90's throw back....Manche build - Page 46 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-03-2017, 07:23 AM   #1126 (permalink)
Member # 85771
Fawk brakes!!!
Make Forums Great Again!
Old 09-03-2017, 07:39 AM   #1127 (permalink)
mcutler1's Avatar
Member # 167368
Originally Posted by ky scrambled View Post
Fawk brakes!!!
Trying something new... brakes on command, the latest and greatest... pedal on passenger side, and tell that lazy sob sitting there to hit them...
Sent from my SM-G950U using Tapatalk
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
Instagram: CutlerFab
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 09-03-2017, 08:00 AM   #1128 (permalink)
Member # 85771
Old 09-03-2017, 08:57 AM   #1129 (permalink)
Member # 181868
Got cold feet........ummm no.
Project : Amphibious HEMTT
Old 09-03-2017, 04:34 PM   #1130 (permalink)
mcutler1's Avatar
Member # 167368
Mo doing stuffs...
Matt
Old 09-03-2017, 06:10 PM   #1131 (permalink)
Member # 181868
In the first pic, the bead roll section looks "recessed". On the last pic, it looks "raised". Don't know which way I like it better.
Old 09-03-2017, 06:11 PM   #1132 (permalink)
mcutler1's Avatar
Member # 167368
It's both, upper shelf is raised, vertical plane is recessed.
Old 09-03-2017, 06:14 PM   #1133 (permalink)
gt1guy's Avatar
Member # 236179
What are your plans to deal with the header heat?
I almost hate checking in on your thread, makes me want to go out to my shop and burn my Jeep to the ground. Fantastic craftsmanship you have there.
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 09-03-2017, 06:41 PM   #1134 (permalink)
Member # 42940
Thanks guys
Burning that midnight oil and shit...
I bet the oil smells better
TeXJ is offline   Reply With Quote Quick reply to this message
Old 09-03-2017, 07:34 PM   #1135 (permalink)
mcutler1's Avatar
Member # 167368
thanks gt-1!
Lol. That has probably been the most talked about 'issue' of the build. Honestly I had zero air gap in my previous buggy, and yes it got warm... but I only touched bare skin one time... that's all it took, lol. This truck will have a 1-2" air gap around the header, wrapping the outer tube and insulating the backside of the panel. I will even have room to double wall with insulation if I see the need.
It's really hard to get the perspective in pictures, especially since you guys can't read my mind and see my blueprint in my head.
Lmao
Old 09-04-2017, 04:35 PM   #1136 (permalink)
mcutler1's Avatar
Member # 167368
Hammer down; plumbing and wiring party this weekend with [USER=6153]@Paul[/USER], [USER=3094]@ol'Jeeps[/USER], and [USER=35]@jeepn-jason[/USER] - everything needs to have a home by then, except for interior panels; I'll complete those once she's cranked...
Matt
Old 09-04-2017, 06:51 PM   #1137 (permalink)
Member # 181868
Looks nice. Will the Guage panel be rubber mounted?
Old 09-04-2017, 06:53 PM   #1138 (permalink)
mcutler1's Avatar
Member # 167368
If it goes the way I think it will tonight, it will be floating between the first A pillar at left and the windshield bar on right; with a small scalloped tab at the column notch.
Old 09-05-2017, 01:24 PM   #1139 (permalink)
Josh40601's Avatar
Member # 171332
so... why gloshift?
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 09-05-2017, 02:11 PM   #1140 (permalink)
mcutler1's Avatar
Member # 167368
Originally Posted by Josh40601 View Post
so... why gloshift?
Main reason is the dual analog and digital readout on the max tow series; the digital is easier to glance at in duress, but the analog looks better.... I used then in my previous buggy with good service.
Old 09-05-2017, 02:30 PM   #1141 (permalink)
Wubsor's Avatar
Member # 308273
thanks gt-1!
Sounds like you've had plenty of thought into a plan, but here's what worked for me in my build with a nearly identical issue (cab build, engine pushed 2/3rds way into the cab, minimal distance between ankle/shield/header).
  • DEI Floor and tunnel shield
  • HVAC tape to seal the edges from dirt/dust (specifically Nashua 324A)
  • Cowl "scoop" to force air over the backside of the engine
Like I said, sounds like you're covered, but that heat shield has done me well. I have about a .25" airgap at a couple spots and the shield has held up great. If it does get hot even with insulation (as it did with me) I built a cheezy scoop right in front of my windshield tubes that forces air down over the engine. Helps a lot at sustained high speed.
-Scott
Afterthought Racing, 4827
Wubsor is offline   Reply With Quote Quick reply to this message
Old 09-05-2017, 03:09 PM   #1142 (permalink)
mcutler1's Avatar
Member # 167368
Thanks wubsor!
I will be using something like this, and they're will be a hood vent above air cleaner near the back of the hood.
Old 09-05-2017, 03:20 PM   #1143 (permalink)
mcutler1's Avatar
Member # 167368
Finished the gauge cluster and mount this afternoon
Matt
Old 09-05-2017, 03:59 PM   #1144 (permalink)
Member # 103621
my cab is hot as fuck, mainly because it is semi-open. My plan is to rip out the seats and seal everything up the best as possible. will the stuff linked above work better on the underside (engine side) of the panel? I dont plan on taking the engine out, but can remove the panels and apply some heat shield if need be.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 09-05-2017, 04:07 PM   #1145 (permalink)
mcutler1's Avatar
Member # 167368
All info I've looked at for many brands is the shielding goes on the hot side of a panel, except for some obscure stuff.
Old 09-05-2017, 05:25 PM   #1146 (permalink)
Member # 181868
Love the look of your panel. But I don't see how you get access to work on it. I hope you don't have to work on it after initial wiring, but that what we always said building helicopters. Eventually, we started putting hinges on em'. Which vibrates more, helicopters or off road trucks, hmmmm.
You could put a cannon plug on the side. Then just pull the whole pod when you need to work on it. But it's nice to have it plugged in sometimes when troubleshooting.
Don't mind my ramblings. Keep up the good work.
Old 09-05-2017, 05:31 PM   #1147 (permalink)
mcutler1's Avatar
Member # 167368
Thanks.
Yes its getting a weatherpack cannon plug with about a 12" whip. It's stupid easy to get it off the column, 2 screws front and 4 rear, slips right out, then you can pull the 6 screws from the rear access panel for work. Thought about hinges and quarter turns for the rear panel, but this was a more stable mounting.
Old 09-05-2017, 06:18 PM   #1148 (permalink)
Member # 78700
Send a message via Yahoo to sickboyboone
I hate you. I really, really hate you.
So when are you gonna come help me with my cj7 inner fenders and new dash hahahaha.
For reals though bough matt, you keep fukin blowing my mind with this shit dude.
Sent from my iPad using Tapatalk
I must be sick, I'd almost rather build em than wheel em! almost.
sickboyboone is offline   Reply With Quote Quick reply to this message
Old 09-06-2017, 12:16 PM   #1149 (permalink)
Member # 101265
so... why gloshift?
Was waiting for that - everyone seems to badmouth those gauges on the diesel side, but I haven't been impressed with Autometer either. Might run them in the next rig.
Kunker is offline   Reply With Quote Quick reply to this message
Old 09-06-2017, 01:49 PM   #1150 (permalink)
Josh40601's Avatar
Member # 171332
you should do it and sell me your autometers super cheap since they are not impressive
