DANA 745 axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-01-2015, 11:44 AM   #1 (permalink)
Member # 101407
DANA 745 axle
Anybody have any input on these? They appear to be comparable to an Axletech. Trying to figure out if these are worth pursuing at work here. May be able to pick them up for scrap.
Elvis38 is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 11:45 AM   #2 (permalink)
Member # 103621
Whats on top of the diff? Im not too familiar with HD axles such as these.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 11:50 AM   #3 (permalink)
Member # 328810
Looks like they come out of construction equipment, guessing military construction equipment. That's really all I can find at the moment.
JKTweak is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 11:50 AM   #4 (permalink)
Member # 328810
looks like it pivots on that. you can see the stops next to it
Old 10-01-2015, 11:56 AM   #5 (permalink)
Member # 101407
Yeah, Intended for a front wheel assist tractor.
The print says they weigh 1190lbs(540KG) . Trim off the Unicorn horn and a few other little casting pieces, they're not much heavier than a 60.
Old 10-01-2015, 12:26 PM   #6 (permalink)
Member # 145175
Buy them for scarp price, dick with them to see if you want them. If they turn out to be turds, then sell them for scrap price with the satisfaction seeing what they are all about. I would guess that they would make a great axle for a trail rig with the exception of custom wheels unless they are too wide - most of the 'tractor' housings are cast like this and very tough to cut down and still be reliable. Tough to see the size without something familiar int he pictures.
We build stuff
AnySevenOffroad is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 02:26 PM   #7 (permalink)
Member # 101407
Outside portal box is 2196,(86.5") Wheel surface is 1892(74.5") Has "Gruppo Dischi Blocco" which based on my awesome Italian and Google. Must be a locker of some sort.
I want them. Gonna push to make it happen, they've been sitting around awhile.
Old 10-01-2015, 02:30 PM   #8 (permalink)
Ho Shorts's Avatar
Member # 109328
Get them for sure. 2.5 ton rocks are 79" WMS unless you flip the hubs so width isn't an issue.
Would be curious about gear ratio though being from equipment they could be in the 10.26 to 1 area. Worst case scenario you can run a 1 to 1 transfer case though.
I had a clogged sewer pipe. After cutting the pipe, reaching in past my elbow, and removing the obstruction; about 12lbs of shit started flowing. Bits of corn and peanuts washed over my neck, down my shirt, some even got in my mouth.
It was still a better experience than buying from Ballistic Fab
Ho Shorts is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 10:13 PM   #9 (permalink)
Under Powered
onlyonedr's Avatar
Member # 19543
Are the 60s you run encased in concrete or something? Stock trim early HP60s were in the mid 400# range, the GMs were just over 500#. Or so says the 60 bible. My AxleTech Portal equipped 60 and 14B together probably weigh just a little more than one of those things.
And those are planetaries, not portals.
'01 Nissan KC Desert Runner: Work in Progress
'69 Chevy K5: Non-Wheeling Fun Rig
NOAS Club Membership Coordinator and Treasurer 2016-2017
onlyonedr is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 10:26 PM   #10 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Yup. Skyhook/gradeall boom lifts use a center pivot with a single. Ram mounted to one corner for suspension.
The gm mil tugs use a similar center pivot axle mount
Old 10-01-2015, 10:28 PM   #11 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
No doubt its north of 10:1. Some planets are 22:1
Old 10-01-2015, 10:42 PM   #12 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Could the thing on the top be brake related?
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 10:45 PM   #13 (permalink)
Member # 55444
Scrap is what, .03/lb right now?
$36/axle I'd jump all over it
Should be wet discs, and the integrated ram is handy. Doesnt look like as much steering angle as the axletechs, but as long as the parts arent too expensive, doesnt seem like a losing proposition.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 10-01-2015, 10:57 PM   #14 (permalink)
Member # 328810
you know, we have a navy tug at work. I forget the real name, but we call it the Buddha. We decommissioned them a few years ago. For moving c40's c130's etc. It's had the front end cut off so the axle is sitting there, ill have to see if it is the same. IIRC it had 2 rams for steering and has a ton of steering angle so it may be different.
They still run and at upwards of 30k lbs they are fun to run into other trashed vehicles.
Old 10-01-2015, 11:10 PM   #15 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
I cant say that ive seen a shaft driven axle do it but the hydro drive wheel hubs can pigeon toe the tires and and do a nearly zero radius.
Old 10-02-2015, 02:17 AM   #16 (permalink)
Member # 120446
I will get some pics at work later, but those are similar to the axles on the MB4 aircraft tugs. They have double cardan steering joints, 4 wheel-full hydro steering, planetaries, a 6.7L cummins 6BT, some kinda hydrostatic transmission and 6" thick bumpers.
cajunrebel is offline   Reply With Quote Quick reply to this message
Old 10-02-2015, 04:20 AM   #17 (permalink)
Member # 101407
Checkin the print here... Differental Multi Disc, Bevel gear set 13/30, Bevel gear ratio 1:2.37, Final reduction 1:6.00 and Total ratio 1:13.846
Old 10-02-2015, 04:37 AM   #18 (permalink)
jemarshall's Avatar
Member # 50690
Send a message via MSN to jemarshall
.024 here this week , I usually use it as rat hole money that I get from cleaning up around the shop but at that price its not even worth the time and money to haul it in.
jemarshall is offline   Reply With Quote Quick reply to this message
Old 10-02-2015, 10:02 AM   #19 (permalink)
Member # 55444
Yup. It costs me more to have a bin here than I make in the steel. I shouldnt have to pay to get rid of steel
Old 10-02-2015, 10:57 AM   #20 (permalink)
Member # 328810
Kinda like this
Old 10-02-2015, 06:00 PM   #21 (permalink)
Under Powered
onlyonedr's Avatar
Member # 19543
To do this the wheels on opposite ends of the axle have to rotate in opposite directions. Check out the Jeep Hurricane concept from a few years ago to see a way to do it with shaft drives (but not a single solid axle at each end).
Old 10-02-2015, 08:27 PM   #22 (permalink)
Member # 328810
Are we talking about the same thing? I noticed I can turn the pinion yoke very easily, with one finger. The hubs do not spin when I turn it.
This is literally all in a trash pile and will stay here until the navy writes a contract with someone to come haul it away for scrap. I could go to jail if I made the motor disappear. It's still pretty tempting.
Old 10-03-2015, 03:38 PM   #23 (permalink)
Atomic Test Lab Rat
Member # 25325
You won't do it you bitch....haha
IDI F250 Crawler
redranger4.0 is offline   Reply With Quote Quick reply to this message
Old 10-03-2015, 08:08 PM   #24 (permalink)
Member # 328810
I transfer in march, you think if I take one part a day until then that I could end up with a whole motor?
Old 10-03-2015, 10:19 PM   #25 (permalink)
Member # 105936
Yes
https://www.youtube.com/watch?v=rWHniL8MyMM
OC IH is offline   Reply With Quote Quick reply to this message
