divorced 205...kinda... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2004, 11:54 PM   #1 (permalink)
bigtoyfreak's Avatar
Member # 9550
OK so here's something I've been thinking about for a few days. I want to run a 700R4 and a ford 205 in rig, and if I can get 10" between the mounting surface on the back of tranny and the front of the TC, I will have equal length driveshafts, which is cool cuz I can have one spare shaft. So either I have to make a 10" adaptor, which isn't a problem as I have access to CNC machine equipment and a machinist friend, or run this setup divorced. I think by the time I subtract the length of the yokes, I would really have any room left for a shaft. So, what about running a 2wd tranny with the stock tailhousing and output shaft with the slip yoke and attaching the U joint from that yoke directly to the input yoke on the 205? Basically no shaft between the two, they would just share one U joint? Hopefully you understand what I mean, not sure a clearer way to describe it. They wouldn't be divorced, just sorta of a trial seperation
bigtoyfreak is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 12:22 AM   #2 (permalink)
Dan Dibble's Avatar
Member # 12695
Wow thats alot of work to keep equal length drive shafts. Do you break many?
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops!
Dan Dibble is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 12:27 AM   #3 (permalink)
Member # 2569
i think it would work if they dont move around...
it would also save $$ in adapters
71RCKCRZR RYAN is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 12:57 AM   #4 (permalink)
Member # 9550
Dan
Well actually no, it's not alot of work, it's basically no work If I go the married route, that would be alot of work. I could bolt this set-up together tomorrow if I was sure it would work, and not shake itself to pieces. The beauty of the whole idea is that it is incredibly simple! No, I don't break alot of shafts, actually only 2 in 10 years. This was just a "thinking outside box" idea I had and thought it would be a cool way to adapt the ford 205 to a 700R4 with no adaptors or custom shit.
Old 02-13-2004, 01:19 AM   #5 (permalink)
Dan Dibble's Avatar
Member # 12695
Cool.
Dan
Old 02-13-2004, 10:41 AM   #6 (permalink)
Member # 17947
Send a message via AIM to jaluhn
The problem with just one u-joint is that it will only allow angular movement, and not actual displacement. When the frame flexes, the centerline of the trans and t-case shafts will move relitive too each other, and this will probably do bad things to the u-joint, or if nothing else, wear out the bearings faster. Even just a short shaft would make this problem much less signifigant, athough you may still have trouble under extreme flex loading with too short of a shaft.
-John
jaluhn is online now   Reply With Quote Quick reply to this message
Old 02-13-2004, 11:23 AM   #7 (permalink)
Member # 15774
Unless the frame is stiff .The truck he's talking about will have an exo from front to rear. The last few trucks we've done have had no frame flex . well maybe .01 degrees from front to back. solid mounted there should be no movement.or mounted with UHMW .Like solid mounting but no vibration.
The only promlem I see, is the pain in the ass it would be to replace the u-joint between the t-case and tranny. It would still be easier than splitting a mated set up.
The Twister is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 11:50 AM   #8 (permalink)
ItsaCJ6's Avatar
Member # 6340
yes the one Ujoint thing works, but is a real Pain in the butt to work on.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 03:24 PM   #9 (permalink)
Member # 9550
I'll assume from the way you worded that, you have some experience with this type of set up? or it is your opinion that it will work?
Old 02-13-2004, 07:24 PM   #10 (permalink)
Member # 12780
Send a message via Yahoo to SCOTTS_4X
why not us a double cardan joint? it will add a little nit if length over a single joint, but would alow a little more movement and vibe cancelation. just a thought.
-Scott
"A fear of weapons is a sign of retarded sexual and emotional maturity." -Sigmund Frued
SCOTTS_4X is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 10:08 PM   #11 (permalink)
Member # 23452
was just taking about the same thing with my dads willys, if you dont do it, it will be done on his jeep. it does flex ( frame ) but i will run a cardon joint just to suck up some of the vibes. i talked to a drive shaft gooru and he did not like the idea at first but after i explained it to him he did not see to much problems on a slower speed jeep, jason.
420willys is offline   Reply With Quote Quick reply to this message
Old 02-13-2004, 10:15 PM   #12 (permalink)
Member # 10990
Send a message via AIM to oletater Send a message via Yahoo to oletater
samurai's
samurai's use a slip yoke at the back of the tranny tailshaft and one ujoint at the front of the t-case...
oletater is offline   Reply With Quote Quick reply to this message
Old 02-14-2004, 07:48 AM   #13 (permalink)
Member # 9098
Re: samurai's
Factory samurai' have a jackshaft with 2 u-joints. Some Mazda rotarry conversions into samurai' only use 1 u-joint.
Flipper is offline   Reply With Quote Quick reply to this message
