes with two pieces, a hollowed out piece you screw into the bushing area and a tapered shim.
I was trying to back out the old threaded piece and it snapped inside of the axle. What the hell do i do? The picture is the new part, but it is the same as the piece that broke inside of my axle
07custom is offline   Reply With Quote Quick reply to this message
Old 06-11-2015, 08:06 PM   #2 (permalink)
Member # 145867
i have dealt with this before.
if you can get a bolt that fits inside the broken piece and weld the bolt to the broken piece then finish removal.
if the broken piece is completely inside the inner c. then get the dremel out and make sut it in to little chunks and break it out.
third get a big easy out or left handed drill bit.
you can also heat around the stuck piece and hope you can then spin it out with pliers
WTB: heims/johnny joint/uniball 2-5/8 wide 1.25 shank with misalignment spacers pm me if you have some you dont need
devuurstorm is offline   Reply With Quote Quick reply to this message
Old 06-11-2015, 08:22 PM   #3 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Drive it around with chisel or driver.
Dremel.
Hacksaw blade
Keep driving with the prong socket
High explosives.
Weldercate it
Old 06-29-2015, 08:01 AM   #4 (permalink)
Member # 217684
So guys, I literally cannot get this thing out. I've tried the hammer/chisel/screwdriver method and it's doing nothing. I soaked it with PB blaster and it isn't budging one bit. I'm not sure what to do from here but this +1.5 degree camber is messing up my tire quick. I have a road trip soon and need to sort this out.
I just keep pounding on it and it's doing nothing but eat up the sleeve. Frustrating!
Old 06-29-2015, 08:39 AM   #5 (permalink)
Member # 188740
Try some heat and then the hammer/chisel/screwdriver method.
rotun is offline   Reply With Quote Quick reply to this message
Old 06-29-2015, 09:02 AM   #6 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
[QUOTE=07custom;32287505
I just keep pounding on it and it's doing nothing but eat up the sleeve. Frustrating![/QUOTE]
Thats the point. Break it. Its far beyond a slavageable peice. Wreck it and get it the fuck out. Get a hack saw blade and cut it in to sections and keep chisling.
Old 06-29-2015, 09:11 AM   #7 (permalink)
ZAG
ZAG's Avatar
Member # 14113
weld some mig beads around the inside. it will shrink it and loosen up
ZAG is offline   Reply With Quote Quick reply to this message
Old 06-29-2015, 09:14 AM   #8 (permalink)
Member # 428418
this works well, also useful for removing blind hole bearings
dropitlow88 is offline   Reply With Quote Quick reply to this message
Old 06-29-2015, 09:31 AM   #9 (permalink)
Member # 217684
but it's all the way in there still, all the way down. hasn't budged.
I'm afraid I'm going to mess up the threads that it goes into, making it impossible to use the camber adjustment sleeve kit I bought? Won't welding in there melt the threads or something?
I'm new to this guys, so sorry for the unreasonable worries/questions.
Old 06-29-2015, 09:33 AM   #10 (permalink)
Member # 217684
I can't back it out enough (at all) to get more than a thin flathead screwdriver in there...
Old 06-29-2015, 10:03 AM   #11 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Welp i guess youre just fucked then, scrap the axle and start over.
Old 06-30-2015, 07:20 AM   #12 (permalink)
Member # 11928
DRILL IT OUT OR CUT IT OUT WITH A TORCHIF YOU JUST HEAT THE INSERT IT WONT CUT THE THREADS IN THE C, OR IF YOU USE A DRILL JUST UNDER THE HOLE SIZE IN THE C AND USE A PUNCH TO PULL OUT THE REST THEN GET A TAP THE SAME AS THE C AND CLEAN THE THREADS. YOU DO HAVE THE BALL JOINT OUT CORRECT?
BUCKWILD 66 BRONCO F/W 60'S 538'S ARB DETROIT
BUCKWILD is offline   Reply With Quote Quick reply to this message
