neon transaxle buggy - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2017, 02:24 PM   #76 (permalink)
SHARPMACHINE's Avatar
Member # 84021
Very cool build.
Wow, your rig IS cooler than mine.
SHARPMACHINE
SHARPMACHINE is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 04:56 PM   #77 (permalink)
Member # 182723
for your front disconnect issue could you use a dana 30 front axle shaft? the older ones were vacuum disconnect but you can convert to cable
kris97ranger is offline   Reply With Quote Quick reply to this message
Old 04-01-2017, 03:10 AM   #78 (permalink)
Member # 145218
Thanks guys . Not a lot to report . I have had to pack her away in storage because I sold my place and need to move . Still need to build the diff housings and some electraical . Hopfully Ill be back on her in the fall.
For the disconect with a dana 30 shaft ill look into it.
johny5.0 is offline   Reply With Quote Quick reply to this message
Old 04-01-2017, 01:50 PM   #79 (permalink)
Member # 45798
That's a really good idea. The disconnect is also easily converted to cable actuation to make things easier.
One of these on the front and rear outputs would be fun.
yotota is offline   Reply With Quote Quick reply to this message
Old 04-01-2017, 07:08 PM   #80 (permalink)
Member # 193950
I am curious how this would work. Anyone have a link to someone who has done this?
Aaron Z
aczlan is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 09:50 AM   #81 (permalink)
Member # 145218
Im not sure how it would work as a drive shaft . Be tricky to make the shifting work with a shaft that moves and exteneds and compresses
Old 04-02-2017, 11:21 AM   #82 (permalink)
Member # 193950
That's what I was thinking. I would see using a CAD front axle, but I dont see how it would work for a driveshaft.
Aaron Z
Old 04-02-2017, 11:24 AM   #83 (permalink)
Member # 85771
Two piece shaft? Use it before the carrier bearing?
Make Forums Great Again!
Old 04-02-2017, 11:28 AM   #84 (permalink)
Member # 143697
Nice work 5'Ster
jeep09 is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 04:30 PM   #85 (permalink)
Member # 45798
This.
You would have two-piece shafts front and rear, and the first piece would consist of a cut-down long-side D30 axleshaft with a u-joint yoke welded on each end. This shaft has a split in the middle that is splined on each side of the split, and has a splined collar that locks them​ together. You would utilize the axle disconnect mechanism (and part of the d30 axle tube) to act as a driveline disconnect and support the shafts. You may need to add another carrier​ bearing to the mix for support, I don't recall the bearing configuration in the disconnect axle.
The second piece of the driveshaft, after the typical driveshaft carrier bearing, would be normal.
Old 04-02-2017, 09:59 PM   #86 (permalink)
Member # 145218
With this car and the way it's set up a rear disconnect was pretty straight forward. The front would be hard because the drive shaft would get real short , I didn't want to even add a bearing because it would cost me 2-3 inches , as it is the shaft will be about 20 inches. I'm sure a dodge Dana 60 disconnect would be beef too
Old 04-03-2017, 12:51 AM   #87 (permalink)
Member # 2395
Another possible option along that line would be to run a dodge 60 axle disconnect on your landcruiser axle. That, along with an unlocked arb would allow the front to essentially disconnect.
Unfortunately, the above option is not cheap or easy and I don't see a big enough advantage to justify the extra work and cost. Keep up the good work.
Dustin is offline   Reply With Quote Quick reply to this message
Old 10-02-2017, 01:20 PM   #88 (permalink)
Member # 10161
Send a message via AIM to Grizzwald13
Any updates on this, hell of a build!
Thanks Ross
www.rauschcreekoffroadpark.org
Grizzwald13 is offline   Reply With Quote Quick reply to this message
Old 10-05-2017, 08:14 PM   #89 (permalink)
Member # 145218
Thanks Ross
Thanks !
I moved into my new place 3 months ago and still have not touched it . My plan is to build a new shop here soon so it might be a while yet.
I will post up when I get back on it.
Old 03-29-2018, 08:48 AM   #90 (permalink)
Member # 83301
Hows the shop coming Johnny? Starting back on the build yet?
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 03-29-2018, 12:38 PM   #91 (permalink)
Member # 90208
Send a message via MSN to Garrett85
Subscribed
D90 TD5 - 35" Maxxis M8090 - Longfielded - 3Link
Garrett85 is offline   Reply With Quote Quick reply to this message
Old 01-01-2019, 09:15 PM   #92 (permalink)
Member # 831514
Any updates?
DIESEL314 is offline   Reply With Quote Quick reply to this message
Old 01-02-2019, 09:33 AM   #93 (permalink)
Member # 145218
I dragged it into my tempory shop yesterday and did some work on it and got a feel for what needs to be done . Hoping to get it done for spring.
Posting pics are a pain with photobucket so my updated have been on FB and instagram
Transaxle buggy page on FB and Johns4whln on instagram
Old 01-02-2019, 12:53 PM   #94 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
well dang! cross post a few of them over here if you get some free time
Old 01-03-2019, 06:52 PM   #95 (permalink)
Member # 145218
https://flic.kr/p/2bdCBFS
Pics of the buggy as a roller.
Just learning flickr
Old 01-04-2019, 07:51 PM   #96 (permalink)
Member # 145218
20161228_131927.jpg Photo by johny5 | Photobucket
Old 01-04-2019, 09:11 PM   #97 (permalink)
Member # 827322
For Johnny...
He makes building awesome buggies look easy but posting pics look anything but...lol.
Cheers buddy, lookin’ good.
Fuzzybiscuit is offline   Reply With Quote Quick reply to this message
Old 06-13-2019, 08:45 AM   #98 (permalink)
Member # 85771
This thing driving yet?
Old 06-13-2019, 08:29 PM   #99 (permalink)
Member # 89362
Yup. Been out with him a few times in it. Works very well.
too tall is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 03:48 AM   #100 (permalink)
Member # 85771
Pics? Videos?
