IDing a NV4500 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-22-2015, 09:03 AM   #1 (permalink)
Member # 203543
IDing a NV4500
Okay I know what they look like and what years they came in. But looking at pickup up one from a guy that has had it sitting in his garage for sometime. He says its from a 94 chevy.
What casting numbers, serial numbers, hard measurments or and cast webbing to be able to ID which NV4500 came from what specific vehicle and year that it came from.
I only ask because I am wanting the lower first gear from the 92-94 chevy years. Dont wanna be screwed in buying something that is a year off from what I need. And im pretty sure he wouldn't let me pop the top off a count individual gears.
KTMSuperduke1290 is offline   Reply With Quote Quick reply to this message
Old 12-22-2015, 09:12 AM   #2 (permalink)
TreeQuotaTon's Avatar
Member # 214484
The early ones have a vertical bellhousing bolt spacing of 4 and 5/8ish.
TreeQuotaTon is offline   Reply With Quote Quick reply to this message
Old 12-22-2015, 09:32 AM   #3 (permalink)
Member # 203543
I know about the ID sticker on the shifter cover but thats an easy part to swap to make it look like the correct one. Really looking for something like TreeQuotaTon stated. What other hard measurments or castinf numbers are there to ID this thing.
2. NV4500 Transmission Identification | Tech Vault | Advance Adapters
Old 12-22-2015, 10:03 AM   #4 (permalink)
Member # 214484
I have one sitting on the floor at the house. If nobody else chimes in, I'll take hard measurements and pictures for you.
Old 12-22-2015, 10:27 AM   #5 (permalink)
79chevy39.5's's Avatar
Member # 67935
Cant you stick it in gear and count rotations? Kinda like a dif?
too many trucks not enough dough
79chevy39.5's is offline   Reply With Quote Quick reply to this message
Old 12-22-2015, 10:55 AM   #6 (permalink)
Member # 203543
That'll give you a fairly rough number. Not accurate enought since the two different gearing options were still somewhat close.
Old 12-22-2015, 10:56 AM   #7 (permalink)
Member # 203543
Would be much appreciated. If you want PM me and you can send them to me via text.
Old 12-22-2015, 04:41 PM   #8 (permalink)
Member # 67935
Isnt it 6.5 vs 5.6?
6 rotations on input vs 5 shoud be prettyu easy to spot
Case is just a case you can put whatever shafts you want in either case
Old 12-22-2015, 04:57 PM   #9 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
94 and 95 will have the same bolt up but different 1rst gears.
Mark and count the shaft rotations.
Old 12-23-2015, 05:18 AM   #10 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Isnt it 6.5 vs 5.6?
6.34 vs. 5.61 - so should be enough of a difference to notice.
Only the ’93 Chevies came with 6.34. The ’94 up Chevies and Dodges came with the 5.61. The 6.34 version also doesn’t have a syncro for first or reverse.
’94 GMC 6.5TD K1500 Yukon SLE / ’93 Chevy 6.5TD K2500
’85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 12-23-2015, 07:01 AM   #11 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Yeah, about 3/4 of a turn.....
5.6 will turn 5 times and the mark will land on about the 7:00 bottom side
6.3 will turn 6 times and the mark will land about the 4:00 rh side
Old 12-23-2015, 07:06 AM   #12 (permalink)
Member # 141714
Novak always has pretty good info on transmissions
The Novak Guide to the NV4500 Transmission
The real Grammar Nazi is the person who proofread Adolf Hitler's speeches.
Fredy_C is offline   Reply With Quote Quick reply to this message
