Oil Pan Idea question?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2004, 10:22 AM   #1 (permalink)
Member # 14455
Okay I have been trying to figure out a way to keep the iol pump happy at almost all running angles. If you have ever seen a nodwell you know how they drive. They have oil pan similar to this one with a modified pick-up at the centre of the pan with some baffles to keep the oil at the pickup.
Is there anyone that builds such a pan without having to run a dry sump? Or should I just use the stocker flange as a template and build my own like this.
Sapper is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:28 AM   #2 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
Came acrossed this looking for sump options for my 4.3.
BIGELOW MOTORSPORTS EST. 2003
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 11:36 AM   #3 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
This is a no brainer.....not even a need for a funky shaped oilpan. All you need is a well designed trap door baffle setup along with a windage tray (not screen) and you are good to go. I run this setup.....I filled my pan with oil while it was off the engine and the trapdoor box around the pickup remained full of oil tilted at every angle except the obvious, upside down. Canton uses this design on their race pans.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 12:17 PM   #4 (permalink)
Member # 6036
Send a message via AIM to AggieLR
pics?
Landon
'07 Dodge 2500, '94 Toyota...just about like the one that burned down
AggieLR is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 12:41 PM   #5 (permalink)
Member # 14455
Is it on there site for a SBC???
http://www.cantonracingproducts.com/
Old 03-03-2004, 01:18 PM   #6 (permalink)
Member # 616
I just called and ordered one. They've got quite a few different ones that'll work for my application - 15-100T, 15-250T, 15-260T. I called the Tech line and they were real helpful.
-Brett
brett is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 07:22 PM   #7 (permalink)
Proeliator's Avatar
Member # 12042
Nope no pics.....hell, I barely know how to get on the internet. Its easy to make your own trapdoor baffle setup but Canton will have whatever you want. Just so you guys can picture it though, basically, you weld a box into the bottem of your pan (around where the pickup goes with wings coming of the four corners to direct oil to the box. The box has four doors in it, each which has a flapper plate and spring....lets oil in, won't let it out. Windage tray on top keeps oil in its place and off the crank. Weld in a crank scraper while your at it. All of this is easy to do, even on a stock pan put really its best to have a deep sump to play with. I run setups like this on all my wheelers and have never had failure from oil starvation at extreme angles.
