limit cables - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2016, 10:20 AM   #1 (permalink)
Wilson's Avatar
Member # 7233
limit cables
These were on a rig that I bought from mosebilt. I like the simplicity and non-stretch aspect. Anyone else using cables or know where I could source some?
Old 04-09-2016, 10:41 AM   #2 (permalink)
Rock Stacker
HydroDynamic's Avatar
Member # 65066
Rigging companies can make these to length. McMaster Carr even has them for lifting rigging.
It would be nice to see a Dyneema winch rope style. Spliced with eyelets of some sort that could be bolted.
The stretch is a good thing with webbing, to lessen the shock, that goes away with a non stretch line. Similar to mountain climbing with dynamic rope for fall shock absorbition vs rappelling with a static line so you don't bounce.
HydroDynamic is offline   Reply With Quote Quick reply to this message
Old 04-09-2016, 10:46 AM   #3 (permalink)
Wilson's Avatar
Member # 7233
That would be great for ultimate weight savings
Old 04-09-2016, 11:06 AM   #4 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I use to do these before my swedge tool was stolen. I used 5/16 cable. It worked great. Never had one fail. Even on a rockwell rig I built on 46" claws and stazworks 20x14's.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 04-09-2016, 11:28 AM   #5 (permalink)
Wilson's Avatar
Member # 7233
Not that limit straps are known to fail, but I am somewhat surprised these aren't more common.
Old 04-09-2016, 11:39 AM   #6 (permalink)
ZAG
ZAG's Avatar
Member # 14113
made my limiting traps from winch rope. i just have eylets welded to Axel and chassis. spliced the rope to them. its easy to adjust and just un splise when there is need for removal.
didnt splice the end inside the rope only goes 3 times trough it.
ZAG is offline   Reply With Quote Quick reply to this message
Old 04-12-2016, 12:49 PM   #7 (permalink)
welndmn's Avatar
Member # 398
I'd try Todd at custom splice, he's always willing to try new things.
Mark
Old 04-12-2016, 12:56 PM   #8 (permalink)
whitneyj's Avatar
Member # 135947
I used those on my last XJ. Started with chains (ran out of money for straps), replace the chains with the straps and hated how much they stretched, and ended up building cables from old winch cable I had (like Action Fab said-5/16"). I have a hydraulic hand swedge tool I picked up for $80 for making my own battery cables, ect, that has a few die for cables. I'll never build another limit strap again after the cables.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 04-12-2016, 01:18 PM   #9 (permalink)
Member # 189899
any sailboat marina can swage 'em up for ya
[COLOR="Black"].
.[/COLOR]
[COLOR="Black"]_ _______ _ _ _ _ _ _ _ _ _ _ _ _[/COLOR][CENTER]what the hell you lookin' down here for?[/CENTER][COLOR="Black"] _ _ _ _ _ _ _ _ _ _ _ _ _ _[/COLOR]
ecoast is offline   Reply With Quote Quick reply to this message
Old 04-12-2016, 09:01 PM   #10 (permalink)
Member # 192237
Chains may rattle, but they're much more hackfab friendly.
Old 04-12-2016, 09:08 PM   #11 (permalink)
Wilson's Avatar
Member # 7233
Not after hack-fab in the least. In my case, they are insurance (ORI's) for others why give up travel for future stretch or risk failure if a strap stretches too much? I'm looking for nice, custom swaged cables like I showed.
Old 04-12-2016, 09:24 PM   #12 (permalink)
Member # 102813
If you are going a cable route I would plasti dip them after you have them made.
Cuts down on unsightly wear and safer (broke/frayed strands)
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 04-12-2016, 09:33 PM   #13 (permalink)
Member # 192237
Oh, I'm all for the easy way out.
Old 04-12-2016, 10:42 PM   #14 (permalink)
Member # 111580
any logging company around there should be able to make them for you, I can get them made at cost for you if you are interested and want to drive an hour.
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 06:42 AM   #15 (permalink)
whitneyj's Avatar
Member # 135947
Now that idea is gold. I hadn't thought of that. I soldered the frayed ends but that was a PITA and strands always ended up coming loose anyhow.
Old 04-13-2016, 06:48 AM   #16 (permalink)
Member # 3007
Could you slide some fuel line over the cable and cover most of the cable minus the swage portion?
Bones is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 06:59 AM   #17 (permalink)
Member # 23011
Where do you source reasonably priced steel eyelets for 5/16" cable?
vikingsven is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 07:18 AM   #18 (permalink)
whitneyj's Avatar
Member # 135947
Easily. It would just need to be done prior to crimping the swedge clips. I wouldn't want to do that however as that'll hold mud, grim, water, ect. I'd rather be able to hit it with the pressure washer, let it dry, or seal it entirely. Plus with the hose over it the cable won't move freely like it would otherwise. Would that cause an issue? Probably not, I just don't like the idea. But that would work great for keeping the cable from chaffing anything.
Old 04-13-2016, 07:19 AM   #19 (permalink)
whitneyj's Avatar
Member # 135947
Any hardware store. They're $2-3 a piece. I like the swedge clips as they're $0.10 a piece and can be "crimped" with a punch and hammer if you don't have a swedging tool-which are reasonable to buy as well.
Old 04-13-2016, 12:12 PM   #20 (permalink)
Member # 37016
heat shrink over the cable before crimping. Once crimped shrink it down and it'l be water tight
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 12:19 PM   #21 (permalink)
Member # 200324
https://m.mscdirect.com/mobileweb/search_results?catId=12105356&sortby=bestmatch&dir =asc&page=0&ref=keep
2002 Dodge 5.9HO 6sp
2005 Honda Pilot on 31's
83yotski is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 12:25 PM   #22 (permalink)
Member # 55444
I've done this. And then used bigger heat shrink, doubled up over the crimp.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 04-13-2016, 12:32 PM   #23 (permalink)
whitneyj's Avatar
Member # 135947
I like this idea better than the plasti-dip...
Old 04-13-2016, 12:49 PM   #24 (permalink)
Member # 102813
I agree, that would look much nicer.
[/COLOR]
Old 04-13-2016, 06:19 PM   #25 (permalink)
sasaholic's Avatar
Member # 152099
Not saying you don't need them but I've aired out my 6,000lb 4runner more times than I would like to admit and haven't had any issues with my ori's. And that's with 14bolts and 43" sx's so a ton of weight unloading
sasaholic is offline   Reply With Quote Quick reply to this message
