90's throw back....Manche build - Page 55 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-06-2017, 09:14 AM   #1351 (permalink)
Member # 14196
Send a message via AIM to wes8517 Send a message via MSN to wes8517 Send a message via Yahoo to wes8517
Are you worried about your shoes slipping if muddy or wet and losing leverage on either pedal since the floor is slick aluminum? Just curious what your thoughts were on that. Looks killer as usual.
Wes
Nothing worth noting here
wes8517 is offline   Reply With Quote Quick reply to this message
Old 11-06-2017, 09:53 AM   #1352 (permalink)
Josh40601's Avatar
Member # 171332
I definitely don't think your feet will ever get cold. lol
The never-ending project
An old Explorer with a lot of dents
Josh40601 is offline   Reply With Quote Quick reply to this message
Old 11-06-2017, 10:58 AM   #1353 (permalink)
mcutler1's Avatar
Member # 167368
Wes
Similar questions on Desert Rangers;
Originally Posted by partybarge_pilot View Post
I would have left it solid and covered it with grip tape. With the dimples it will collect shit loads of dirt under it.
That's exactly why their placed so, no where for dirt to collect, both holes drain outside the belly pan and boat side skid; no worries about what enters the skids, I drop them after every trip to clean the belly out and inspect, the tires throw plenty up in the skids from the front anyway.
Grip tape can still be added later if I feel the need, never needed it in past rigs though.
And I can remove that panel with seat in, their are brake line connections there that may need to be tightened for some reason.
... end quote
There are hundreds of buggies with aluminum floors and no tape, and never had any issue on any of my last rigs. I will probably add a heel stop for my gas foot, similar to my buggy was; but my brake foot needs to slide, pedal has a long throw.
Btw, these Goatbuilt skids are certainly going to be much easier to drop versus previous set ups; looking forward to that convenience.
Probably not!
Sent from my SM-G950U using Tapatalk
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
Instagram: CutlerFab
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 11-06-2017, 12:09 PM   #1354 (permalink)
hurleygo3's Avatar
Member # 80862
Wes
If you're buckled in a seat. I don't see any reason he be losing any leverage.
Panel work is amazing.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 11-06-2017, 12:48 PM   #1355 (permalink)
mcutler1's Avatar
Member # 167368
Originally Posted by hurleygo3 View Post
If you're buckled on a seat. I don't see any reason he be losing any leverage.
... and this is why I saved the dog box for last, smh....
Matt
Old 11-06-2017, 12:55 PM   #1356 (permalink)
whitneyj's Avatar
Member # 135947
Matt
Are you bending that form one piece?
I know this is almost beating a dead horse at this point, but I love reading your explainations for why you did, or didnít, do certain things. Your thought processes and forward thinking makes me feel a little more Neanderthal than Iím used to
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 11-06-2017, 12:55 PM   #1357 (permalink)
Member # 181868
Gas pedal behind brake, reason it looks low. I drive two footed on the trails. I've got good leverage on the brake.
Thanks.
That's interesting. So will you drive this thing single footed when on the street? I realize you might not be driving it lots on the street, but it is legal. (I think it would be a blast on the street)
Project : Amphibious HEMTT
Old 11-06-2017, 01:02 PM   #1358 (permalink)
mcutler1's Avatar
Member # 167368
I'm going to attempt to. That common corner isn't really common, there will be a cut there that should allow me to do it in one shot.... but if not, I'm not afraid to cut and weld and grind, I won't try it twice.
I posted the wrong picture, first didn't have the degrees of each bend marked, this one does...
Hard to say until I drive it, but probably won't have much choice., it's a stretch from one to the other, and the pedals are angled like the seat- towards the drivers side front tire about 10į.
Old 11-06-2017, 03:51 PM   #1359 (permalink)
mcutler1's Avatar
Member # 167368
More...
The cup holder piece is kind of the keystone of the center tunnel section (albeit, the last piece that would be removed, so as to be a fully functional vehicle when all the panels are removed for cleaning.) So I added these skirts to aid in fastening the lower pieces.
Small storage spot below/ behind cup holders.
Tried to do this tunnel panel in one shot, but quickly determined wasn't going to happen, therefore I flanged all the sides and made two pieces.
Matt
Old 11-06-2017, 05:54 PM   #1360 (permalink)
Member # 181868
Boy that cup holder turned out nice. When you weld those skirts on, do you butt weld or is there some overlap? Do you ever burn through and have to blob a bunch of al on it and grind it all down? If you don't, you make me sick.
Old 11-06-2017, 06:03 PM   #1361 (permalink)
mcutler1's Avatar
Member # 167368
Thanks.
Open corner, very little overlap. Yes, I still burn through from time to time, but I'm getting better. Still have a hard time with inside corner fillet, and lap joints, I like open corners.
Basically, if I've sanded a weld, it wasn't pretty enough to leave natural . Lol. (On aluminum anyway)
Old 11-07-2017, 10:15 AM   #1362 (permalink)
Member # 101265
Thanks.
I was going to ask how it was joined - can't even tell it wasn't 1 piece to start with. Lots of envy of your skills over here - I need to make the time.
Kunker is offline   Reply With Quote Quick reply to this message
Old 11-07-2017, 10:52 AM   #1363 (permalink)
mcutler1's Avatar
Member # 167368
Thank you. It takes time for sure.
Old 11-07-2017, 10:53 AM   #1364 (permalink)
mcutler1's Avatar
Member # 167368
Drivers side aluminum is done, templates are close for passenger side. Try to knock it out today. Then onto the steel engine covers.
.... unfortunately, once the seats are in, you'll never see it...
Matt
Old 11-07-2017, 10:57 AM   #1365 (permalink)
Jeepman14wheel's Avatar
Member # 46071
looks great... what bender are you using for your sheet metal work?
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 11-07-2017, 11:17 AM   #1366 (permalink)
mcutler1's Avatar
Member # 167368
Hi quality Chinese stuff, lol.
$300 eBay finger brake
$45 grizzly 6" vise finger brake
$150 American made work bench with toobing welded to the end and a Chinese rubber hammer... Lol
Wouldn't know what you do with real tools lol.
Thanks jeepman!
Old 11-07-2017, 11:51 AM   #1367 (permalink)
Member # 181868
I'm going to have to get me one of those 6" finger brakes. Another tool I find handy is a 4" vise grip seamer.
HAND SEAMER/3.5Ē JAW from Aircraft Spruce
Old 11-07-2017, 11:58 AM   #1368 (permalink)
mcutler1's Avatar
Member # 167368
Its handy dandy for sure.
Yep, I have that and the narrow one as well.
Old 11-07-2017, 01:15 PM   #1369 (permalink)
Member # 133593
Great work as usual. Question on those panels, are you going to be adding any foam or gasket type material where the panels meet to help reduce noise? I would think the panels would rattle slightly against each other.
1998 XJ thats too mild for Pirate .!.. :D ..!.
Cage,35's,4.88's,front truss,zip locker,4.5" longarm
DutchVDub is offline   Reply With Quote Quick reply to this message
Old 11-07-2017, 02:15 PM   #1370 (permalink)
mcutler1's Avatar
Member # 167368
Time will tell. Never needed it in the past, (there's always that one exhaust resonance frequency zone that rattles everything, lol), but I go to great lengths to have some pre load on every piece on the circumference. That's why every edge has a broken lip, to 'lift' the panel off the base so that the screw has tension throughout.
Note: I don't add that final bend until every thing fits tight; then I put it in the brake, or hammer the edges to add that lift.
I'm sure I will be chasing down rattles for a bit. But I'll find them and remedy it somehow.
Old 11-07-2017, 04:31 PM   #1371 (permalink)
Newbie
Member # 769833
This machine is simply a work of art. Wish I had half of your fab skills.
Lil_Chop19922 is offline   Reply With Quote Quick reply to this message
Old 11-07-2017, 04:36 PM   #1372 (permalink)
Member # 135279
Really like the dimple holes in the floor to sweep shit out. Always look forward to the updates. Looking forward to seeing it at Koh!
shrek tits is offline   Reply With Quote Quick reply to this message
Old 11-07-2017, 04:43 PM   #1373 (permalink)
mcutler1's Avatar
Member # 167368
Thanks guys!
I'm looking forward to being there!
Old 11-08-2017, 09:29 AM   #1374 (permalink)
Josh40601's Avatar
Member # 171332
are you going to paint the aluminum or leave it raw? Just wondering, not criticizing
Old 11-08-2017, 01:16 PM   #1375 (permalink)
Member # 181868
k
Could you please take pic of that fastener apart. I've tried to zoom in, but just can't figure it out. It looks like a wire going across two rivets holding a button. I must be missing something.
