4L65 line pressure issues? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-04-2015, 03:36 PM   #1 (permalink)
Member # 482578
Just swapped a 4l65 and LQ9 into my K5 Blazer and loving the combo so far. Trying to determine if I am having trans issues, or if this is how new trans shift.
My daily driver is a stick, so very little experience with the new computer controlled trans.
I replaced the pump and torque converter in the 4L65 before I put it in but my truck doesn't seem to be putting out the power I thought it would.
I tuned the 6.0 to about 425+ horsepower but don't seem to be getting it all to the ground. I do weigh in at about 6500 pounds, on 38's with 4.56 gearing, but it feels as if the trans is slipping.
Full throttle to the floor off the line gives me a civilized departure, no smoking tires, no screaming motor, just a steady climb up the revs. Almost feels like I have traction control or something enabled.
Truck won't do a burnout, motor just revs and trans slips. Seems odd.
Not sure if this is the new age of computer controlled malarky or if I have a line pressure issue, or PCM tuning issue.
Any thoughts?
K30_Blazer is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 04:22 PM   #2 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
A quick opinion, 4.56 gears and 38's make a high geared setup. Probably not a tire smoking combo, just looking at R&P calculators. I would think 5.13 or 5.38 would be a much better choice. Also unless built up the 4L65 is not as durable under high hp/torque as the 4L80 series.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 05:38 PM   #3 (permalink)
Member # 482578
What about the acceleration away from the line. Honestly feels like I have traction control but that would require abs.
Old 11-04-2015, 05:42 PM   #4 (permalink)
Member # 63684
Has to be something wrong, I have the same combo in my Jeepster and it will smoke the tires off the rim if I stay on it. 42's ,4.88 gear , about 4600#. Mark
Cantankerous A hole
Skorch is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 05:45 PM   #5 (permalink)
Member # 1636
Might still have torque management enabled. Who tuned it?
chris demartini is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 05:53 PM   #6 (permalink)
Member # 482578
That is what it is feeling like. Just feels very civilized. I want maniac.
Old 11-04-2015, 05:54 PM   #7 (permalink)
Member # 482578
Team 208 did. I have a call into him. He has been fantastic to work with
Old 11-04-2015, 07:09 PM   #8 (permalink)
Member # 482578
One other thing. I notice that to get it to shift when I am on the gas hard, I have to blip the throttle or it won't shift. Same thing on the freeway. If I am in torque lockup and give it the beans it doesn't really want to downshift unless I get off the gas first.
Old 11-04-2015, 11:51 PM   #9 (permalink)
Member # 140878
What torque converter? Stock? What stall speed? It kinda sounds like it's too tight (low stall) converter for the combo.
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 08:51 AM   #10 (permalink)
Member # 482578
Stock stall so like 1700 ish. I am beginning to think it is the active torque management is still at 100%.
What are opinions about removing completely? 80%??
