Hydro ram setup - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2016, 09:01 AM   #51 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Has anyone *recently* made a hydro assist system with a DE ram for a tie rod *without* a divorced servo? Basically, drilled and tapped saginaw box with a DE ram.
I'm considering using my PSC rebuilt saginaw box, tap it for ram assist, and run a 2" DE ram with 1.25" shaft. I ran the numbers on this setup, and it would be fast enough, provided the box can keep up. Planning to run a 7.5-8" custom pitman arm and a modified low mile stock TJ pump. I can swap to a high flow PSC pump if this one can't keep up, but I have determined that the ~1400 psi and 4 gpm would suffice. Stock flow from a TJ pump is around 2.7 gpm based on research here (PBB). I may need the PSC pump for faster steering but this will still work with a modified pump.
Thoughts?
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 02-12-2016, 01:14 PM   #52 (permalink)
Kraqa's Avatar
Member # 24741
Send a message via AIM to Kraqa Send a message via MSN to Kraqa
you know that i am doing it right now. But i haven't tested it yet.
i ran a 2" single ended ram with a 3/4" shaft with a stock ZJ pump and it was great. not slow at all.
i can't see hwo this woudl be that much different wiht the 2.25" ram and a 1.25" shaft.
REDWOOD PLASTICS RACING
Toyo Tires Offroad Race Team | EMF Rod Ends | Mulitia Muffler | VancouverWaterjet.com | RCV Performance Shafts | Redwood Plastics & Rubber
Instagram & Twitter: @Kraqa
Kraqa is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 11:20 PM   #53 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Bump. Getting ready to mount up my assist. I can either go to tie rod pros are its away from trail damage. Cons I'll have to build a bracket off my track bar bracket as my rig is kind of tall.
Second place is off axle tube to knuckle I've got artec double shear arms. Pros doesn't interfere with anything on up travel. Cons possibly slower steering as I'll need more ram travel (I could be wrong but that's what I've read). Lower on the axle more susceptible to trail damage.
Also from reading this thread I'm still confused wether it's better to be parallel at full lock or wheels straight.
Psc basically says split the difference.
http://www.pscmotorsports.com/pdf/tech/single_end.pdf
My setup Dana 60 1.75x8" ram and psc p series pump.
RANGERROD is online now   Reply With Quote Quick reply to this message
Old 03-12-2017, 08:40 AM   #54 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
Thoughts?
Just saw the date, hahahhaha
hope its done and your happy with it!
That's the plan for my next build, Lee steering box gutted to work as a Servo with no pressure to the piston. Double ended ram to take place of the tie rod. It will effectively be full hydro using a servo with gear box connection, all inside a steering box. The guys at Lee say they have gears available to bring the ration down to work with the 2-2.5 turns lock to lock, I want.
Oh on the race car we run 1450 psi at 6.5 GPM.... Not sure what they will put on this system....
Offroad Design ♦ Atomic MC ♦ Jantz Engineering
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 03-12-2017, 08:52 AM   #55 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Nearly done, need to take the box apart and fix an issue with no flow to one direction.
I thought Lee went out of business? I'm interested in getting down to 2.5 turns.
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 03-12-2017, 10:54 PM   #56 (permalink)
Member # 96153
Lee retired but a steering company in Santa Clarita bought them out and their guys/employees when over to them too. Its still called Lee and Tommy does still go there to help with problem solving...
Old 03-13-2017, 07:54 AM   #57 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Badass, I'll have to give them a call. Thanks for the update. If I'm able to get a 2.5 turn box setup I'll report back here
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 12-31-2017, 08:04 PM   #58 (permalink)
pcoplin's Avatar
Member # 17986
I am trying to rework the steering on my Jeep to accept hydro assist. I am told the internal steering box stops, ram, and knuckle stops should all stop at the same time.
I initially set up my steering with a 6.5 inch pitman, and 6.5 inch knuckle length (ball joint to drag link). I did this to speed up the steering, and it worked great until it didn't, and I twisted off a sector shaft.
Setting the ram travel to the knuckle travel is the easy part. To have the steering box travel match the knuckle/ram travel I'm going to have to shorten the pitman arm considerably. About an inch. I'd like to keep the length if I can, and I don't have the time really to figure out internal box spacers.
Question is, What happens to pressure/bleed off/whatever if the ram bottoms but but the steering box still has more to go? In my head, I can't see how the box knows whether is sees internal stops, or uses the ram as it's steering stop.
Thanks for any enlightenment.
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 12-31-2017, 08:26 PM   #59 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
when the ram stops, everything stops. use the ram as your steering stop, get as much travel out of it as your knuckles can take, dial it back a touch and limit the ram. the pressure will just go and recirc.
the box doesn't have enough power to blow the ram apart, but if you let your ram run past your knuckle stops or steering, the ram will blow up everything else
Old 12-31-2017, 08:31 PM   #60 (permalink)
pcoplin's Avatar
Member # 17986
Ah, that must be what it is then, unnecessarily pressurizing the ram? That makes sense.
98 TJ LQ4/TH400
Old 12-31-2017, 08:33 PM   #61 (permalink)
69DieselLover's Avatar
Member # 210244
Too slow...
Seems like stops in the box is a none issue. If the ram and knuckles hit their stops, the only thing pushing on the piston in the box, sector shaft, and drag link is the oil pressure in the system. Any external force would be controlled by the axle and cylinder stops.
Humboldt Hillbilly
My Diesel Sport Trac Build
69DieselLover is offline   Reply With Quote Quick reply to this message
Old 12-31-2017, 08:47 PM   #62 (permalink)
Member # 210244
I feel like PSC knows their shit, as they should, it's their job, but from my personal experience with cylinders in general and especially on SE steering rams, I try to have the cylinder as straight as possible with the load when fully extended because at that point the rod is the least supported. The piston being one support and the gland being the other, the piston is right up against the gland so the rod is really hanging out there and could be putting a lot of force on those parts. On DE rams I try to make everything parallel when the rod is extended. On the collapsed side it's less important because the rod on that side is much better suported.
Humboldt Hillbilly
Old 12-31-2017, 09:14 PM   #63 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Also rather than breaking knuckles and ruining upper kingpin bushings is can also bend the rams rod outward.
Old 12-31-2017, 09:18 PM   #64 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
That’s exactly how I set mine up. And just to update this thread I’m running artec arms and I’m using all 8” of my ram steering stops limit everything ram parallel to axle at full lock. Here’s some pictures and my fancey skid plate.
Old 01-01-2018, 08:11 AM   #65 (permalink)
Member # 83301
Originally Posted by charlieboyd65 View Post
My last setup had the ram mounted to the knuckle but I can't do it on my current setup. I think running the ram to the tie rod really depends on the material/strength of your tie rod, and where you connect it to the tie rod. Connecting it to the middle of the tie rod is much less ideal than straight to the knuckle. The closer you get the attachment point to the knuckle the better off you'll be. And of course, the knuckle is best. My ram was parallel with the wheels turned. Worked fine.
Originally Posted by Gordon-B View Post
Interesting question...
Could you split the difference?
That would be my first thought...
Turn the wheels to halfway and make it parallel there. That would put a small angle at full lock and at center.
It would be closer to parallel in the range you are most likely to be bound up. (Neither fully straight or full lock)
What do you guys think?
This I what I had on my last set up. Worked great, the moving end of the ram was just inside the tube adapter and the fixed end beside the housing on the tube. With tight jam nuts I never had it rotate
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
