Dumb steering angle question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2016, 06:55 PM   #1 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I've never worried much about steering angle. Mainly because I've had rear steer for so long and before that no one really cared about steering angles. But right now I'm drawing a mockup in cad of some axles and I need to know where the tires will be at full lock so I am having to worry about it. When people say they have 45* steering, is that 22.5* in each direction for a combined total of 45* or 45* in each direction for a combined total of 90*? I've got both drawn out. One seems like not enough, the other seems like so much that very few axles could handle it before a big tire hit the front driveshaft. I know that when you see an axle actually turning 45* it looks broken though so maybe my eyes just aren't used to it and a lot of people just don't have what they think they do.
Old 03-30-2016, 07:09 PM   #2 (permalink)
Member # 102813
Mine is 47* in one direction, Starting at a straight forward 0*. Its not a combined sweep.
[/COLOR]
Mr Stubs is online now   Reply With Quote Quick reply to this message
Old 03-30-2016, 08:23 PM   #3 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Thank you!
Old 03-30-2016, 08:38 PM   #4 (permalink)
Under Powered
onlyonedr's Avatar
Member # 19543
Remember that due to Ackerman the inside tire turns sharper than the outside tire, like in the picture above. Both tires do not rotate to the same angle for a given steering wheel position. The overall swing should be the same side to side.
'01 Nissan KC Desert Runner: Work in Progress
'69 Chevy K5: Non-Wheeling Fun Rig
NOAS Club Membership Coordinator and Treasurer 2016-2017
onlyonedr is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 08:25 AM   #5 (permalink)
B.A.R.K's Avatar
Member # 8540
All of that depends on steering arm design. Jessie Haines runs reverse Ackerman so that the outside tire turns shaper than the inside, for various reasons.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 09:19 AM   #6 (permalink)
Blase's Avatar
Member # 63692
patooyee I have some cad drawings of my old buggy. I can email them if you'd like. auto cad LITE files.....probably 2002 version.
Inside tire turned 43* and the outside 47* in reality. I didn't take Ackerman into account in my drawing.
The narrower you are the harder it is to get extreme steering! My WMS on the front was 62" after I added the spacers. Tires hit everything in reality and nothing in my CAD drawing.
[QUOTE=JR;13666387]:laughing: You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.[/QUOTE]
Blase is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 09:28 AM   #7 (permalink)
Member # 1889
I usually set my own stuff up for zero or near-zero Ackerman for maximum angle.
45 from straight does look broken. And unless you're running really wide axles and really narrow chassis, is hard to fit the tires.
I remember thinking we had a nice hot-ticket setup that would steer a legitimate 43 from straight, how broken it looked, how tight it turned... and the very next comp out rolls a Twisted Customs car with prototype 1550 knuckles that turned about 60 degrees.
Scott@Rockstomper is online now   Reply With Quote Quick reply to this message
Old 03-31-2016, 11:20 AM   #8 (permalink)
Member # 159557
Currently in same boat. 50 degrees was easy to get digitally, just didn't transfer to real world very well. Looks like I'm settling for about 43.
Anybody got a link to past conversations on this subject? Curious what his thoughts are on 0 vs. reverse.
JETHROBODEAN is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 11:35 AM   #9 (permalink)
Member # 8937
Set your Ackerman to give you the greatest combined turning angle. If your inside tire hits the links at 43, why not set the outside tire to turn 50? I guarantee it will turn sharper than both tires at 43 or 100% Ackerman with one tire at 43 and the outside tire at 38. My new car has neutral steering, with both tires turning 45 because my CV's will only allow 45.
September 24-25, Wild West Motorsports Park, Reno, NV
#199/4499 - Superchips, Maxxis, Trail Gear, Branik Machine Shop, Yukon, JE Reel, Rugged Radios, Lifetime LED, Sway-a-way.
mudtruck44 is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 11:38 AM   #10 (permalink)
Member # 159557
Makes perfect sense, thanks.
Old 03-31-2016, 11:41 AM   #11 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
I never measured turning radius but, on my last rig, I set the front rockwell up with reverse ackerman initially. I ended up changing to correct ackerman just as a side effect of changing ram setups. I noticed a definite improvement in turning radius that I wasn't even expecting.
Old 03-31-2016, 01:05 PM   #12 (permalink)
ISDTBower's Avatar
Member # 94026
I know my LJ doesn't turn worth a crap locked, and secondly with the rear locked.
That subject was talked about on the trails in Moab last week. Interesting how many are now running just front wheel drive locked and unlocked. This minimizes bind through the transfer-case. Zero Ackerman for racing to bite the outside front and Ackerman for general wheeling with grip.
ISDTBower is online now   Reply With Quote Quick reply to this message
Old 03-31-2016, 01:18 PM   #13 (permalink)
Member # 164791
Here is what 40* looks like, i think it looks broken...
https://www.pirate4x4.com/forum/gener...l#post29959938
I setup mine so that the inside tire turns 40* (outside turns 36*)...
boing. is offline   Reply With Quote Quick reply to this message
Old 03-31-2016, 02:22 PM   #14 (permalink)
Member # 8937
Essentially what you did was went from the inside tire turning 30 and the outside turning 35 to the inside turning 35 and the outside turning 30. I would agree that if you had to choose one or the other, the correct Ackerman would turn tighter. That's not the same as what I described above though.
