90's throw back....Manche build - Page 34 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-08-2017, 02:41 PM   #826 (permalink)
mcutler1's Avatar
Member # 167368
There's just not enough builds that incorporate a custom fabricated windshield washer fluid reservoir....
Got started on the radiator shrouding also; and my ss wire mesh arrived...
Matt
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
Instagram: CutlerFab
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 03-08-2017, 02:42 PM   #827 (permalink)
mcutler1's Avatar
Member # 167368
Originally Posted by ssic off road shop View Post
33 Pages of this build and i'am dieing to see where that exhaust is going to route to. At 6'7" that is a great idea on running it out of my footwell area, patiently waitingloving the clean work just like everyone elso
Thanks! I'm excited about it too! It's going to be fun and different...coming soon!
Matt
Old 03-09-2017, 04:42 AM   #828 (permalink)
scottapher's Avatar
Member # 126355
Killer work, it had been a while since I checked out progress
Bent Fabrications Evo 2 Coupe
IG: @RxOffroad
scottapher is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 04:22 PM   #829 (permalink)
Member # 161331
Originally Posted by mcutler1 View Post
Cold start, I like to set the amperage so that I am running about 60% pedal when running a bead. You can then lay on it to start your puddle faster when you are starting on top of the previous weld.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 08:04 AM   #830 (permalink)
Member # 161721
This build is so badass! You do amazing work Matt! I am blown away at how fast you can build this stuff from scratch. Your tig welds look really good to. Makes me really want to get a tig welder.
jeepyj2000 is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 08:15 AM   #831 (permalink)
mcutler1's Avatar
Member # 167368
Thanks brother, I don't feel fast, I've never had a build last this long...but I never had 3 kids while doing a build before either...such is life.
Leaning tig is fun. Wish I had picked it up years ago. I love laying mig beads, but tig is on another level of fun. The challenge and satisfaction when you get something right is a high. Now I want to tig everything, lol.
Looking forward to some videos of your ride!
Matt
Old 03-15-2017, 01:51 AM   #832 (permalink)
mcutler1's Avatar
Member # 167368
Getting some tin work done under hood. Almost done shrouding the radiator. The shroud stays in place with our without the front clip....for those stupid midnight crackhead runs at gmp...
Matt
Old 03-15-2017, 01:54 AM   #833 (permalink)
Member # 95025
Very nice work indeed!
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 03-15-2017, 10:45 AM   #834 (permalink)
Wubsor's Avatar
Member # 308273
Th
Where did you get the wire mesh? I've looked at McMaster but there is a plethora of available styles and options. Got a p/n? You've got me inspired...
-Scott
Afterthought Racing, 4827
Wubsor is offline   Reply With Quote Quick reply to this message
Old 03-15-2017, 11:17 AM   #835 (permalink)
mcutler1's Avatar
Member # 167368
Pegasus auto racing supplies, cheapest I found for this size. Cost almost as much to ship!
Matt
Edit; they have three mesh sizes, this is the medium. Works great with 1/8 rivets with a back up washer, it's weaved just tight enough that you can move the strands with a carbide scoring tool to get the rivets through. Btw, plasma cuts it nice...no sharp edges.
Old 03-15-2017, 12:29 PM   #836 (permalink)
mcutler1's Avatar
Member # 167368
Shroud done, steering and washer fluid resi mounted. Be about a week before I can get back on it. Gotta build some trailing arms for a customer, and strip a couple tons of copper wire...
Nice straight, short, shot from steering resi to pump...
Matt
Old 03-15-2017, 10:10 PM   #837 (permalink)
Newbie
Member # 491105
How long are your trailing arms I am building a similar rig except it's a explorer thanks Kevin.
Hotrodmk8 is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 06:40 AM   #838 (permalink)
matzell's Avatar
Member # 42081
Matt,
I know the motor is pretty solid mounted but are you worried about the tension on that ps hose being so short?
Build is looking very good!
Rob Matzell
2014 4WD EASTERN 4500 CLASS CHAMPION
EMC 2013,14, 15, 16, 17
Matzell Motorsports #4573
Thanks to: Weldone Fabrication, Maxxis, Fox, PRP, PSC, Raceline, Reid Racing, Ruffstuff, Willow Lawn Service Center, JB Custom Fab, Yukon Gear, Dynomax, 150tunes.com,Lugnut4x4
matzell is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 06:55 AM   #839 (permalink)
mcutler1's Avatar
Member # 167368
Iirc 41-42"
Originally Posted by matzell View Post
Matt,
Good eye Rob. Frankly didn't give it a lot of thought, had direct shot on the brain. I've got a 135 fitting I can put on the resi, and give it a loop around to allow more movement. Would be less than 10"overall I think.
Thanks!
Matt
Old 03-16-2017, 07:00 AM   #840 (permalink)
OnTheSpot's Avatar
Member # 34900
Matt,
From what I see I think he will be fine. My wife's buggy has an even shorter hose run from her resi to pump. Just two normal motor mounts. I was concerned at first but after putting it into service it seems to be working fine.
Another thought I had was you could cut off a bit of the barb fitting to allow the rubber hose to flex a bit more since there shouldn't be any pressure in that line.
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 07:16 AM   #841 (permalink)
mcutler1's Avatar
Member # 167368
Now that's a thought...and put a crimp ring on just for good measure.
Thanks
Matt
Old 03-16-2017, 08:38 AM   #842 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Iirc 41-42"
Thanks!
Matt
Thanks
Matt
I had a hose that was too short, where the barb fittings almost touched. It leaked all the time.
I fixed it with the loop method discussed above, and have been leak free since.
Just some input.
Bryan 'Opie' Bennett
Wanna be rock crawler guy #91 in a Blue XJFireWallBuggy.
XJ_ranger is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:06 AM   #843 (permalink)
mcutler1's Avatar
Member # 167368
Just some input.
I appreciate it!
Matt
Old 03-16-2017, 09:10 AM   #844 (permalink)
Josh40601's Avatar
Member # 171332
Do you have thread on this??
Sorry for the thread jack Matt
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:17 AM   #845 (permalink)
Member # 7903
I really like the shrouding for directing air to the rad. I'm interested to see with the lay back of the rad and shrouding how it works. I've thought of a less intricate setup, and it worked fine in my mind. Will be good real world experience.
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:22 AM   #846 (permalink)
Member # 686858
Start here.
https://www.pirate4x4.com/forum/gener...-build-17.html
Just realized you were probably asking about the Explorer. My bad.
DZ Fab is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 09:40 AM   #847 (permalink)
Josh40601's Avatar
Member # 171332
Originally Posted by DZ Fab View Post
Start here.
I am asking about the explorer. No worries.
Sorry again Matt
Old 03-16-2017, 09:48 AM   #848 (permalink)
mcutler1's Avatar
Member # 167368
No problem guys
Matt
Old 03-16-2017, 09:59 AM   #849 (permalink)
OCM
Member # 14091
I had a very short -12 from the res to the pump as well. Took some off the barb on both fittings (push-loc). Has not leaked in 4 years of racing.
OCM is offline   Reply With Quote Quick reply to this message
Old 03-16-2017, 10:11 AM   #850 (permalink)
Member # 181868
So is that a perminate installed fuel pressure gauge in that pic? I was thinking of doing something like that. Than if the engine was running rough (or not running), I would have a quick way to trouble shoot. It's not like I need it on the dash. Have you done that before? Is there any problem with vibration or anything? If that's not what it is, disregard.
Project : Amphibious HEMTT
