New Maxxis Razr MT - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2017, 04:52 AM   #51 (permalink)
Member # 151742
I still love mine. About 4500 miles on them at this point and I've rotated them once and they seem to be wearing well.
MOD....WHEEL....BREAK....REPEAT
Μολὼν λαβέ
Militaryman4455 is offline   Reply With Quote Quick reply to this message
Old 04-07-2017, 06:21 AM   #52 (permalink)
Member # 83301
meh, but how are they offroad?
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
pennsylvaniaboy is online now   Reply With Quote Quick reply to this message
Old 04-11-2017, 01:55 AM   #53 (permalink)
Member # 151742
Well... I don't crawl my '14 2500, so I can't give you any input from that front. But they do pretty good on wet grass at my property
Μολὼν λαβέ
Old 04-11-2017, 08:34 PM   #54 (permalink)
Skinny Pedal Racing's Avatar
Member # 556170
Is your 2500 a diesel (asking because of weight) and how do they do with towing? My F250 really needs new tires bad and I have been looking at these.
Contact us for any project that you have: truck, jeep, or buggy.
Skinny Pedal Racing is offline   Reply With Quote Quick reply to this message
Old 04-13-2017, 09:19 AM   #55 (permalink)
Member # 91399
Kinda curious why would you put these on your daily driver if they don't see dirt? Seems very unnecessary.
Jackel is offline   Reply With Quote Quick reply to this message
Old 04-13-2017, 11:17 PM   #56 (permalink)
RSL
Member # 35895
'Murica!
RSL is offline   Reply With Quote Quick reply to this message
Old 04-14-2017, 02:51 AM   #57 (permalink)
Member # 151742
Yes. They're great. That was one of the main reasons I went with them. They have the proper ratings for an 8K lb truck with 37" tires and 17" wheels.
It does see dirt. I just don't wheel it. Why would you buy a car that can do 160mph if all the speed limits are well below that? Because I can and I'm not poor.
Originally Posted by RSL View Post
'Murica!
Also, this.
Μολὼν λαβέ
Old 05-16-2017, 04:52 PM   #58 (permalink)
caryt's Avatar
Member # 27775
OK someone has to have tried these 40x13.50R17LT, Razr MT Tire by now?
I've got trail grapplers now..so curious how they compare, street and esp trail.
caryt is offline   Reply With Quote Quick reply to this message
Old 06-02-2017, 09:26 PM   #59 (permalink)
Member # 75827
Bump, I wanna know how the 40s wheel too...
Sent from my SM-N920V using Tapatalk
eggus is offline   Reply With Quote Quick reply to this message
Old 08-21-2017, 11:56 PM   #60 (permalink)
Member # 623849
Some time running 40s Load Range C
I bought these tires a month ago and have a few wheeling trips under my belt now so posting up some preliminary data.
Running the 40X13.50R17LT Load Range C on 17 Inch Trail Ready HD series Beadlocks. Running under a 5700Lb 2012 JKU.
Install Observations:
They were surprisingly light compared to my old 35x17 Toyo Open Country. In fact carrying one in each had the 40 and the 35 they felt about the same in weight. The unmounted Maxxis was definitely softer feeling in tread and carcass but the load rating differences probably has a lot to do with that.
Mounting was easy enough. They mounted fine. I did not balance them but the balance has been decent. I have run them over 80MPH hundreds of miles over several wheeling trips and no noticeable vibrations or tread wear.
I have covered loose dry terrain, rocks, and stumps. No snow or mud yet.
The contour very well to the terrain and grip very well. I almost never slip on terrain short of being hung up or climbing in significant loose dirt.
They do not chunk as advertised but I do see some small chipping in a few spots. Its a trade-off I am willing to make to run a softer tire than the Toyo.
seaj is offline   Reply With Quote Quick reply to this message
Old 08-22-2017, 12:15 AM   #61 (permalink)
Member # 623849
Below is a few short videos of them in use recently. Not allowed to post links yet so this is the best I could do. Copy and remove the space after https :// if you want to see them.
https ://goo.gl/photos/YpxXPPMjD5gdi3zM8
https ://goo.gl/photos/FkNnEcG2W5ErkWGQ8
https ://goo.gl/photos/3CuRd8PVPL8zsLYaA
Old 08-23-2017, 06:22 AM   #62 (permalink)
matzell's Avatar
Member # 42081
Not sure if anyone else has these on sale but I just bought a set from my local supplier for $1300. 40 x 13.50 x 17. set of four. I was looking for some trail riding 40's and this deal came up. You guys may want to check with your local suppliers but for some reason mine were cheap. I even had the guy check with his manager to be sure price was correct. He called me back and said yes!
Rob Matzell
2014 4WD EASTERN 4500 CLASS CHAMPION
EMC 2013,14, 15, 16, 17
Matzell Motorsports #4573
Thanks to: Weldone Fabrication, Maxxis, Fox, PRP, PSC, Raceline, Reid Racing, Ruffstuff, Willow Lawn Service Center, JB Custom Fab, Yukon Gear, Dynomax, 150tunes.com,Lugnut4x4
matzell is offline   Reply With Quote Quick reply to this message
Old 08-23-2017, 06:54 AM   #63 (permalink)
Member # 111955
Who is your supplier?
tbuff02 is offline   Reply With Quote Quick reply to this message
Old 08-23-2017, 07:42 AM   #64 (permalink)
matzell's Avatar
Member # 42081
I buy from a wholesaler. PM me and I can get you a set. I do not want to clog up this thread with selling tires. I did not check on other sizes just 40's.
Rob Matzell
Old 10-11-2017, 06:37 AM   #65 (permalink)
Member # 83301
anyone have some trail time on these...they are a really competitively priced 40'' tire.
Old 10-11-2017, 05:19 PM   #66 (permalink)
matzell's Avatar
Member # 42081
[INDENT]Worked great in red clay, smooth rocks and loose dirt here in Virginia. Wet rocks and creek crossings were no problem, even wet climbs coming out. I will have them out at Rausch Creek and AOAA this weekend. I expect they will do well. I had them at 12 psi.
Rob Matzell
Old 10-11-2017, 07:56 PM   #67 (permalink)
generalee7's Avatar
Member # 16522
Hows the road noise compared to Toyos? I know Toyos are essentially silent.
generalee7 is offline   Reply With Quote Quick reply to this message
Old 10-15-2017, 02:32 PM   #68 (permalink)
matzell's Avatar
Member # 42081
I have 4 trips out on these tires. Two in Virginia, two days in PA at Rausch Creek and AOAA park. Tires are holding up great with no real chunking. I went everywhere by buddy's went on red label Krawlers. Now they are not sticky but warm then up a little and they hook right up. The red labels had to heat up some before they worked on the wet rocks as well.
Rob Matzell
Old 12-18-2017, 11:57 AM   #69 (permalink)
Member # 83301
@matzell can you get a measurement of these on your buggy mounted....please with PSi and rim width....I really like the tread block of these i compared to most other 40s
Old 12-18-2017, 06:13 PM   #70 (permalink)
matzell's Avatar
Member # 42081
The car is in the trailer. I will try to get out to it and get some mesurements.
Rob Matzell
Old 12-18-2017, 06:33 PM   #71 (permalink)
Member # 556170
I just bought some for my truck and look forward to them, 08 f250.
Sent from my SM-G935V using Tapatalk
Old 12-19-2017, 05:35 AM   #72 (permalink)
Member # 83301
See this is what I fear with nittos, coopers, maxxis razr, and procomp mt2......guys are running them on tow rigs, so do I really want to put them on a trail only vehicle.....versus a swamper or trep, or creepy....but none of those are in the same price range either.
Old 12-19-2017, 05:58 AM   #73 (permalink)
Member # 556170
Like you stated, price. I run a 35x12.5x20 and with the factory 20" wheel, it makes the price a little higher. I happen to get them on sale but it was on of the tires I was looking at anyways.
I wouldn't necessarily worry what a tow rig runs in considering what to run on your rig.
From what I hear, they are selling pretty well. I was going to get my brother to get them for his truck but witg his factory 20" wheel, you can only get these tires down to a 35" and he was looking at a 33".
Old 12-19-2017, 06:31 AM   #74 (permalink)
matzell's Avatar
Member # 42081
I am sure you wheel the same type of terrain that I do on the East Coast. Shirley and Gilstrap have good things to say about them as well on their race cars. Shirley sr has a set on his Jeepster and loves them. I do not thing you can go wrong for the price. Now if you really want to pay $$ get a set of sticky treps.
These hold the line and side hill better than Treps in my opinion if that is worth anything.
Rob Matzell
Old 12-19-2017, 09:23 AM   #75 (permalink)
Member # 83301
So i know you are sponsored by maxxis, but why pick the razr over all the other tire choices(even within the maxxis line)?
