Project OVERDOSE: Bent Fab 2" AT EVO 2 Coupe - Page 14 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-09-2019, 08:48 AM   #326 (permalink)
Member # 129055
One of my favorite buggy builds for sure, love seeing updates.
https://www.pirate4x4.com/forum/chevy/2575401-damn-blue-chevy-2003-silverado-build.html
mccustomize is offline   Reply With Quote Quick reply to this message
Old 01-09-2019, 10:16 AM   #327 (permalink)
Boomtacoma01's Avatar
Member # 139434
Looks Good Scott. Are you going to make opening weekend at K2?
1985 Xtra Cab - 22RE, 39" Red Labels, D60, 14B, 3 Link/4-Link, A340F, Atlas II 4.3, Lone Star Light....
2017 Ram 2500 Crew Cab 4x4, 6.7 tow rig
IG: @boomtacoma01
-Chris
Boomtacoma01 is offline   Reply With Quote Quick reply to this message
Old 01-09-2019, 10:50 PM   #328 (permalink)
scottapher's Avatar
Member # 126355
Thanks man! I hope to have some better wheeling videos soon.
Unfortunately I have a prior family commitment...I cannot believe I haven’t had this thing out to K2 yet!
Bent Fabrications Evo 2 Coupe
IG: @RxOffroad
scottapher is offline   Reply With Quote Quick reply to this message
Old 01-12-2019, 06:52 PM   #329 (permalink)
What do I do now?
bhat's Avatar
Member # 771225
Love the build, if it wasn't for being street legal I would have also went the BFR route. Anyways, based on the suspension videos it doesn't look like you're getting into the bumpstops much but wondering if you've played with the pressures in them at all? Front or rear?
bhat is offline   Reply With Quote Quick reply to this message
Old 01-13-2019, 08:17 PM   #330 (permalink)
scottapher's Avatar
Member # 126355
In that video I only get into the rear bumps twice, mainly due to just bombing around the pasture and lots of travel.
I have the bumps at 250 I think? Maybe 300. I feel the front bumps could use some pressure; the rear seem to work great. I need to invest in a no-loss chuck before we get all scientific and all
IG: @RxOffroad
Old 01-14-2019, 11:29 AM   #331 (permalink)
What do I do now?
bhat's Avatar
Member # 771225
You're not kidding about the no-loss chuck, I did not figure it would be THAT sensitive to a regular chuck! Took me a couple go-arounds to figure out why the pressure kept dropping 40-50psi between checks!
Old 01-14-2019, 11:55 AM   #332 (permalink)
scottapher's Avatar
Member # 126355
I guess now that you brought it up I need to buy one...I filled all of my suspension without one
Here is a long video of my and a buddy tearing through a local Offroad park. Some jumps and high speed stuff around the 8-9 minute mark.
IG: @RxOffroad
Old 03-13-2019, 04:44 PM   #333 (permalink)
scottapher's Avatar
Member # 126355
Update:
The Ruffstuff trailing arms are just too large/deep for this car and I have been getting hung up a bit too much on them. They are a good product and went together well when I welded them, but just too large and bulky.
I had left +1.5” of shock shaft showing at full compression when I originally set the rear up. I did this thinking I might get into that portion of travel when the car was articulating. The bump cans are inboard of the arms/shocks and I assumed incorrectly that this last portion of travel would be useable.
In come the straight trailing arms. I ordered up some 2.5” OD .25w chromoly tubing, some solid 2” 7075 bar, and some TMR anti-wobble joints.
Since the OD of the aluminum was a few thousandths larger than the ID of the chromoly I had to get creative. I don’t own a lathe, and it is like pulling teeth in my town to get a one off item machined.
Further, since I didn’t want to sacrifice up-travel, I decided to notch the tubing to set the shock eye lower “into” the arm. Doing so allowed my original setup to utilize the last 1.5” of travel I had left on the table.
Super strong; super low profile. I’ll let the pictures do the talking from here.
IG: @RxOffroad
Old 03-13-2019, 04:47 PM   #334 (permalink)
scottapher's Avatar
Member # 126355
IG: @RxOffroad
Old 03-13-2019, 04:50 PM   #335 (permalink)
scottapher's Avatar
Member # 126355
IG: @RxOffroad
Old 03-13-2019, 07:03 PM   #336 (permalink)
Member # 159557
Digging that notch idea.
JETHROBODEAN is offline   Reply With Quote Quick reply to this message
Old 03-14-2019, 08:54 AM   #337 (permalink)
Member # 83301
sooooo how did you get the aluminum in the steel? the look like they would not roll as much with the notch, compared to other over the center trailing arms.
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 03-14-2019, 08:56 AM   #338 (permalink)
Member # 188843
Your arms are very cool !
I went with the BKOR trailing arm kit and let Tim modify the chassis side to fit the big anti-wobble cup.
I'm interested in your feedback on this. I would like to keep the bumpstops inboarded, like you, and was wondering how much bump travel do the shock really have after the bumps are compressed.
Here is what I'm envisioning :
Bump stops in red, bump pad in blue, inboarded (about 6-8") from the heim which is the pivot point.
This is full bump :
Bebop is offline   Reply With Quote Quick reply to this message
Old 03-14-2019, 08:50 PM   #339 (permalink)
scottapher's Avatar
Member # 126355
I used a belt sander, and jigged it up all fancy like and used a drill to spin the aluminum while I took some material off. I used a micrometer to intermittently check where I was at. Then I beat the aluminum into the steel with some time and muscle.
IG: @RxOffroad
Old 03-14-2019, 08:54 PM   #340 (permalink)
scottapher's Avatar
Member # 126355
Right now, there are maybe a few c-hairs before the rubber pad around the shock shaft hits the shock body. I had 1.5” of shaft showing before and it was unused travel.
IG: @RxOffroad
Old 03-14-2019, 09:50 PM   #341 (permalink)
DiscoDino's Avatar
Member # 15296
Great and simple idea to the trailing arms...you should do a kit and sell...it's smart and simple and can be done easily in the home garage or at the pro shops...
'83 D130: 54" TTCs or 42.5" Boggers, OEM RW2.5s, Stazworks, LQ4, Atlas, dual M8274-50s, mid-mounted 9.5xp-s, dual 16" ORIs, PRP seats, etc...
'91 D110: 36" Iroks, R380, 2wd conv, underdrive, ARBs, 30 spl front, Sal D60 rear, caged, Fox remote reservoirs, M8274-50, and P&P exo-cage, etc...
DiscoDino is offline   Reply With Quote Quick reply to this message
Old 03-14-2019, 10:38 PM   #342 (permalink)
scottapher's Avatar
Member # 126355
I think TMR or Jake Burkey (spelling?) sell something nearly identical without the notch’s, chromoly tubing, or as low of a shock mount. Honestly, these were born out of necessity; time will tell how they hold up.
IG: @RxOffroad
Old 03-15-2019, 09:05 AM   #343 (permalink)
Member # 188843
Thank you for the info.
Old 03-18-2019, 07:30 AM   #344 (permalink)
scottapher's Avatar
Member # 126355
The new straight trailing arms were a BIG improvement. Next step is upgrading the rubber this thing rides on.
IG: @RxOffroad
Old 03-18-2019, 12:25 PM   #345 (permalink)
Member # 127171
She sounds mean, I can't wait to see it with some stickies.
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 03-25-2019, 08:43 AM   #346 (permalink)
scottapher's Avatar
Member # 126355
Me either, I am impatient and pulled the trigger on some BFG KR3-S tires this past week.
I should have gone comp compound a long time ago! Here is a short video going up Royal Gorge at Hidden Falls. Ran it a few times where I have been previously denied.
IG: @RxOffroad
Old 03-25-2019, 09:55 AM   #347 (permalink)
Member # 139434
Big baller!!
IG: @boomtacoma01
-Chris
Old 03-25-2019, 10:08 AM   #348 (permalink)
scottapher's Avatar
Member # 126355
Big baller!!
I can't let you cool kids have ALL the fun
IG: @RxOffroad
Old 03-25-2019, 10:18 AM   #349 (permalink)
Member # 83301
Curious how they do in mud?
Old 03-25-2019, 10:44 AM   #350 (permalink)
scottapher's Avatar
Member # 126355
I try to avoid mud like the plague.
With that said they cleaned out well when I did find some wet spots at the park. The KR3-S is a tad taller than my 40" Toyos when both were unmounted; a good bit lighter as well at ~86 lbs a tire vs ~104 lbs for the toyo.
The Ultra4 race this past weekend was a mudfest, looks like most teams were running these tires or a Trep.
IG: @RxOffroad
